Thread started 14 Dec 2009 (Monday) 23:17
so a little bird tells me today about ....
Eiro
Dec 14, 2009 23:17 |  #1
that EFS lenses will screw your 5d up even if you put it on just once and take a few pics...
but I dont believe thats true, I've take a few snap shots with my 10-22 on my 5d classic before (havent tried it on mk2) and they came out all messed up but it didnt mess up the camera in anyways, I threw on my L after that it worked just fine....
so what is this rumor which I'm sure has been covered already before, but let me reprise the commentary with this Q?
Get out and shoot
g3ck0
Dec 14, 2009 23:22 |  #2
EF-S stands for short back focus. For some lenses, if you zoom in/out too much, you are going to hit the mirror thus damaging your camera.
Canon 7D | 50 1.4 | 17-55 IS | 10-22 | 18-55 IS | 70-200 F4 IS | 430EX
Eiro
Dec 14, 2009 23:31 |  #3
g3ck0 wrote in post #9199637 (external link)
:D bingoooo
Get out and shoot
crowflyawa
Dec 15, 2009 01:13 |  #4
the EF-S lenses have a rubber boot to keep the mirror form hitting the metal in the rear mount.
This is no guarentee you cant damage something though.
I tested a few EF-S lenses onto my camera also and alsothe Sigma 55-150, it worrked fine.
I had no issue at all, but all my images had a black circle around them as expected
on my 5D FF camera with a crop format lens.
Eiro
Dec 15, 2009 01:29 |  #5
crowflyawa wrote in post #9200217 (external link)
yep thats what happened with I took my 17-35 and used it on my ff
Get out and shoot
Crimzon
Gallery: 13 photos
Dec 15, 2009 04:06 as a reply to  @ Eiro's post |  #6
Isn't putting an EF-S lens on a 5d, like putting Walmart tires on your BMW anyway?
My blog (external link)
Karl ­ Johnston
Dec 15, 2009 05:11 |  #7
Aren't BMW tires made by bridgestone? I think I've seen bridgestone at walmart...and everywhere else :roll:
Adventurous Photographer, Writer (external link) & Wedding Photographer (external link)
n1as
Dec 15, 2009 05:33 |  #8
I tried to mount several EF-S lenses on my 5D and 1D but they wouldn't even mount? Maybe I was 10 degrees off in rotation or something?
My Tokina 11-16 worked just fine on the 1D but I'd be very cautious about putting ANY EF-S lenses on a larger-than-1.6-crop body.
- Keith
http://darwinphoto.zen​folio.com (external link)
JeffreyG
Gallery: 42 photos
Dec 15, 2009 05:41 |  #9
Eiro wrote in post #9199606 (external link)
Can you take a photo of the back end of your 10-22? It sounds like someone modified it.
A stock EF_S lens physically cannot be mounted on a non-EF-S body.
crowflyawa
Dec 15, 2009 07:18 |  #10
JeffreyG wrote in post #9200807 (external link)
That is incorrect.
I have and other people have also mounted EF-S lenses on 5D and 5D MKII cameras.
Some people have mixed results, and it is a risk and not recommended.
But it can work fine too.
The sigma 50-150 is a good example of one i mounted on my 5D and took shots. want me to post the pics with exif?
bohdank
Dec 15, 2009 07:29 |  #11
The 10-22 has a plastic baffle on the rear that can be popped off without damaging it. It can then be mounted on a FF, except that the lens will vignette badly at < 15mm. Apparently it will interfere with the mirror at 10mm. I haven't tried it at less than 11-12 and although it vignettes badly, it clears the mirror.
msowsun
"approx 8mm"
Gallery: 18 photos
Dec 15, 2009 07:35 |  #12
crowflyawa wrote in post #9201076 (external link)
That is incorrect.
I don't think you should call 3rd party lenses EF-S. So I think that statement IS correct.
Canon EF-S lenses need to be modified in order to mount on a FF camera. On many EF-S lenses this is done by simply sticking a finger into the rear opening and popping out the little plastic piece that prevents the lens from fitting to a FF. On others (18-55) you need to cut off the protrusion as it is physically part of the plastic mount.
Sigma, Tamron, Tokina, etc, use a standard EF mount and will of course mount on any FF camera. I don't believe there are any 3rd party lenses that have the rear element protruding past the rear of the mount, so there is no risk of damage and no need or the EF-S style mount.
Canon EF-S lenses often have the rear element protruding past the rear edge of the mount and will hit the mirror at wide focal lengths.
SkipD
Joined Dec 2002
Dec 15, 2009 07:37 |  #13
A stock EF-S lens physically cannot be mounted on a non-EF-S body.
Quite true
That is incorrect.
Crow, your statements are incorrect. However, I do believe that you are confusing something.
First off, a Sigma (or any other third-party) "digital only" lens is NOT an EF-S mount lens. They will mount on any Canon EF-mount camera, though there will be a lot of vignetting, etc.
Canon EF-S mount lenses CANNOT be mounted on cameras not designed to accept them without modification of the lens. If one modifies the mount of an EF-S lens and uses it on other bodies, there is very definitely a risk of crashing the camera's mirror into the rear element of the lens when the lens is used at some focal lengths.
Skip Douglas
timnosenzo
Dec 15, 2009 07:57 |  #14
That is incorrect.
No it's not.
3rd party lens manufacturers don't use the EF-S mount, they use a standard EF mount, even if it can only be used on a crop body.
Canon EF-S lenses can only be used on the 7d, the Rebel cameras, and the 20/30/40/50D's.
JeffreyG
Gallery: 42 photos
Dec 15, 2009 18:05 |  #15
OP specifically referred to a '10-22' lens, and only Canon make such. The Canon EF-S 10-22 will not physically mount to a 5D unless the rear baffle is tampered with.
3rd party lens companies make small format only lenses (like the Sigma 10-20) and these lenses will physically mount to a 5D but they only provide partial coverage of the sensor.
2,602 views & 0 likes for this thread, 13 members have posted to it and it is followed by 2 members.
1521 guests, 132 members online
