Thread started 24 Dec 2009 (Thursday) 14:20
monopod
cruso
Dec 24, 2009 14:20 |  #1
hi can any one recommend a monopod . And will i need a head. for 40d 100-400 lens
Canon 7d2Canon Eos 7d 500f4 is 300f2.8 24-105 IS 100-is macro 580ex11
c2thew
Dec 24, 2009 14:41 |  #2
manfrotto monopods in my opinion have the best bang for the buck in stability and ease of use.
carbon monopods = overpriced and do the same job
cheap aluminum monopods = waste of money and you get what you pay for.
Flickr (external link) |Gear|The-Digital-Picture (external link)|The $6 mic | MAGIC LANTERN (external link) | Welding Filter
Go Support Magic Lantern 2.3!!
JohnJ80
Dec 24, 2009 14:46 |  #3
cruso wrote in post #9258119 (external link)
Why do you need a head?
I'd look at the monopod offerings from Gitzo and Feisol.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
ed ­ rader
"I am not the final word"
Dec 24, 2009 15:12 |  #4
i've owned gitzo, manfrotto and benro monopods. my favorite monopod for my current equipment is the benro MC-66 (owned it twice) with manfrotto tilt head and RRS flip lever release.
the monopod is 5-section and weighs under a pound without head and collapses to 16.25" without the head.
i use this set-up with 1d mark III and 100-400L . i've taken the benro to africa on safari and to katmai np to shoot brown bears.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Lowner
"I'm the original idiot"
Dec 24, 2009 15:19 |  #5
Whether you need a head and indeed what sort of head very much depends on what you intend to use it for.
I shoot motorsports with mine and need a fully functioning ball head and QR clamp so that I can plant the monopod foot between my feet and pan with the subject. I have read that others manage without heads, or simple tilt heads for other photography. If you do get a ballhead it need not be as expensive as a head for a tripod. I use a basic Manfrotto 486 with a Markins QR-60 clamp on mine.
Richard
cruso
Dec 25, 2009 03:10 as a reply to  @ Lowner's post |  #6
i am doing wildlife and birds at a moment I am thinking a carbon fiber so it is light for taking on Holiday but dont know what head would be the best?
Lowner
Dec 25, 2009 06:18 |  #7
Cruso,
Try it without and see how you get on. That will help you decide how much movement you need if indeed you need one at all. Tilt heads only operate vertically, while a ball has the full range of movement.
Richard
Mark ­ Theriot
Joined Sep 2009
Dec 25, 2009 07:54 |  #8
I've had Gitzo's that cost twice as much but I'll take the Induro every time!
http://www.bhphotovide​o.com …ails&Q=&sku=655​319&is=REG (external link)
For ground level and panning (like drag racing) I could get by without a head but I prefer a simple monopod ball head. I use the ball head loose and wrap my free hand around it for stabilization - works for me!
Mark
Equipment: 800L, 400 DO, 70-300L, 24-105L
My Place: Soaring Art (external link)
Soaring Art on Facebook (external link)
jhom
Dec 25, 2009 09:16 |  #9
The Manfrotto 680 is a very good and inexpensive monopod. If you want cf then Gitzo has several excellent monopods.
Jim
PacAce
Joined Feb 2003
Dec 25, 2009 10:27 |  #10
For shooting birds especially in flight, yes, you'll need a head. I'd recommend one of the following (both require the use of an Arca-Swiss compatible QR system):
RRS Hi-Capacity monopod head:
http://reallyrightstuf​f.com …ic=MH%2D01%2D40​LR&eq=&Tp= (external link)
Wimberley Head II (good for big lenses but might be overkill for the 100-400):
http://tripodhead.com/​products/wimberley-main.cfm (external link)
Manfrotto has the 234 swivel/tilt head which has a load capacity of only 5.5 pounds. But it's probably OK for the 100-400 lens. One version comes with an RC2 QR plate and clamp and the other version has a screw so you can mount your own clamp to it.
...Leo
Jon
Joined Jun 2004
Dec 25, 2009 13:03 |  #11
I'll second Leo on the RRS or Wimberley heads. I use the RRS monopod head on mine with lenses up to the 300 2.8 + stacked TCs. I had a Manfrotto swivel-tilt (non RC2 model) with A-S clamp attached and it just wouldn't stay solidly in position no matter how I tightened it down, even with the 100-400. But if you use an RC2 QR, it'll probably be OK.
Jon
Cocker Spaniels
wicker_man
Dec 25, 2009 13:34 |  #12
A friend has a Manfrotto 680B monopod which he uses with a gripped D90 + Sigma 70-200mm f2.8, and he recommends it. It seems very solid, and available for around £40 in the UK.
Canon EOS 5D + 40D, Panasonic LX1
Canon 16-35mm f2.8L / Canon 24-70mm f2.8L / Sigma 70-200mm f2.8 / Canon 50mm f1.8 II / Zenitar 16mm f2.8 Fisheye / Cosina 100mm f3.5 Macro
My Website (external link) // My Flickr (external link)
ben_r_
-POTN's Three legged Support-
Dec 25, 2009 17:01 |  #13
I have owned a Bogen/Manfrotto 680B and a Gitzo GM2541 and a few heads and if youre going cheap, I think the 680B with a bogen ball head is good, if you wanna go top notch, check out my review here: LINK
cruso
Dec 26, 2009 02:56 as a reply to  @ ben_r_'s post |  #14
thanks a lot every one. that as given me a lot to think about their is a lot more choices than i thought their is some really top notch rigs i will search around and see what i can get hold of in the UK that fits my pocket i dont want to go cheap though
DeaconG
Dec 26, 2009 11:58 |  #15
I'm currently using the Manfrotto 685B Neotec with a 486RC2 head...doesn't collapse as short as the others, but I've gotten the one hand trigger trick down. Works very well with my Bigmos.
More food fer thought...are you stuffed yet?:lol:
Gripped 5D Mark II & 50D|70-200 2.8 IS L|24-105 L|17-55|10-22|28 1.8|Σ 150-500|Σ 120-300 EX DG|Σ 50 1.4 EX|Σ APO 2X TC|580EXII|various other bits and pieces
"Reality holds surprises for everyone!" King Solovar, Crisis On Infinite Earths
4,107 views & 0 likes for this thread, 12 members have posted to it.
monopod
911 guests, 120 members online
