I was just wondering if I make 3 copies of the same RAW file, can I adjust the exposures in PP and then merge to HDR? Or does it have to be shot in the various exposures?
Mike787 Member 222 posts Joined Dec 2009 More info | Dec 19, 2009 23:21 | #1 I was just wondering if I make 3 copies of the same RAW file, can I adjust the exposures in PP and then merge to HDR? Or does it have to be shot in the various exposures? Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Dec 19, 2009 23:23 | #2 You can definitely do it that way. You don't even need to make 3 copies, just develop and output jpegs from the same file multiple times. Taylor
Dec 19, 2009 23:26 | #3 Ok thanks, I'll try it out. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
Collin85 Cream of the Crop 8,164 posts Joined Jan 2007 Location: Sydney/Beijing More info | Dec 19, 2009 23:26 | #4 No, you can use one exposure and rely solely on the headroom provided by the single RAW. Many people do not regard this as true HDR, but rather 'pseudo-HDR'. Personally, I find pseudo to work well under certain circumstances. Infact, the following came from a single JPEG (not even RAW), so you can definitely achieve a typical HDR-looking image from just one file.
Col | Flickr
TeamSpeed 01010100 01010011 More info | Dec 19, 2009 23:33 | #5 ^ Those are great, would you mind sharing some of your technique in using just one JPG? I am okay in CS3 but I would not be able to pull off those shots, they are wonderful! Past Equipment | My Personal Gallery
Collin85 Cream of the Crop 8,164 posts Joined Jan 2007 Location: Sydney/Beijing More info | Dec 19, 2009 23:51 | #6 Thanks TeamSpeed! Each shot is worked a slightly different way, but it's a combination of a set of curves adjustment layers (with each selectively masked over different areas of the shot), while also playing with the Shadows/Highlights tool and the like. The shots are actually shot in RAW, where I then pick an 'optimum exposure' to convert to JPEG (or TIFF if you prefer) before doing this workflow in CS4. I always use DPP rather than ACR as I get punchier results. The most important thing is setting up for the workflow in-camera. The histogram is key, and things like a CPL can help alot (it certainly did for the second shot).
I never use programs like Photomatix anymore. I bought the full licence a couple of years back but it has honestly never given me the results I wanted.. so here's a thumbs down to tone-mapping from me personally, although I'm sure there are many others who get great results from such programs. Col | Flickr
NeoTokyo Goldmember 2,005 posts Likes: 2 Joined Mar 2008 Location: Sacramento Ca, Springfield Mo. More info | Dec 20, 2009 05:19 | #7 Awesome examples Collin Check out my flickr! http://www.flickr.com/photos/crainracing/
Dec 27, 2009 14:13 | #8 Awesome, thanks collin. The one thing I've noticed from trying from one RAW is massive clipping in white areas and blow outs in some other areas. Is there any way to prevent that or is it just the shot? What histogram shapes should I look for / stay away from? Thanks. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
tonylong ...winded More info | Dec 27, 2009 15:24 | #9 Doing this from one Raw file is the same in principle as using multiple exposures -- multiple exposures will have, say, one "middle" exposure where maybe highlights are too bright and shadows are too dark, then (for a three shot sequence) you would have an "underexposed" shot where the highlights have desired detail but the shadows are much too dark and an "overexposed" shot where the shadows have good detail but the highlights are blown. You put each in a separate layer in Photoshop then use masks and brush the "good" parts into one image. Tony
| Latest registered member is ANebinger 921 guests, 151 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
