Thread started 15 Dec 2009 (Tuesday) 21:33
Mounting Multiple Speedlights on a Stand
crackaonrice
Dec 15, 2009 21:33 |  #1
To make it potentially more difficult I have the speedlights mounted on Radiopopper PX stands which are directly threaded into. What are some solutions out there for attaching two (preferably three) of these speedlight/Radiopopper PX setups on a single light stand?
Why does everybody list their gear here? :rolleyes:
http://www.jkan.net (external link)
Palladium
Dec 15, 2009 21:36 |  #2
crackaonrice wrote in post #9205941 (external link)
take a look at this bracket
http://www.bhphotovide​o.com …3_Umbrella_Tilt​_Head.html (external link)
crackaonrice
Dec 15, 2009 21:51 |  #3
Problem there would be the hotshoes as I need to screw the flash/PX setup directly into threads. Is there some sort of hotshoe to thread converter out there?
Palladium
Dec 15, 2009 21:54 |  #4
crackaonrice wrote in post #9206050 (external link)
The 2 cold shoes at the ends unscrew and there is the 1/4 screw - I use these brackets with the PW's flexs - I connect the flexes directly with the 1/4 screws.
FJ ­ LOVE
Dec 15, 2009 21:57 |  #5
doesn't sound hard to make,piece of aluminum flat bar couple of holes couple of bolts
your good with a camera i'm sure you could wing it
DILLIGAF about your bicycle or your gear
tetrode
I am a walking repository of thoroughly useless information
Dec 15, 2009 22:11 |  #6
How much flexibility in speedlight positioning do you require? Are they all going to be aimed in the same direction from the same height? On the rare occasions when I need to mount multiple speedlites to a single stand, I use Manfrotto 175 spring clamps (http://www.bhphotovide​o.com …75_175_Spring_C​lamp_.html (external link)) on the lightstand riser. A standard stud with a 1/4-20 male end inserted into the clamp's 5/8" socket provides the necessary screw on connection point. The more elegant and extravagant solution is the 175F "Justin" clamp with its standard ballhead.
Dave F.
Palladium
Dec 15, 2009 22:14 |  #7
tetrode wrote in post #9206157 (external link)
Dave F.
this morris bracket also has an umbrella holder and you can position the lights to the center of the umbrella
tetrode
Dec 15, 2009 22:31 |  #8
Palladium wrote in post #9206175 (external link)
That's a nice feature but the OP didn't say he was using an umbrella.
Dave F.
mikekelley
"Meow! Bark! Honk! Hiss! Grrr! Tweet!"
Dec 16, 2009 00:22 |  #9
I just use a super clamp for the other one and clamp it to the center column
Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography (external link)
How To Photograph Real Estate and Architecture (external link)
My Fine Art Galleries (external link)
My articles at Fstoppers.com (external link)
crackaonrice
Dec 16, 2009 01:12 |  #10
Thanks for all of the responses guys! I probably should've mentioned that I do use modifiers for the most part but occasionally do shoot bare bulb in which case I'd like the lights on the same stick to be as close together as possible (I have other sticks if I need to position them far apart) as I'm mainly looking for some more power to be able to overpower brighter light sources.
crackaonrice
Dec 16, 2009 02:31 |  #11
Palladium would I be able to mount 3 flashes on the Morris bracket? Not too sure whether the third would fit in the modeling light location.
mufutau55
Dec 16, 2009 09:13 as a reply to  @ crackaonrice's post |  #12
I have this kit, got it on sale from Photoflex for $59.99 came with a Swivel umbrella bracket too. Not bad for mounting three flashes.
http://www.bhphotovide​o.com …l_Shoe_Flash_Ad​apter.html (external link)
Mufutau
Palladium
Dec 16, 2009 09:26 |  #13
crackaonrice wrote in post #9207287 (external link)
Sure if you look carefully at the image you'll notice that there is a 3 slots. At each end and another off to the side of the center.
You could put any number of 1/4 screws through these slots to mount additional cold shoes or flash triggers.
Also the 2 thumb screw at the end of the bracket slide and rotate within their slots.
Originally I was using these brackets with flashes in the cold shoe and a PW Plus II mounted to the screw to the side of the center column. I used a mono y splitter from the PW to the flashes.
Now I remove the cold shoe and just mount the flashes to the new PW Flex and use the thumb screw.
NVcameraman
Dec 16, 2009 12:24 |  #14
Two Canon 550EX's attached to a 10 inch mending plate I got from Home Depot. Attached with 2 Smith Victor cold shoe adapters, 2 Female Hotshoe to Inexpensive Radio Slave Adapter Cables from Flash Zebra, Y splitter cable from radio shack and fired with cybersync
IMAGE: http://farm3.static.flickr.com/2130/2194023648_4280b5512d_b.jpg
Ben Morrow :) www.eagleeyephotograph​y.us (external link)
20D|Rebel XT|D30|Sigma 120-300 f2.8|Sigma 70-210 f2.8|Sigma 24-70 f2.8|Sigma 12-24 f4.5-5.6|Tamron 75-300 f4-5.6|Canon 50 f1.8|580EX|420EX|Sunpa​k 544 x2| Quantum 1+ battery|DIY battery pack
7,132 views & 0 likes for this thread, 7 members have posted to it.
1096 guests, 179 members online
