Thread started 17 Dec 2009 (Thursday) 11:29
Help: Viewfinder blurry
jelaineab
Dec 17, 2009 11:29 |  #1
I have a 24-70 L on a 1d mark ii n. whenever i try to use manual and make it sharp in the viewfinder, the image does not come out sharp when i take the photo. when i use autofocus itl come out sharp, but becomes blurry in the viewfinder, not completely blurry, but not as sharp. I'm not sure what the problem is. thanks!
Joyceelaine
1D Mark IIN| 5D Mark II | Canon 24-70 L | Canon 50mm 1.4 | Canon 580EX II
anthony11
Dec 17, 2009 11:34 |  #2
bannedPermanently
Sounds like you need to tweak the diopter dial on the body.
5D2, 24-105L, 85mm f/1.8, MP960, HG21, crumbling G6+R72, Brownian toddler
Genome
Dec 17, 2009 11:41 |  #3
yep i agree. its the little wheel next to the view finder, turn it till its clear
In the bag:
Canon 500D Tamron 17-50 f2.8 Canon 70-200L f4 Jessops 2x converter Jessops 360 Flash
jelaineab
Dec 17, 2009 11:56 |  #4
i have. its perfect and sharp, but the image is blurry when taken.
Joyceelaine
dle42
Dec 17, 2009 11:59 |  #5
jelaineab wrote in post #9216300 (external link)
What is perfect and sharp? The viewfinder image when manually focusing?
Gear
anthony11
Dec 17, 2009 11:59 |  #6
bannedPermanently
What sort of shutter speed are you using? Lens with IS?
charliec
Dec 17, 2009 12:00 |  #7
you may just need a focusing screen. it can be very difficut to judge a perfectly focused shot when manually focusing.
spuddevans
Dec 17, 2009 12:06 |  #8
jelaineab wrote in post #9216129 (external link)
It sounds like you are saying that when you focus manually, the image appears sharp in the viewfinder but the resulting digital image is blurry, but when you use autofocus the viewfinder is blurry and the digital image is fine, right?
If that is the case, you need to adjust the diopter wheel next to the viewfinder. To do this, put the camera on a tripod, use the auto-focus to focus the camera, and then adjust the diopter adjustment wheel until the viewfinder is clear and sharp.
Tim
Canon 400D, 7D, EF50mm 1.8, EFS17-85mm, 135mm pentax m42 2.8, 2 sets of m42 extension tubes, 1 m42 macro bellows. Ps elements 1,5 & 8
My gallery: www.velvet-art.co.uk (external link)
jelaineab
Dec 17, 2009 12:14 |  #9
I tried doing what you said and it looks better in the viewfinder when i do auto focus. but when i switch it to manual focus, i can actually make it look sharper through the view finder, but when i do the image looks blurry. its as if the camera cant focus like the lens, that might sound weird
Joyceelaine
phigment
Dec 17, 2009 12:19 as a reply to  @ jelaineab's post |  #10
It could be a misaligned focus screen. I had the same problem with my 5dII after I put in the Eg-S screen.
Even though it looked seated fine, once I gave it another nudge and reclosed the housing all was fine.
Did you replace a focus screen recently?
Paul
A7R, Firin 20mm, CV 21/4, CV 40/1.4, 100ZE, 300 4LIS, Tamron 150-600, Jupiter 8, RX100 IV
deadpass
Dec 17, 2009 12:19 |  #11
You might need to keep making small adjustments to the diopter. Are you taking all of the shots at the same focal length? it's possible your lens has a focus issue. You could post two pictures to compare you focusing vs. the camera. that might help.
a camera
http://www.deadpass.co​m (external link)
siriusdogstar
Dec 17, 2009 12:31 |  #12
could be a number of things.
1. standard focus screen is too slow to show changes when using lenses faster than f/3.5, see http://www.jayandwanda​.com …_man_focus/man_​focus.html (external link) for explanation.
2. focus screen needs shimming to accurately focus. Canon calls these "washers." They are available inexpensive from Parts; adjustment can be tedious. Canon repair center also does shimming.
3. viewfinder diopter adjustment is off. should be adjusted without a lens for sharpest view of camera settings around frame.
jelaineab
Dec 17, 2009 12:47 |  #13
thanks sirius! the article describe exactly what im going through. thankssss!
Joyceelaine
1,632 views & 0 likes for this thread, 9 members have posted to it.
1801 guests, 120 members online
