I have an image that was cropped at 3792 x 2592. I'd like to order prints, but I was wondering what size to order without distorting the image in any way. Thanks in advance.
Mike787 Member 222 posts Joined Dec 2009 More info | Dec 24, 2009 11:00 | #1 I have an image that was cropped at 3792 x 2592. I'd like to order prints, but I was wondering what size to order without distorting the image in any way. Thanks in advance. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
rx7speed Goldmember 1,204 posts Joined Jun 2008 More info | Dec 24, 2009 11:44 | #2 better question would be how big are you looking to go with your prints? digital: 7d 70-200L 2.8 IS MKII, 17-55 2.8 IS
JeffreyG "my bits and pieces are all hard" More info | Dec 24, 2009 12:20 | #3 11x14 is a straight forward print with no screwing around beyond size appropriate sharpening. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Dec 24, 2009 12:28 | #4 Are you asking about size ratio? You have a 1:1.46 size ratio, which the closest semi-standard print size I can think of would be 13x19. It should be easy to crop to any of the multiples of 4x6 or 5x7, though. Taylor
Dec 24, 2009 13:48 | #5 Ok, this is my first print so if someone can link me to a tutorial that explains cropping / resizing for prints that would be great. I'd like to get as big a print as possible without losing quality, so what would you guys recommend from a 10.1 MP shot from a Rebel XS at the resolution I specified? Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Dec 24, 2009 14:01 | #6 300 pixels per inch is kind of the default standard for printing, and I've had good results down to 200 ppi. At 200 ppi you'd end up at 19x13. 300 ppi would get you somewhere around 8x12, 9x13. Here's a link to the printing faq's page
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Dec 24, 2009 14:17 | #7 Mike787 wrote in post #9257989 Ok, this is my first print so if someone can link me to a tutorial that explains cropping / resizing for prints that would be great. I'd like to get as big a print as possible without losing quality, so what would you guys recommend from a 10.1 MP shot from a Rebel XS at the resolution I specified? You could get an excellent 12x18 or 13x19 and a good 20x30. 300DPI is ideal, but also less critical for large prints. You won't be looking at a 20" print from 1 foot away like you would a 4x6. Taylor
Dec 24, 2009 14:42 | #8 tkbslc wrote in post #9258108 You could get an excellent 12x18 or 13x19 and a good 20x30. 300DPI is ideal, but also less critical for large prints. You won't be looking at a 20" print from 1 foot away like you would a 4x6. This is exactly what I wanted to add SONY A7RIII | SONY A7III | SONY RX10 IV | SONY RX100 | 24-70 2.8 GM | 70-200 2.8 GM | 16-35 F/4 | PZ 18-105 F/4 | FE 85 1.8 | FE 28-70 | SIGMA 35 1.4 ART | SIGMA 150-600 C | ROKINON 14 2.8
Dec 24, 2009 16:23 | #9 I have made 12x18 prints at 300 ppi with an xt and they look fine.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Dec 24, 2009 16:47 | #10 cccc wrote in post #9258603 I have made 12x18 prints at 300 ppi with an xt and they look fine. Hell, I've made XT 20x30's at 200 dpi on a Durst Lambda that would blow your socks off. Elie / אלי
Dec 24, 2009 19:28 | #11 Ok because i've been directed to this link http://www.design215.com/toolbox/megapixels.php Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Dec 24, 2009 23:38 | #12 Mike787 wrote in post #9259293 Ok because i've been directed to this link http://www.design215.com/toolbox/megapixels.php That a 300DPI chart. Taylor
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | Dec 24, 2009 23:44 | #13 Mike787 wrote in post #9257989 Ok, this is my first print so if someone can link me to a tutorial that explains cropping / resizing for prints that would be great. There's no need for a tutorial. Just take a look at the print sizes available at the lab you're going to get your print at. Usually the ratios are 4:5 or 3:2 or 4:3 and others like 5x7 or 11x14. Either you crop to that aspect ratio or you make a nonstandard print with borders. Printing to a standard size is simple and straightforward. If you want a nonstandard ratio, you'll need to change the size of the canvas, which is a little less simple.
katodog Goldmember More info | Dec 25, 2009 00:17 | #14 The Canon 40D shooting large JPG, will give you a print 54"x36". I've printed these sizes numerous times and have never seen any image degradation. The Canon 20D will shoot large JPG around 48"x32".
Figure out what the ppi is of your image, and then divide the pixel dimensions by the ppi, that will give you your physical dimensions, and that's the largest you can print without losing image quality. The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Dec 25, 2009 11:11 | #15 Figure out what the ppi is of your image, and then divide the pixel dimensions by the ppi, that will give you your physical dimensions, and that's the largest you can print without losing image quality. Ppi is easily changed. It is a function of print size and pixel dimensions, not the opposite. As long as it doesn't drop below 180 you're golden and if it does a good uprezzing will put you back in business Elie / אלי
| Latest registered member is ANebinger 919 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
