FORUMS Photography Talk by Genre Critique Corner
Thread started 14 Dec 2009 (Monday) 18:02
How do I get this sharper? Nightshots
Architective
Dec 14, 2009 18:02 |  #1
I'm having some trouble getting the results I'm after, and I'm not sure why.
These shots were using Av and Manual mode, ISO 100, f4.0- f5.6, 30 second exposures.
What can I do to make the edges more crisp? I'm shooting with a 50D on a tripod with 2 second timer, Tamron 10-24mm.
Thoughts? Criticisms? Suggestions?
IMAGE: http://lh6.ggpht.com/_-Mp8nfBQdjs/SybQkvLFPWI/AAAAAAAAGN8/z0ySZP0WCl0/s512/Vaughn%20Gas%20Station_lg-3.jpg
IMAGE: http://lh6.ggpht.com/_-Mp8nfBQdjs/SybQkonRPyI/AAAAAAAAGOA/F1Fxw5GTCz8/s800/Vaughn%20Gas%20Station_lg.jpg
IMAGE: http://lh4.ggpht.com/_-Mp8nfBQdjs/SybQk1nmhmI/AAAAAAAAGOE/pegA_LK4HeQ/s720/Vaughn%20Gas%20Station_lg-2.jpg
Christopher ­ Steven ­ b
Dec 14, 2009 18:25 |  #2
Obvious solution comes to mind: shoot at f/8 or higher and in bulb mode (you'll need a release or, as I discovered desperately one evening, a rubber band and a pebble!) as you'll be shooting at > 30s. Also, make sure you have a steady tripod. If you can find at least one portion of your images that are super sharp then you can cross shakey tripod off the list of suspects.
I like 3 best--might like to see it rotated CCW a little and the foreground filled a little.
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
jetcode
Dec 14, 2009 18:57 |  #3
Focus is a huge issue. I have found that what I thought was in focus was off. I now use Live View exclusively. I have also found that a cable release is necessary and waiting for the tripod to get steady before firing the 2 second timer. With a short lens it's less of a problem. Wind is another factor. Not so sharp glass is another issue. There are lots of ways to make less than sharp images.
pickupman92
Dec 14, 2009 23:12 |  #4
jetcode wrote in post #9198007 (external link)
Not everyone has live view;)
-Quentin
400D | 50mm 1.8 mkI |17-85 USM IS | Opteka Fish-Eye |Canon 200EG Backpack | SLIK U212 Tripod | Point & Shoot - SD400 | DicaPac Underwater Case for SD400
Southern Exposure Photography (external link)
ajc518
Dec 15, 2009 07:16 as a reply to  @ pickupman92's post |  #5
2 second timer, or having 2 second timer with the mirror lockup on should reduce a lot of the shake.
Canon 7D, Canon XT, Canon Elan 7, Canon 24-105mm L, Canon 100-400mm L, [/SIZE]
firebugg
Dec 15, 2009 14:46 as a reply to  @ ajc518's post |  #6
I agree. If you do not have a release, use the timer. I almost always use mirror lock up when shooting evening low light or night shots. Good luck......Shawn
Snydremark
my very own Lightrules moment
Gallery: 47 photos
Dec 15, 2009 20:10 as a reply to  @ firebugg's post |  #7
As someone earlier said, shoot a smaller aperture f/8 - f/16 depending on which lens you're using and a longer shutter...try around 11sec and see what you wind up with.
Be sure to enable mirror lockup, unless using Live View where it's on by default.
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
1,100 views & 0 likes for this thread
Latest registered member is heflerbj
1166 guests, 256 members online
