Following the instructions in the manual. Options on the 580 are Master-Slave-Off. Tells me in the manual if I want to switch the master off and fire the slave, select off. But what happens is the Master fires and the 430 doesn't?
markimage Member 225 posts Joined Jul 2007 Location: Hitchin, Herts. UK More info | Dec 22, 2009 14:50 | #1 Following the instructions in the manual. Options on the 580 are Master-Slave-Off. Tells me in the manual if I want to switch the master off and fire the slave, select off. But what happens is the Master fires and the 430 doesn't? http://www.markwebb.smugmug.com/
Dec 22, 2009 14:55 | #2 Are you looking at the switch on the back or the menu settings? Jim
Dec 22, 2009 15:07 | #3 Menu settings, holding Zoom until the display flashes etc.... http://www.markwebb.smugmug.com/
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Dec 22, 2009 16:06 | #4 markimage wrote in post #9246404 Following the instructions in the manual. Options on the 580 are Master-Slave-Off. Tells me in the manual if I want to switch the master off and fire the slave, select off. But what happens is the Master fires and the 430 doesn't? What you need to do is to press the Zoom button repeatedly until the light ray icon to the left of the flash icon blinks (on the LCD screen). Then use the dial to change the blinking "on" tp "off". This will set the master so that it doesn't flash, only the slaves will. Don't press and hold the Zoom button because that will only let you switch to master mode, slave mode, or wireless mode off. ...Leo
Dec 22, 2009 16:11 | #5 Thanks very much Leo, but I cant get that http://www.markwebb.smugmug.com/
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Dec 22, 2009 16:32 | #6 You have to first go into master mode. You do this by first pressing and holding the Zoom button until something flashes on the screen. If it isn't "Master on", turn the dial until "Master on" flashes and then press the Set button in the middle of the dial. Next, press the Zoom button repeatedly until the light ray flashes as I mentioned in my previous post. ...Leo
Dec 22, 2009 17:02 | #7 Got it http://www.markwebb.smugmug.com/
Jannie Goldmember 4,936 posts Joined Jan 2008 More info | Dec 22, 2009 23:37 | #8 I couldn't make that happen but I did go into the camera menu where I was able to disable the master flash and it works perfectly, at least that's the way it is on the MKIII. Ms.Jannie
| Latest registered member is MWCarlsson 932 guests, 183 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
