wasabean wrote in post #9245021
which lens should i dedicate to which camera? right now i have the 24-70 on the 5D so i have wide to semi-zoom cover, and the 85 on my 7D to get my telephoto porition covered.
Yeah, that sounds the right way to do it when carrying both cameras as a walk around combo.
I'm puzzled by your talk of dedicating them though. That suggests that you are planning on this being a permanent arrangement. There are many times when you would be better off using one body with the other lens.
Two examples:
The FF of the 5D and the 85 are a great portrait combo. Ideal FL and all the shallow DoF you could want for subject seperation.
The 7D and 24-70 will be great for close in action work, say getting up close and underneath skateboarders on a ramp. Best AF, 8fps and reasonably wide angle for drama. In this situation, the 5D with 85 would be a great second combo for grabbing some portraits of the skateboarders.
So, yes, as a walk around pair the combination you have chosen is generally the most logical. Do consider what you will be shooting though, as sometimes they will be better off the other way around.
To simply work it out based on spread of FL is ignoring that the two cameras are very different animals and for many jobs one body is much better than the other, you then choose the best lens to put on it. There are many factors to consider when choosing which body and lens combo to use and they vary from shoot to shoot.
