Just out of curiousity, does the Vagabond II system work with Elinchrom lights? I know the Vagabond is just a battery source that I'd need to plug in a power strip to but didn't know if anybody has had problems doing that or not.
Thanks!
exodusfman800 Senior Member 649 posts Joined Jun 2009 Location: IUPUI - Indianapolis, IN More info | Dec 22, 2009 09:36 | #1 Just out of curiousity, does the Vagabond II system work with Elinchrom lights? I know the Vagabond is just a battery source that I'd need to plug in a power strip to but didn't know if anybody has had problems doing that or not. -Jon
symbolphoto Cream of the Crop 6,628 posts Likes: 18 Joined Nov 2005 Location: Boston, MA More info | Dec 22, 2009 09:49 | #2 Yep, sure is. Assuming you mean their monoblocs.
B&Wlover Member 48 posts Joined Dec 2009 More info | Dec 22, 2009 09:57 | #3 Yes and no there are issues running multi-voltage strobes like the BXri and I believe the D-lites mostly when running 2 lights off the one pack, the Innovatronix explorer SE is designed for the multivoltage strobes and would be your best bet there is a thread on here about it https://photography-on-the.net …968&highlight=explorer+se
exodusfman800 THREAD STARTER Senior Member 649 posts Joined Jun 2009 Location: IUPUI - Indianapolis, IN More info | Dec 22, 2009 12:42 | #4 B&Wlover wrote in post #9244656 Yes and no there are issues running multi-voltage strobes like the BXri and I believe the D-lites mostly when running 2 lights off the one pack, the Innovatronix explorer SE is designed for the multivoltage strobes and would be your best bet there is a thread on here about it https://photography-on-the.net …968&highlight=explorer+se I was thinking along the lines of like a RX600 -Jon
Village_Idiot GREATEST POTN MEMBER EVER 3,695 posts Likes: 18 Joined Jan 2007 Location: Durt Burg, WV More info | Dec 22, 2009 13:41 | #5 exodusfman800 wrote in post #9245605 I was thinking along the lines of like a RX600 I believe, from looking on Elinchrom's site, that the RX600 do not switch power. You have to choose which one you want when purchasing, so in theory, they should be ok to use with a vagabond. My village called. I was told that they missed me.
symbolphoto Cream of the Crop 6,628 posts Likes: 18 Joined Nov 2005 Location: Boston, MA More info | Dec 22, 2009 13:47 | #6 If you look at the video, i use both the explorer and the vagabond, powering two RX600's
B&Wlover Member 48 posts Joined Dec 2009 More info | Dec 22, 2009 16:39 | #7 Yeah no problem with the RX600's oh and great video by the way mumbles
bibowj Member 69 posts Joined Jun 2009 More info | Dec 22, 2009 21:23 | #8 I have the Rx 600... and several other Elin's and they work just fine with the V-bond2...
exodusfman800 THREAD STARTER Senior Member 649 posts Joined Jun 2009 Location: IUPUI - Indianapolis, IN More info | Dec 23, 2009 07:27 | #9 mumbles wrote in post #9245984 If you look at the video, i use both the explorer and the vagabond, powering two RX600's I did watch the video. I was just responding to B&W. Great video btw. -Jon
| Latest registered member is MWCarlsson 803 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
