Thread started 17 Dec 2009 (Thursday) 07:13
New Sigma 530 DG Super stuck at 17mm
Rebecka
Post edited over 2 years ago by Rebecka.
Dec 17, 2009 07:13 |  #1
Has anyone experience of this or got any tips to fix it?
The wide angle adapter seems fine, but regardless of the position (in or out) the flash zoom stays at 17mm and pressing the zoom button has no effect.
It is looking like I might have to send it back, but just hoping otherwise as it was bought online (Amazon UK) and so with Christmas I will be looking at next year before getting a replacement.
Thanks.
Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
EXIF is available inside all my photos, though bribes are still recommended anyway.
fortinaa
Dec 17, 2009 10:18 |  #2
No real clue as I don't have one, but I would try:
1) Holding in the zoom button and see if that allows the setting to blink and be changed.
2) Tilt the flash head at different angles and see if that fixes the issue. I believe some flashes have a fixed zoom if they are tilted downward (the one tiny click below head-on flash).
Aaron
Curtis ­ N
Master Flasher
Dec 17, 2009 21:27 |  #3
Push the wide panel all the way back in to allow the zoom function to work.
Rebecka
Dec 18, 2009 13:38 |  #4
It is in as far as it will go, but with no effect on the zoom setting stays at 17mm. Likewise holding down the zoom button or changing angle.
Looks like I will need to arrange a return and exchange.
Thanks anyway.
Curtis ­ N
Master Flasher
Dec 18, 2009 20:17 |  #5
I forgot to mention:
It will only autozoom when pointed straight forward. In other positions it will autozoom to 50mm regardless of lens focal length but manual zoom should work.
Sounds like you could have a faulty unit.
1,308 views & 0 likes for this thread, 3 members have posted to it.
1043 guests, 105 members online
