FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 23 Dec 2009 (Wednesday) 18:43
macro flash
Ross ­ Workman
Dec 23, 2009 18:43 |  #1
Greetings and Merry Christmas to All on the Macro Forum.
I apologize if this question is out of line here, but considering that it refers specifically to macro, I thought I'd pose this question here.
I've been wanting to seriously get into macro for some time, and I have purchased a Canon 100mm f/2.8 macro.
Now comes the time to buy a flash. I would like some input as to which flash I should purchase; the Canon 14EX, Canon 24EX, or the Sigma EM 140 DG?
Currently, I am using a 30D, but plan to pick up a 5D in a couple of months.
I appreciate the input!
Ross
LordV
Dec 23, 2009 23:57 |  #2
I'd either go for the MT-24 or just get a normal flash gun like the 430Ex and mount it on a bracket. The fixed head type macro flashes are rather difficult to diffuse satisfactorily.
I'm still using the latter.
Brian v.
Macro Hints and tips
racketman
Gallery: 16 photos
Dec 24, 2009 05:47 |  #3
MT-24 is more useful for MP-E65 at higher mag, 430ex will do nicely with 100mm
Toby
Canon 5D MKIV & 90D
Olympus EM-1 MKII
Flickr collections (external link)
Gear
2much2carry
Dec 24, 2009 13:18 |  #4
I have several 580's and the MT-24. The MT-24 has the advantage of having two flash heads whose output can be set differentially. I use the 580's mostly with my 180mm lens.
Ross ­ Workman
Dec 24, 2009 14:37 |  #5
LordV wrote in post #9255287 (external link)
....<snip>or just get a normal flash gun like the 430Ex and mount it on a bracket....
Brian v.
Brian, which bracket would you suggest that I use? As you can see in my signature, I already have the 430....
Thanks for your input.
Ross
themadman
Dec 24, 2009 17:08 |  #6
I am also interested in how to mount the flash off camera, what is your setup Brian?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
racketman
Gallery: 16 photos
Dec 24, 2009 17:28 |  #7
Brian has photos of his set up here:
Equipment & Test Pictures (external link)
a quote
'fraid the brackets are a bit DIY- nearest thing is a Hakuba LH-1 ballhead, but it's worth replacing the ballhead on it with another one with just a 1/4" bolt connection so you go into the base of the flash cord instead of relying on the flanges.'
Toby
Canon 5D MKIV & 90D
Olympus EM-1 MKII
Gear
LordV
Dec 24, 2009 23:53 |  #8
Think Toby's covered it :)
Brian v.
Crypto
Dec 26, 2009 07:14 |  #9
Don't be affraid to attach it directly. I've had great results with a 430 mounted directly on the camera with a Lumiquest Soft box.
TCProimages (external link)
Canon 5DII
Canon 40D
Canon 100-400L, Canon 24-70L, Canon MP65 macro,Canon 100L Macro
1,618 views & 0 likes for this thread
macro flash
Latest registered member is KellyLaundromat
303 guests, 139 members online
