Thread started 16 Dec 2009 (Wednesday) 18:18
HELP: canon 1d mark iin w/24-70 l
jelaineab
Dec 16, 2009 18:18 |  #1
So I just got both of these this week and for some reason when I make the image sharp on the view finder then do it manually on the lens, the image does not come out the same. whats the problem?
Joyceelaine
1D Mark IIN| 5D Mark II | Canon 24-70 L | Canon 50mm 1.4 | Canon 580EX II
sonnyc
Joined Jun 2005
Dec 16, 2009 18:25 |  #2
I don't get the post.
Did you mean the image looks fine in the "viewfinder" but not sharp when downloaded to the computer?
Can you post an example?
Sonny
Replaces
Dec 16, 2009 18:38 |  #3
i do not understand OP's meaning.
jelaineab
Dec 16, 2009 18:47 |  #4
in the viewfinder it looks good, but when i take the picture, it appears completely different on the lcd, blurry. now when i change the dioptric lower so it looks blurry in the view finder, it looks clear in the lcd when the image is shot
Joyceelaine
jelaineab
Dec 16, 2009 19:47 as a reply to  @ sonnyc's post |  #5
Joyceelaine
gator1970
Dec 16, 2009 20:04 |  #6
jelaineab wrote in post #9212397 (external link)
Put a white sheet of paper in front of the lens and adjust the diopter until the focus point squares are sharp. If I understand your meaning, this should solve your problem.
sonnyc
Joined Jun 2005
Dec 16, 2009 20:26 |  #7
The AF points are independent of the diopter. You can have a blurry viewfinder as long as the lens focus, the pic will sharp.
Make sure you have enough light, point the lens at a large object with good contrast, the camera box is a good one 1/2 press the shutter to get AF going and confirm with a beep and take a shot. If it still blurry then something is wrong with the lens or camera. Try it with another lens if you have one see if it does the same.
Sonny
gator1970
Dec 16, 2009 20:33 |  #8
4x4rock wrote in post #9212635 (external link)
I believe the OP said s/he was MFing the lense - so the view through the viewfinder would certainly affect the focus...
jelaineab
Dec 16, 2009 21:59 as a reply to  @ gator1970's post |  #9
thanks. i'll give both a shot and let you know how it goes :)
Joyceelaine
gator1970
Dec 17, 2009 22:47 as a reply to  @ jelaineab's post |  #10
well? enquiring trolls would like to know....:lol:
dzaneh
Gallery: 6 photos
Dec 19, 2009 16:28 |  #11
do you need glass' ? lol
stuff
jelaineab
Dec 20, 2009 08:51 |  #12
Its still blurry in the viewfinder, autofocus works, but its like I won't be able to Manual focus. The article perfectly describes my situation, what should I do
Joyceelaine
jelaineab
Dec 20, 2009 08:52 |  #13
this article, in this my other thread, https://photography-on-the.net/forum/showthre​ad.php?t=797273
Joyceelaine
1,244 views & 0 likes for this thread, 5 members have posted to it.
1801 guests, 120 members online
