whats the difference between crw and cr2 files.crw photohop cs sees.cr2 it doesn't.
mchivers Member 58 posts Joined Mar 2005 Location: uk More info | Jun 15, 2005 13:47 | #1 whats the difference between crw and cr2 files.crw photohop cs sees.cr2 it doesn't.
mgbeach Goldmember 1,502 posts Likes: 4 Joined Nov 2004 Location: Charleston, SC, USA More info | Jun 15, 2005 13:54 | #2 you need to download the new RAW plugin from Adobe's website. Michael G. Beach
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Jun 15, 2005 13:58 | #3 CS or CS2?
jimsolt Senior Member 758 posts Joined Apr 2004 Location: Palm Beach County, FL More info | Jun 15, 2005 14:23 | #4 mchivers wrote: whats the difference between crw and cr2 files.crw photohop cs sees.cr2 it doesn't. They are different file formats. They come from different cameras. The .crw is an older format. It was followed by .cr2 and in .cr2 there are even 2 different formats, the newer of the 2 used by the Rebel XT and a few other cameras.
mgbeach Goldmember 1,502 posts Likes: 4 Joined Nov 2004 Location: Charleston, SC, USA More info | jimsolt wrote: THE CATCH IS Adobe made this plugin to work ONLY on CS2 and Elements 3. This is inaccurate. I was able to install it under CS and open and manipulate .cr2 files Michael G. Beach
jimsolt Senior Member 758 posts Joined Apr 2004 Location: Palm Beach County, FL More info | mgbeach wrote: This is inaccurate. I was able to install it under CS and open and manipulate .cr2 files edit...v 3.1 is only for cs2, but there is a version for cs that allows you to open .cr2 files Yes, you can open some .cr2 files in CS, but not the .cr2 files from the Rebel XT. They are 2 different file formats even though they are both called .cr2.
mgbeach Goldmember 1,502 posts Likes: 4 Joined Nov 2004 Location: Charleston, SC, USA More info | Jun 15, 2005 14:46 | #7 touche. Michael G. Beach
CyberPet Hiding Under a Rock 4,052 posts Likes: 2 Joined May 2005 Location: Piteå, Sweden More info | Jun 15, 2005 15:23 | #8 You can open 350D files in CS *if* you convert them to DNG-files first and use Camera Raw 2.4. /Petra Hall
| Latest registered member is SteveeY 1171 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
