Thread started 17 Dec 2009 (Thursday) 03:14
Question about lighting setup
JaredBush
Dec 17, 2009 03:14 |  #1
I'm in need of assistance! I am trying to do a few Christmas portraits this upcoming friday for some friends. I'm fairly new to shooting indoors and with lights. I have ordered the Calumet Genesis 400 2-Light Kit but sadly it will not arrive until next week. So I am either going to have to rent equipment or use some lights I borrowed from a friend.
Can anyone suggest a setup with the equipment below or even post a diagram? Any help would be appreciated! I'm shooting with the 7D and 17-55 f2.8 and i'll have the expodisc to set the white balance. I have a pretty big room with florescent lights that can be turned off.
This is what I have:
*Camera, Tripod, Trigger
*Backdrop (10x20 Red Diamond cloth) and stand
*36in Reflector 5-in-1
*Plenty of cardboard, whiteboard, white/black diamond cloth
*Speedlight 430EX II w/ stofen
*2 Photoflex Starlite Lights w/ either 500 or 1000 watt bulbs w/ softboxes, diffusers, waffles
Here is the link for the lights...
http://www.photoflex.c​om …_Digital_Kit_2/​index.html (external link)
and specs:
http://www.photoflex.c​om …Specifications/​index.html (external link)
1000 watt lights:
3200 kelvin
Lux @ 10 feet - 400
F-stop @ 10 feet - f2.0 @ 1/30 sec.
F.V @ 10 feet - 7
Canon 7D (Gripped) - Canon EF 24-70mm f/2.8 L USM - Canon EF 100-400mm f4.5-5.6 L IS USM - Sigma 50mm f/1.4 EX DG HSM
Sigma 10-20mm F4-5.6 EX DC HSM - Tamron SP 90mm f/2.8 Di Macro - Canon Speedlite 430EX II
Calumet Genesis 400wt Lighting Kit - Manfrotto Tripod/Velbon Monopod - Skywatcher 8" SCT
JaredBush
Dec 17, 2009 04:03 |  #2
Would this work? And if it would, should I get any lamp available and try to light the background a bit?
IMAGE: http://i579.photobucket.com/albums/ss236/ForumRiderUSA/Possibility1.jpg
Big ­ G
Dec 17, 2009 07:50 |  #3
subscribing, I'd be interested in the answer as I've just started using two lights. I have experimented with different setups and I am not 100% happy with results so far.
S100, 1000D (My first DSLR) plus R and various lenses
Full Gear List
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Dec 17, 2009 09:39 |  #4
Your setup looks okay. The nice thing about continuous lights is you see what you are getting up front. Dont try to mix in your 430ex as you will have color balance issues unless you gel it. You can do a test to see the effect of the ambient light. Ordinarily with flashes it wouldnt be an issue, but you may have to work slow enough with the continuous lights that it may contribute a little color cast.
JaredBush
Dec 17, 2009 13:30 |  #5
gonzogolf wrote in post #9215477 (external link)
Yea, I didn't think using the speedlite with the softboxes would work too well. Are two 1000 watt softboxes going to give me enough light? How slow am I going to have to shoot at?
gonzogolf
Gallery: 559 photos
Dec 17, 2009 14:15 |  #6
That greatly depends on the aperture you pick. I havent used continuous lights that bright in a while so I cant say off the top of my head. You may be in handholdable range, but I think I would plan on having a tripod on hand just to be sure. I dont think we are talking super slow, but possibly slow enough that camera shake might be an issue handheld.
doidinho
Dec 17, 2009 14:48 |  #7
I would put one light on either side, up high, and in the softboxes. You could then use the speedlights for the background if you want, but it isn't necessary.
Here is a shot I took of some people at my work the other day. umbrell on either side of the group, up high, and feathered. I also had one light in a strip box on the background.
IMAGE: http://farm3.static.flickr.com/2568/4192874635_cc62c7ea50_o.jpg
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
JaredBush
Dec 17, 2009 16:51 |  #8
^ Perfect example of what Im looking for...
Can I get the same results with 2 1000 watt softboxes versus umbrellas? Will I be able to shoot at f9 so everyone is in focus?
Player9
Dec 17, 2009 17:18 |  #9
JaredBush wrote in post #9216979 (external link)
With two 1K watt softboxes setup in a way that the key is somewhat supplemented by a neutral on-axis fill, I'm thinking that you could shoot f/8 in the area of 1/25-1/60, at ISO 400. If you are using a reflector for fill (with the other softbox as a backlight), you may have to raise the ISO to 800 to keep the shutter speeds reasonable at f/8. YMMV.
RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
drumsfield
Dec 17, 2009 18:24 |  #10
JaredBush wrote in post #9214501 (external link)
Doesn't this setup cast shadows if there are more people in the picture? I think the two light up front would work better for larger groups.
Canon 5D MkIII | Olympus OM-D | Olympus E-P2 | 16-35L MKII | 24-70L MKII | 70-200L MKII | 85L MKII | EF 50mm 1.4 | EF 100mm 2.8 | 100-400mm L MKII | 20mm 1.7
Feedback and Full gear list
Website (external link)
JaredBush
Dec 18, 2009 02:50 |  #11
I played around with everything tonight... Here is what I am working with:
Here are some test shots... My buddy stood in for the tests:
For this one the light was almost behind the camera almost directly infront of him...
JaredBush
Dec 18, 2009 03:00 |  #12
I like how Doidinho's is pretty evenly lit. How can I achieve something closer to what he had?
Doidinho's photo was f9 - 1/160 - 100 ISO
Mine are closer to f9 - 1/40 - 800 ISO
Are my lights just not strong enough?
skydiver_8
Dec 18, 2009 03:48 as a reply to  @ JaredBush's post |  #13
Kinda noisy I think, any need for the 800 ISO? You're going to get quite a bit of the red cast due to the background reflecting from everywhere so I think you'll be disappointed with the skin tone. I've used a similar setup but I used umbrellas and you don't lose as much light.
What if the Hokey Pokey is really what it's all about?
gonzogolf
Gallery: 559 photos
Dec 18, 2009 09:08 |  #14
Looks like you are going to need to lock onto the tripod and go even slower with the shutter speeds.
JaredBush
Dec 20, 2009 16:51 |  #15
Update: Here is a pic of the results... I am happy with them, but I think I've got a lot of room for improvement!
IMAGE: http://farm5.static.flickr.com/4004/4201633826_a2d31965bb_b.jpg
2,928 views & 0 likes for this thread, 7 members have posted to it.
1097 guests, 120 members online
