Thread started 25 Dec 2009 (Friday) 16:26
Is this a good tripod?
AprilArchambeau
Dec 25, 2009 16:26 |  #1
Platinum Plus 7500tm. It is a tripod and monopod in one. My husband got that for me for Christmas along with the 100mm macro, I plan on getting a 100-400l lens in the spring so I need something to support it. I know tripods are important so I wanted opinions on it. It seems stable but may be junk, all input appreciated :)
www.AprilArchambeauPho​tography.com (external link)
5D l Calumet Genesis 400 light kit (2) l 430EX II l 50mm 1.8 l 70-200 f/4L IS l 85mm 1.8 coming soon!
number ­ six
fully entitled to be jealous
Dec 26, 2009 15:26 |  #2
22 hours and no answer? I guess you get to review it for us, then. ;)
Is it stable and rigid? Does the pan/tilt head lock without movement? Are the leg locks solid?
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
JeffreyG
Gallery: 42 photos
Dec 26, 2009 16:30 |  #3
AprilArchambeau wrote in post #9262442 (external link)
What do you plan to use it for?
The two things that I don't like about this tripod looking at it online (I've never so much as touched one):
1. The legs are tied together. This is common for video camera tripods that are going to be used inside. If you plan to use this tripod outside on potentially uneven ground you will soon be cursing having the legs tied together.
This design also means by default that you cannot get the camera close to the ground. Consider it an eye level tripod only, not suitable for macro.
All in all, this type of tripod is OK for portraits and group photos, not so much for landscapes and macro.
2. The head is pan and tilt. While video shooters like pan and tilt, most still photographers find it needlessly fussy to use to get the camera aimed, and the ability to smoothly pan a shot is pretty useless for a still.
MrWho
Dec 26, 2009 19:29 |  #4
I got it as a gift and it's been great so far. Everything's fluid, all locks are firm, everything rotates without issue and it's been very easy to use. No complaints so far :)
Gear
20droger
Dec 26, 2009 19:39 as a reply to  @ MrWho's post |  #5
Look here: http://www.photography​review.com …k/PRD_392083_58​11crx.aspx (external link)
If that's your tripod, it sould do just fine for your purposes.
AprilArchambeau
Dec 26, 2009 20:27 |  #6
Yea, I am going to be using it outside for macro sometimes though, so I am wondering if I should return it and get something better
MrWho
Dec 26, 2009 21:17 |  #7
It should be fine for normal use.
Gear
LowSpark420
Dec 26, 2009 23:10 |  #8
I have this exact tripod. It is fine, my only complaint is the thing is pretty heavy. I would hate to have to lug it around if I wanted to take it on a trip where I had to carry it a long way...
http://codphotography.​blogspot.com/ (external link)
Canon EOS Rebel XSi ~ Canon EF-S 18-55mm IS ~ Canon EF-S 55mm - 250mm f/4-5.6 IS ~ Canon EF 50mm f/1.8II ~ Canon 430 EXII Flash ~ Canon Off-Shoe Flash Cable ~ Kenko Extension Tubes (Full Set) ~ Delta Flash Bracket ~ Lowepro Flipside 400AW
tfd888
Dec 27, 2009 02:19 |  #9
JeffreyG wrote in post #9266752 (external link)
......2. The head is pan and tilt. While video shooters like pan and tilt, most still photographers find it needlessly fussy to use to get the camera aimed, and the ability to smoothly pan a shot is pretty useless for a still.
I would find the ability to smoothly pan a shot for sports shooting quite handy ;). As you said, depends what you're using it for.
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website (external link) - My Blog (external link)
- My Flickr (external link)
AprilArchambeau
Dec 28, 2009 14:12 |  #10
Ok so I returned the tripod and called Adorama about some cameras. He said he has this tripod and its good, considering buying it, its a slik 330dx and is $100, figured it would be better than the above that I previously had?
http://www.adorama.com …tml?searchinfo=​slik+330dx (external link)
1,291 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
2729 guests, 149 members online
