Thread started 23 Dec 2009 (Wednesday) 13:38
100-400 problem?
Catcherman
Dec 23, 2009 13:38 |  #1
I was shooting the other day with my 100-400 lens and noticed what appeared to be parts of a gasket falling out of were the two tubes? Overlap. Now the push-pull zoom does not feel quite as smooth. Has anyone else had this problem and is it in need of immediate repair? It doesn't seem to effect the image quality but I don't want to do any damage if I keep using it.
Norrie
http://norriej.smugmug​.com/ (external link) 1d MKIII,40D,400 5.6,100-400,17-55 & 28-135,100 2.8 IS,iMac 27 inch quadcore i7
FlyingPhotog
Cream of the "Prop"
Dec 23, 2009 13:42 |  #2
What may have failed is the "clutch" mechanism that adjusts the zoom tension when you turn the ring.
Jay
crn3371
Dec 23, 2009 13:50 |  #3
I would think that there would be some type of gasket or seal between the two telescoping tubes. It sounds as if it has become dislodged and probably should go to Canon for a check-up.
rang
Dec 23, 2009 16:54 |  #4
If you are referring to bits of "black" flaky material being left on the inner tube as you slide it back and forth...and you are noticing that you have to tighten the compression locking ring more and more... it is indeed the "clutch assembly" and it is a Canon depot level repair. It will cost you some bucks. Had mine done a few months ago at the Irvine facility.
If this matches your symptoms...no it doesn't effect the IQ.
You should not nor have to "crank" down on the locking ring to stop the tube from sliding.
Lotsa stuff, running outta room and a wife...I keep looking at her and wondering??? :lol:
858 views & 0 likes for this thread, 4 members have posted to it.
100-400 problem?
731 guests, 117 members online
