Thread started 23 Dec 2009 (Wednesday) 14:09
7D High ISO Examples - No Noise Reduction
snyderman
Dec 23, 2009 14:09 |  #1
Figured out enough with the 7D at the 2nd game to actually get some acceptable shots. Good example of 7D with no NR at all just for example. Might run them through Neat Image to see if they can be cleaned up and sharpened a tad, but I'm not disappointed at all with them as-is.
All shots 7D, 85mm f/1.8 (@ 2.0) 1/640 and ISO 2500. Good exposures in a pretty nicely lit gym:
1. Different BG tones show noise levels at ISO 2500
IMAGE: http://i14.photobucket.com/albums/a310/dsnyder160/DPP_1524TIF.jpg
2. Good example with a lot of dark space. Shot taken from about 6 feet from player:
IMAGE: http://i14.photobucket.com/albums/a310/dsnyder160/DPP_1531TIF.jpg
3. Another example with lots of background visible to evaluate noise levels
IMAGE: http://i14.photobucket.com/albums/a310/dsnyder160/DPP_1542TIF.jpg
Still not getting good focus/tracking with the camera yet. Maybe I'll figure that out over the holidays.
Thanks for looking.
dave
Canon 5D2 > 35L-85L-135L
adrian5127
Dec 23, 2009 14:19 |  #2
iso definitely looks better than the 40D which I am considering upgrading from
Adrian
SE UK Thread here***Kit***smugmug (external link)
Wedding photography kent (external link)
Wedding photographer kent (external link)
snyderman
Dec 23, 2009 14:21 |  #3
adrian5127 wrote in post #9252560 (external link)
Upgraded from a 50D to the 7D. Not completely comfortable with the 7D yet, by any means, but for the 2nd time out with the camera, the results are pretty good.
dave
adrian5127
Dec 23, 2009 14:22 |  #4
Is the focus etc very difficult to get to grips with?
Adrian
snyderman
Dec 23, 2009 14:28 |  #5
adrian5127 wrote in post #9252577 (external link)
I'm going to say yes, regardless of what anyone else says. Granted, I'm not the smartest person on the planet, but tracking players with the camera and convincing the lens to keep focusing is not working. It seems I have to keep 'bumping' the shutter button to keep the focus going. Something's not right with my setup, obviously.
Clearly, I had the red square (as indicated in DPP) on the numbers and got focus on the player BEHIND the focus in a number of shots.
The same 85mm f/1.8 lens had absolutely no difficulty tracking and keeping focus where aimed using the 50D.
For now, I'm still chalking this shortcoming up to USER-ERROR. Not blaming the camera because it's truly supposed to be more capable in this regard than any xxD model. I'll keep working on it and hopefully will stumble upon the correct focus mode for shooting basketball.
dave
cstewart
Dec 23, 2009 15:54 |  #6
snyderman wrote in post #9252621 (external link)
I'm going to say yes, regardless of what anyone else says. Granted, I'm not the smartest person on the planet, but tracking players with the camera and convincing the lens to keep focusing is not working. It seems I have to keep 'bumping' the shutter button to keep the focus going. Something's not right with my setup, obviously...
dave
Assume you are using AI Servo Mode (which requires shutter to be always half or fully pressed to keep working and are using the center point...but also try moving the focus function off of the shutter button and on to the * button on the back of the camera and you may get better results. It is a Custom Function (IV I believe) and has many benefits when shooting sports, including the ability to separate focus from exposure lock, an ability to prefocus on an area or player and stay there (works well for hockey goalies who constantly have players cutting in front of them and would disrupt focus in standard AI servo using shutter) . Or you can keep button depressed to engage and hold tracking in AI Servo and then bang off a frame as needed. It is a little bit to get used to but once you get it you will likley not go back. For benefits search here for Custom Fn. IV or "* button for focus" or similar"
Please Check Out My Work at:
Independent Sports News (external link) -- Sports Shooter (external link) --Web Site (external link) -- Facebook (external link) -- iStockphoto.com (external link)--Twitter (external link)
Gear: 1DX; 1D4; 70D gripped; 40D gripped; ; EFS10-22; EFS 17-55; EF 16-35; EF 135; EF 70-200 II; EF 300; EF 1.4X II Extender, 580 EX II Flash
snyderman
Dec 23, 2009 17:17 |  #7
cstewart wrote in post #9253029 (external link)
Yes to AI Servo and I believe the camera focus is set to the (*) button. For some reason, the * works fine, but focus doesn't appear to be tracking while mashing down on * button. When I press shutter 1/2 way down, it does, though.
As mentioned, I'm pretty sure all my ills are self-imposed, so more reading and trial and error will likely solve the issues.
thanks for the tip. And I'll double check the Fn IV area in the menu.
dave
packpe89
Dec 23, 2009 21:27 |  #8
I had no problems, tried the 7d with both the 85/1.8 and 70-200/2.8 IS with very good results. AF is very good and ISO is much better than the 40D.
Canon 5D, 7D, 100-300F4, 200f2.8L, 17-40L, 50f1.4, 85f1.8, 15-85EF-S , Sigma 24-70f2.8, A couple of flashes, strobes and stuff.
ChrisK10
Dec 24, 2009 01:32 |  #9
I have shot 8 games with my 7D and a 70-200 f/2.8. I have tried center point focus as well as different zone focus modes. I have had great success with the AF tracking and seem to get slightly better pics with the center zone focus.
7D gripped / Rebel XS / 70-200 f/2.8 L IS / 50mm f/1.4 / and some other stuff
snyderman
Dec 24, 2009 16:40 |  #10
ChrisK10 wrote in post #9255598 (external link)
Chris,
just for clarification, do you mean the middle GROUP of focus points with the ( ) around them? If this is what you mean, I hadn't thought of it. Let me know for sure so I can give that a try.
dave
ChrisK10
Dec 25, 2009 01:50 |  #11
Dave
yes that is exactly what I have been using and it seems to work for me. I hope it works for you as well.
bharm24
Dec 25, 2009 13:44 |  #12
I rented a 7D to shoot the City of Palms HS basket tournament this past week. Comparing this to my 30d and 40d on noise levels and tracking focus, the 7D is a pure joy to use. After a day of practice, I was able to get some of the best action shots I have ever taken. Noise levels are great, althought dosen't touch 5D2. Can't wait to buy. 30D and 40D both for sale soon. Will post a few shots when time permits.
brian h
5D Mk II,BG-E6 30d, 40d, 24-105L 4.0 is , 70-200 2.8 is, 85mm 1.8 , sigma 50mm 2.8 macro, 580 speedlite II, EF1.4X Ext, AB 800x2. Cypersync, 7d
ChasWG
Dec 26, 2009 14:54 |  #13
Why did I read this thread???!!!!!
Damn you snyderman!! Damn all of you who own the 7D!!!!
I need to go and talk to my wife now, this won't be good...
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
snyderman
Dec 26, 2009 17:44 |  #14
ChrisK10 wrote in post #9260432 (external link)
Dave
Thanks Chris. Definitely give that a shot next game.
dave
snyderman
Dec 26, 2009 17:46 |  #15
bharm24 wrote in post #9262001 (external link)
Brian:
I'm REALLY impressed with the lack of noise. Shooting in the same gyms this year as last and relied heavily on Neat Image with both a 30 and 50D which I swapped up to during basketball season last year.
No comparison of the xxD bodies and the 7D. I've seen some say it's like 1 stop better, (whatever that means) but to my eyes the difference in noise with the 7D was worth every penny of the purchase!
dave
7,204 views & 0 likes for this thread, 9 members have posted to it.
2875 guests, 163 members online
