elitejp wrote in post #9201694
Its really easy to recommend the newest intel i7 or even the amd phenom II x4 with all the ddr3 1600 ram you can fit in the mobo, but what about trying to build a machine that costs very little and can still edit pics and video at a reasonably fast speed?
So lets hear what you would recommend as a low budget build that can still pump out thise pics and videos!
Like the others said, low budget's vary. An i7 will chew through video very well, but that isn't the only factor when considering a machine for video editing. For instance, typically, you don't want to scrimp on the motherboard or power supply. Video is very demanding. It requires good through-put from the point of entry (video card, capture card, bus, memory and so on). I do 90% of my video work on a Mac Pro despite my PC being more than adequate for video work because OS X, Final Cut Studio and the hardware are very predictable.
The best system's are the ones that act predictably. Here are some general rules that 'usually' work well for video work. When getting a system, try to stay within the same company/chipsets. If you get a motherboard by (or with) nVidia for instance, also get an nVidia video card. It's more likely (but not always true) that a company will test their own products together more than they would with competitors. Intel chipsets are usually very good with video. Since Intel put's out the templates that manufacturers base their systems on it's typically also true that they will be more compatible. Start with the motherboard. Find one with a solid record, isn't the least expensive and one that is over clockable (but DO NOT over clock it). When rendering video your computer is going to be pushing very hard for a long time - sometimes for hours. If it's a good over clocker that will 'probably' mean that it will have less voltage droop, has better capacitors (which take the heat) and would glitch less due to heat issues. When it comes to CPU's - just about all of them are fine - just get as much power that you can afford with the most amount of cores. Video rendering is very multi-thread friendly. Final Cut Pro, After Effects, Avid, Premiere will use every CPU you give them.
After motherboard and CPU choose a video card (with the criteria from above) that supports OpenGL (no problems there). It doesn't have to be the latest and greatest, just enough to push things along. Many video plugins are very 3D intensive so at least get a card in the $150-$200 range from nVidia or AMD. Other, specialty video cards are probably out of your price range though.
RAM should be fast. Don't get cheap RAM and get at least 6GB if you plan on doing anything semi-serious. If not, then 3 or 4 will be fine - but plan on seeing it top out with RAM previews and start cacheing to the HDD. The slowest RAM I would get would be 1066. Though timings on the board or CPU may slow things down, the bandwidth will help overall because the RAM will not be taxed and later you fell more confident you can look into changing the timings of the RAM if the voltage is being met.
The only thing I can say about hard drives is get as much as possible and again, try to get the fastest you can afford. I personally go with Seagate drives, but WD blacks are fine. I personally use Velociraptors for the main drives and Seagates for data. I've had a bad string of luck with WD Black's - four have died on me in the last two months, but I'm a very heavy user.
As far as optical media, just about anything will do, but for high scale media I went with Sony's blu-ray rom's - who better than them to make a blu-ray drive?
Case - I use an Antec 900 - cool, roomy and not too expensive.
Monitors are actually not 'extremely' important for video work so whatever works for photos will work fine for video. Final Cut comes with Color and built in color scopes that are more accurate than any computer monitor you'll get under $1000. Eyeballing color for video is a no go - you won't be able to do it well enough without other more expensive equipment if you plan on making broadcast quality video.
That all might sound a bit difficult for the average person, but it really isn't. All said, I could probably put together an OK video editing station for about $900 with a Core 2 Quad or $1400 for an i7. I wouldn't much like to go under those prices if I wanted an 'OK' video editing computer. And if I was truly serious about video work I would look into a workstation from Dell, HP or Apple, but those all cost a pretty penny.
