Thread started 15 Dec 2009 (Tuesday) 00:43
lens focal length question
kkamin
Dec 15, 2009 00:43 |  #1
Can someone explain how the lens' local length is measured. I read somewhere it is from the center of the lens, when it is focused on infinity, to the flim or sensor plane.
What is the center of the lens? How do you set the camera on infinity since it seems to be dependent on f/stop--higher f/stops would yield focus to infinity "quicker".
Thanks for reading.
Kkamin
I shoot with a disposable Dora the Explorer camera
I have a special 18-55mm lens made from tree bark and unicorn farts
I start uncontrollable fires for my lighting
www.kevinkaminphoto.co​m (external link)
20droger
Dec 15, 2009 01:02 |  #2
The focal length of a simple lens is the distance from the center of the lens to the point of convergence (the sensor plane) when the lens is focused at infinity. This distance is both an optical and a physical distance.
Camera lenses, however, are not simple lenses.
The focal length is the optical, not physical, distance from the rear node of the lens to the sensor plane when the lens is focused at infinity.
Two things to keep in mind. First, don't confuse infinity focus with depth of field. They are entirely different. The lens is focused at infinity at only one position of the focus adjustment. Aperture has nothing to do with it.
Second, a complex camera lens has no optical center. Instead it has a front node and a rear node. The front node is where the "center" would be when viewed from the front of the lens, and is usually behind the rear node. Similarly, the rear node is where the "center" would be when viewed from the rear of the lens, and is usually in front of the front node. In fact, the rear node may not be within the body of the lens at all, but somewhere in front of the front element.
The focal length of a lens is a physical property of the lens itself, and has nothing whatsoever to do with the sensor size. The so-called "crop factor" affects only the angle of view, not the focal length.
Wilt
Dec 15, 2009 17:03 |  #3
If as a child you ever used a simple magnifying glass to focus the sun onto ants, the distance from the lens to the focused image of the sun is the Focal Length. What 20droger described is with a complex lens, and for the dSLR the long FL lens is designed to have a shorter-than-FL distance so it is called 'telephoto' design, and the short FL wide angle lens is designed to have a longer-than-FL distance so it is called a 'retrofocus' design.
kkamin
Dec 15, 2009 18:51 |  #4
20droger wrote in post #9200168 (external link)
Is that the focus ring twisted all the way in the "far focus" direction?
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Dec 15, 2009 22:39 |  #5
Maybe not. Sometimes a lens will have the focus extend beyond infinity to allow for variations due to temperature.
20droger
Dec 15, 2009 23:35 as a reply to  @ PhotosGuy's post |  #6
PhotosGuy's right. Most lenses can focus past infinity.
When a lens is focused at infinity, all the light rays from an extremely distant point source, like a star, enter the lens as parallel rays. These are then focused to a point at the focus distance (ignoring lens aberration, which is another subject [and why camera lenses are not simple lenses]).
When a point source is relatively close to the lens, the light rays are diverging (getting farther apart) as they enter the lens. They will be focused to a point at a distance farther than the focal length. This means that to focus on a object closer than infinity, the lens must be moved away from the sensor (optically).
Most lenses can be adjusted to cover a range of minimum focus to infinity and beyond! Focusing past infinity means the lens is optically closer to the sensor than the focus distance, and light rays entering the lens must be converging (getting closer together) as they enter the lens. This cannot occur naturally.
The reasons for being able to focus past infinity are to compensate for thermal changes and manufacturing tolerances in the lens.
Frank—nice car, but it's no Brownie.
SkipD
Joined Dec 2002
Dec 16, 2009 06:43 |  #7
kkamin wrote in post #9205075 (external link)
PhotosGuy wrote in post #9206351 (external link)
In the "olden days" when all camera lenses were simpler manual-focus lenses, twisting the focus ring to one stop usually was the correct position for "infinity" focus.
With today's autofocus lenses (including all three "L" series Canon zoom lenses that I have), there is often a little overtravel at the "infinity" end of the focus ring travel. I am fairly certain that there is one reason why this is true, and it is not related to temperature. The reason for overtravel is so that the autofocus drive system won't slam the focus system against a hard stop every time you aim the camera at a distant subject and activate autofocus. There's a little bit of room for overtravel in the servo system that drives the focus mechanism. If this overtravel were not allowed, I suspect that you'd be sending your autofocus lenses in for repair rather frequently.
Skip Douglas
20droger
Dec 16, 2009 07:53 |  #8
SkipD wrote in post #9207831 (external link)
I represent that remark!!!
siriusdogstar
Dec 16, 2009 08:15 |  #9
http://en.wikipedia.or​g/wiki/Focal_length (external link)
SkipD
Joined Dec 2002
Dec 16, 2009 08:18 |  #10
In the "olden days"....
20droger wrote in post #9208086 (external link)
So do I :p.
Skip Douglas
PhotosGuy
Joined Feb 2004
Dec 16, 2009 19:15 |  #11
20droger wrote in post #9206680 (external link)
The Brownie will be back after Christmas. ;)
IThe reason for overtravel is so that the autofocus drive system won't slam the focus system against a hard stop every time you aim the camera at a distant subject and activate autofocus. There's a little bit of room for overtravel in the servo system that drives the focus mechanism. If this overtravel were not allowed, I suspect that you'd be sending your autofocus lenses in for repair rather frequently.
Good point!
1,119 views & 0 likes for this thread, 6 members have posted to it.
2786 guests, 132 members online
