Hi All,
I was just wondering how many folks out there with Carbon Fibre 055 series legs have noticed marking to the carbon fibre tubes, toward the inside of the legs near the base of the first (largest) leg section.
From what I've seen, if the tripod gets a heavy knock when in the 'closed-up' position illustrated below, there is the possibility for the legs to strike the base of the centre-column, causing scuffs in the tubing (circles mark the approximate location of scuffs (but on the 'inside' of the legs)).
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
I'm just curious if this is a widespead issue, or if I need a more careful courier. The first 055CXPRO3 I took delivery of must've had an awful journey; I returned it for exchange, and while it's arrived in a lot better condition than the first, the replacement still has some scuffs to the inside of the legs.
I'd be eternally grateful if owners of similar pods would advise...
Thanks and regards,
Rob.
No! Mine arrived in perfect condition.
