Thread started 14 Dec 2009 (Monday) 23:17
Boom: Manfrotto 085BS vs. 3400/420CSUNS vs. 420B
ToddR
Dec 14, 2009 23:17 |  #1
I'm getting confused over the details of these three boom stands:
Manfrotto 085BS (external link)
Manfrotto 3400 (external link) (aka 420CSUNS)
Manfrotto 420B (external link)
I am interested in being able to safely and securely support an AlienBee with a large softbox, umbrella, or potentially a beauty dish. Shooting forward, horizontally offset from the stand, or shooting straight down from a high position, and anywhere in between. I would likely transport this to location from time to time as well as use it in my rather confined basement.
The 085BS is certainly more expensive, but it seems to have the most stuff included with it. Would it be overkill for my purposes, or just a very solid piece of kit that would last forever?
The 420CSUNS seems to have its load capacity at maximum extension overstated on B&H's web site compared to Bogen's (external link). 13.2 lbs. vs. 3.3.
What considerations am I overlooking?
And what is the purpose of the drop-down pin I've seen mentioned in other boom arm threads?
iqbal624
Dec 14, 2009 23:19 |  #2
in for some info also. . .
5d2 | | 50L | 28 1.8 | |
MacBook Pro 15 |
SnlpeR
Dec 15, 2009 02:53 |  #3
i have the 420 with steel base (3390 or something like that)
the softbox pictured is pretty light weight....24"x24"
it holds it no problem even close to full extension
i have put a 4ft octabox on boom mode...but i used a drop down pin
the stand is pretty heavy..thats the only thing i dont like about it
but i can trust it a lot when hanging things on it.
the lazy leg has saved me a few times too
ToddR
Dec 15, 2009 12:58 |  #4
Well, that seems pretty similar to what I would want to mount.
I still don't understand the drop down pin, though.
SkipD
Joined Dec 2002
Dec 15, 2009 13:41 |  #5
In my opinion, the Manfrotto 085BS would be a better choice than the 420 pictured above for one simple reason. The 085BS uses a 15-lb counterbalance weight that is fastened anywhere along the length of the boom. Thus, it's easy to move the weight to a position that provides an absolute balance for the boom. When you've balanced the boom, it is extremely easy to adjust the angle of the boom without fighting one end or the other which is trying to fall down. With the movable weight, you can have any combination of boom length and load and still adjust the counterbalance for a balanced boom.
A drop-down pin allows you to set the angle of the light (relative to a vertical or horizontal reference) and then adjust the angle of the boom. The drop-down pin pivots near where it's attached to the boom, and the light is attached to the pivoting arm. Thus, gravity keeps the light at the same angle to the subject regardless of the boom angle.
Skip Douglas
ToddR
Dec 15, 2009 14:20 |  #6
Thanks, Skip. I was hoping you'd show up, as I've seen you post frequently about booms. :cool:
Sounds a lot easier to move when properly balanced. And having casters and the adjustable leg seem like a plus.
That sort of articulation at the drop down pin sounds quite handy...you can "teeter-totter" the whole boom, but the light maintains the same orientation with respect to horizontal/vertical, but simply higher or lower. A helpful description.
Would I use an Avenger E700 (baby drop down, 5/8") for my lights? I assume the E710 (junior drop down) is for heavier gear that I'm not dealing with. I can't seem to find a Manfrotto part that corresponds to this, though they're both within Bogen.
It's probably unnerving at first to hang a Bee with modifier completely upside-down from one of those, with all its weight bearing on that narrow part of the spigot and the clamp mechanism in the Bee. :eek:
m3rdpwr
Dec 15, 2009 14:24 |  #7
I agree.
I have the same boom and it helps me sleep at night knowing it won't buckle under pressure...
-Mario
SkipD wrote in post #9203262 (external link)
SkipD
Joined Dec 2002
Dec 15, 2009 15:19 |  #8
ToddR wrote in post #9203514 (external link)
I have the Avenger E700 and it works just fine with my AB monolights and any modifier I want to attach including their giant folding softbox.
Skip Douglas
bobbyz
Dec 15, 2009 15:23 |  #9
So with the drop-down pin, irrespective of the boom angle, your light will be at the same angle.
Wouldn't something which let you control this angle be better option? I have seen booms which have this knob that you rotate to change the angle like when you want to control for example the position of the softbox used as a hair light.
Like this:
http://www.bhphotovide​o.com …BSL_Super_Boom_​ONLY_.html (external link)
Of course for indoor use only as I don't think these heavy booms to be practical outdoors.
Fuji XT-1, 18-55mm
HastyPhoto
Dec 15, 2009 18:14 |  #10
just got the 085bs in the mail today, was laying in my front yard thx to mr ups. its a beast. one thing im not happy with is the last pole on the boom was egg shaped a little bit so i had to round that out. put it all together and hung 1 ab800 with large softbox all the way extended out and it held nicely. slight bend in the pole but its a heavy duty boom for sure and im sure ill be happy with it.
60D | EFS 17-55 2.8 IS | Rode VideoMic Pro | Manfrotto 190XPROB
www.HastyPhoto.com (external link)
www.etsy.com/shop/Hast​yPhoto (external link)
www.facebook.com/HastyPhoto (external link)
ToddR
Dec 15, 2009 19:36 |  #11
Kind of annoyed to see that despite Adorama and B&H both having the 085BS for the same price, Adorama is out of stock but has free shipping on it, while B&H has it but would charge me $42 shipping!
HastyPhoto
Dec 15, 2009 19:43 |  #12
YEAH I ORDERED FROM B&H YESTERDAY MORNING AND GOT IT TODAY. iM AN HOUR AWAY FROM NYC THOUGH. sOORY FOR CAPS, HIT BUTTON BY MISTAKE.
ToddR
Dec 15, 2009 20:16 |  #13
"Stand & Boom: 36.1 lbs"
Is that with or without the 15 lb. counterweight?
HastyPhoto
Dec 15, 2009 20:23 |  #14
most likely with it i would think.
ToddR
Dec 15, 2009 22:45 |  #15
I hit the dreaded "submit" button on the 085BS and E700 pin. (crosses fingers)
8,899 views & 0 likes for this thread
Latest registered member is silentmusic99
459 guests, 239 members online
