Thread started 14 Dec 2009 (Monday) 13:45
using 70-200 lenshood on 50 1.4
embdude
Dec 14, 2009 13:45 |  #1
Anybody using their 70-200 lenshood (ET-74) on the 50mm 1.4?
I figured out if I put it on the 1.4 and add a rubber band around the 50 it stays snug. Looks to me like it will not even vignette on the 5D full frame (unless perhaps the sensor sees more than the viewfinder)
Anyway looks like it should do great as a shade....
-Chris
NEW: Photo Blog (external link)/ My Classic Cameras (external link) / Toys: Gear Sig...
Canon PDF's for EOS Digital Cameras (external link)
Free Photo Stuff Blog (external link)
jklewer
Dec 14, 2009 13:47 |  #2
Okay, please post a pic of that.........
Gear
gasrocks
Dec 14, 2009 14:16 |  #3
And if you drop it, will it help protect the lens? Not a good time to be cheap if you ask me. I have a dedicated hood for each lens I use. Use the correct hood.
vipergts831
Has the TF retired? Or just being utterly lazy?
Gallery: 42 photos
Location: Taking better shots with an iPhone than MDJAK with a 1DX
Dec 14, 2009 14:18 |  #4
gasrocks wrote in post #9196362 (external link)
+1 you should always use the accessories meant for your gear.
-Omar- Flickr (external link) , 5px (external link)
Phaseone 645DF+...because only the best will make up for my lack of skills.
Beginners worry about gear, professionals worry about skill and masters worry about light
embdude
Dec 14, 2009 23:10 |  #5
vipergts831 wrote in post #9196372 (external link)
I'm afraid I have to take exception to that theory. :D
Canon makes some fine stuff and some real crap too (memory cards and filters come to mind, how many of you would only consider using canon brand filters or mem cards when nearly everyone else makes a better one?)
Canon does not always make the best products for every shoot. sometimes third party stuff is pretty darn good and sometimes you can do it yourself far better than Canon.
It really depends, but I feel you shouldn't limit oneself by only using only designated accessories.
Photography has a long and proud tradition of mods/hacks/ and cobbles.
Not that you should blindly modify your camera but with proper caution and a little research you can easily exceed the capabilities that using canon only approved accessories would limit you to...
-Chris
embdude
Dec 14, 2009 23:14 |  #6
I should think so. With the 70-200 hood the little 50mm sits inside a plastic cocoon.
-Chris
Replaces
Dec 14, 2009 23:24 |  #7
Just get EF-62 (am i right?) for your 50 1.4... b/c using hood for 70-200 on your 50mm will block part of its FoV.
cccc
Gallery: 18 photos
Dec 15, 2009 00:22 |  #8
Isn't it massive??
vipergts831
Gallery: 42 photos
Dec 15, 2009 07:10 |  #9
embdude wrote in post #9199569 (external link)
Trust me i would be the first to tell you not everything canon is great. Look at my grip down there ;) However, in this situation that lenshood is optimized for the 70-200 and not for the 50 1.4. Lensehoods are a bit different because they are designed around the focal length. Thats what i should have originally stated :D
embdude
Dec 15, 2009 11:12 as a reply to  @ vipergts831's post |  #10
I was trying not to aim my comments/rant at anyone particularly, sorry if I offended
-Chris
duane0524
Dec 15, 2009 12:25 |  #11
Do you spend the money for a Canon Hood or an aftermarket that is made for that lens? I have purchased two Canon Hoods, but have not purchased one for the 50 yet and was just currious of your thoughts.
Canon 50D | Canon 17-55 | Sigma 30 1.4 | Canon 70-200 2.8 IS II| Canon 85 1.8 | 430EXII| 580EX ll | ST-E2 | Canon TC 1.4x II | Benro Travel Angel C1682TB0
MT ­ Stringer
Dec 15, 2009 12:38 |  #12
If you want to try it out, buy a clone hood for the 70-200 off ebay. I bought one specifically to use on the 70-200 because I shoot through the fence a lot at baseball and softball games. I don't want to ruin the original. In fact, it's hard to tell which is which. I plan to cut the hood off square for this season s I can get it perpendicular to the fence and still not damage the lens.
MaxPreps Profile (external link)
My Gear List
amfoto1
Dec 15, 2009 13:13 |  #13
Well, the Canon hood is pretty much a sure bet to be a good, snug fit on the bayonet mount. I'm not as confident that third party hoods will fit as well... but they might. Certainly is an option.
For a few dollars, I bougth the fitted "correct" hood for any lens that didn't come with one, and am slowly adding extras - either Canon or third party that fit well - just in case I lose or break one (well, except for the 300mm and 500mm hoods, I'm pretty careful with those since they cost as much as some lenses do... ).
embdude
Dec 15, 2009 13:32 as a reply to  @ amfoto1's post |  #14
You can always make them yourself.....
http://freephotostuff.​blogspot.com …ee-lens-hoods-part-i.html (external link)
I was thinking of using the PDF cutout with neoprene, much more versital than the hard plastic...
Back to the OP:
The 70-200 hood fits deep on the 50mm so no vignette (even on full frame) and it is far larger than the lens so it is completely protected inside the large hood....
I will obviously need to get a photo to explain.... I will try to get one done soon...
-Chris
embdude
Dec 15, 2009 13:36 as a reply to  @ embdude's post |  #15
It always seemed silly to me to use the "correct, proper, OEM, whatever" lenshood on an EF lens mounted to a crop body.... right of the bat you are making the hood 1.6x less effective...... as far as I know all canon ef (efs????) lenshoods are made for full frame...
-Chris
3,642 views & 0 likes for this thread, 15 members have posted to it.
1346 guests, 136 members online
