Thread started 24 Dec 2009 (Thursday) 06:53
MACRO PHOTOGRAPHY - Sigma Lens + Canon Flash
Jack ­ McEntire
Dec 24, 2009 06:53 |  #1
Hi all,
I'm hoping to buy the Sigma 50mm f/2.8 EX DG Macro lens alongside the Canon Macro Twin Lite MT-24EX Flash over the next couple of weeks, and I'm wondering whether people believe that this is a good choice of equipment for macro work or not. I mean, first of all, are the lens and the flash compatible, i.e. will the flash lock on to the lens even if it's not Canon? Secondly, is Sigma's 50mm f/2.8 EX DG Macro lens a good lens? What is it about the 70mm and the 105mm lenses that makes them worth so much more?
Any help would be much appreciated!
Many thanks,
Jack McEntire
dpds68
Dec 24, 2009 06:58 |  #2
What are you wanting to photograph if it's Bugs a 50mm might be too short you will have to get really close and the bug will fly away .
Also you should not post the same thing in multiple threads .
The flash and Lens will work together if the flash unit is one that screws into the Lens just make sure that they have the same thread size .
David
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
CountryBoy
"Tired of Goldmember label"
Dec 24, 2009 07:02 |  #3
The Sigma 50mm 2.8 is a good lens , but to get 1:1 you are going to be very close to the subject. I mean real close , the lens hood will be almost touching the subjct ! So it depends on what your shooting . It's not all that great for bugs , that's where the 150mm macro comes into play. It has more working space then the 50mm.
Someone else will have to answer about the flash.
Hi
push ­ pins
Dec 24, 2009 09:02 |  #4
Yeah, i got both the 50 and 150mm, and you have to get very close with the 50mm.. I also owned the 105mm, which is good as well, but the AF is way better on both the 50 and the 150..
My stuff at flickr.. (external link)
TSY87
Joined Sep 2009
Dec 24, 2009 09:25 |  #5
why not get the canon 100 2.8 non L? that is a fantastic lens (sometimes i wonder if i made the right choice by selling it and keeping the 100L)
i would get it, and skip the macro flash. you can make your own flash modifiers that will help and be cheaper.
D700 Gripped, Nikkor 20 2.8D, Sigma 50 1.4, Rokinon 85 1.4, Nikkor 105 2.8 Micro VR, Nikkor 70-200 2.8 VR2, SB-900
Myflickr (external link)
Canon ­ Bob
Dec 24, 2009 09:29 as a reply to  @ push pins's post |  #6
Jack,
The Sigma 50mm has a 55mm filter thread. To mount the MT-24, you'll need a Canon Macrolite adapter and the nearest size is 58mm. This will be fine if you grab a 55-58mm adapter ring.
Not wishing to sway your choice of FL too much but I think you'd be better (as stated above) going for the 90-100-105 focal length options available.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
artyH
Dec 24, 2009 09:34 |  #7
I have the 50f2.8 and it is a very sharp lens. At 1:1 it is about 1 1/2" from the object you are shooting.
It works great and is useful under a wide variety of situations. If you want to photograph things like bugs, you might want a longer lens. It should be fine for flowers.
The Sigma 70 is a very sharp lens according to reviews, but you may have a problem adapting it to the flash. The Sigma 105 is also sharp. The difference between most of the macros is focal length and working distance. I wanted the shorter focal length so that I could copy artwork for my wife.
Tony-S
Dec 24, 2009 11:17 |  #8
Jack McEntire wrote in post #9256247 (external link)
Do you need this flash? Is there a reason why you're not considering the Sigma macro flash? Or even a macro bracket, E-TTL cable and shoe-mount flash? You could save a bit of money towards a better FL lens, including the 150mm Sigma.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Jack ­ McEntire
Dec 24, 2009 14:22 |  #9
Thank you all for your advice! :D
After reading all your comments I decided to reconsider, and I've now decided upon the Sigma Macro Ring Flash and either the Sigma 150mm f/2.8 EX IF HSM or the Sigma 180mm f/3.5 EX DG HSM.
I can get the flash for £165.99 and either one of the lenses for between £400 and £500.
Which of the two lenses would be best?
I forgot to mention earlier that I intend to shoot a lot of insect portraits, so by the sound of it the 50mm would have been of little use!
CountryBoy
Dec 24, 2009 14:34 |  #10
Canon Bob wrote in post #9256769 (external link)
Jack,
Bob
Actually, you can screw a 72mm filter into the front of the lens hood on the Sigma 50mm macro.
I bought a screw in lens cap for mine, it's easier then the snap in type for this lens.
Hi
Silverfox1
Dec 24, 2009 14:35 as a reply to  @ Tony-S's post |  #11
As an alternative have you considered the Canon 60mm f2.8 macro ?
Since the Canon 60mm macro lens does not extend it can be used with the onboard flash even at 1:1 without casting a shadow on your subject.
Working distance is 3.5"
It cost about $100.00 more then the Sigma but has true USM and is a very sharp lens just like the Sigma.
http://www.amazon.com …ics&qid=1261686​769&sr=8-1 (external link)
http://www.slrgear.com …ct.php/product/​138/cat/10 (external link)
Regards & Merry Christmas ! :D
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
Tony-S
Dec 24, 2009 14:37 |  #12
Jack McEntire wrote in post #9258133 (external link)
This is the setup I have and it works great.
Silverfox1 wrote in post #9258172 (external link)
Really too short of FL for arachnid work.
CountryBoy
Dec 24, 2009 14:39 |  #13
I like the 150mm 2.8. it handles a 1.4 converter very well also. It's not bad with the 2x converter either, as long as you use manual focus.
Hi
themadman
Dec 24, 2009 14:57 |  #14
Spend more money on the lens, spend less money on speicalized flashes! Just get a softbox for your current flash, get a off camera cord and get taken!
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Jack ­ McEntire
Dec 24, 2009 15:26 |  #15
I don't have an external flash I'm afraid, this will be the first. Surely it's worth it? £165 doesn't sound bad to me. :)
2,126 views & 0 likes for this thread, 10 members have posted to it.
1593 guests, 137 members online
