I don't know what I'm missing but whenever i click SAVE AS in Photoshop CS4, there is no choice of DNG in the file format.
Please help......
cyrillo07 Member 66 posts Joined May 2007 More info | Dec 25, 2009 19:19 | #1 I don't know what I'm missing but whenever i click SAVE AS in Photoshop CS4, there is no choice of DNG in the file format.
tonylong ...winded More info | Dec 25, 2009 19:58 | #2 cyrillo07 wrote in post #9262987 I don't know what I'm missing but whenever i click SAVE AS in Photoshop CS4, there is no choice of DNG in the file format. Please help...... You convert to DNG from Camera Raw -- open the file in ACR and if you click Save Image "Digital Negative" is in the file type drop-down list. Tony
Tony, is the "Digital Negative" in the drop down in format selection? I cannot find it. It has only PNG. Is it the same?
tonylong ...winded More info | Dec 25, 2009 20:26 | #4 I should appear in the Format list in ACR -- you should see Digital Negative, jpeg, tiff and Photoshop. Make sure you are seeing the whole list (scroll up or down if need be). If you don't see it, something's amiss. Tony
I'm confused Tony, does it mean I need ACR software to convert to DNG and proceed to CS4? So my workflow is LR to ACR to CS4? Or the ACR that you are talking is the CS4?
tonylong ...winded More info | Dec 25, 2009 20:46 | #6 If it were me and I had a reason to convert to DNG, I'd use LR since LR does all my image managing and the great majority of my editing. Tony
Thanks Tony, ok I saw DNG in Bridge. But I might go with your suggestion to use LR in converting DNG because its a little bit confusing for me to open a file in Bridge and Photoshop CS4.
tonylong ...winded More info | Dec 25, 2009 21:26 | #8 Well, you have a few approaches -- it all depends on your preferred workflow. But, yes, if you save a project in Photoshop, you will create another file of typically a fair size. The alternative is to save as a jpeg, which will flatten all layers and compress the image. A lot of us only do that for a specific output, such as the Web or email or to take to an outside printer. Tony
Yes Tony those are "project files". I'm been shooting for few years in raw and only until lately of considering of converting these files into large prints. I have only started in studying photoshop, oneone and nik softwares. And yes, there are some layers so im considering of archiving it in 3 formats (with layers, flattened and web format).
tonylong ...winded More info | Dec 25, 2009 21:53 | #10 cyrillo07 wrote in post #9263553 In regards with if I really need to convert it in DNG, it seems like its the best file format in archiving as of these days, is these true? Each person has their preference in regards to DNG. Some people convert everything to DNG, archive both the cr2 and the DNG files, and then use one or the other for their working library. I personally don't convert to DNG -- I figure that if my CR2 files are ever in danger of becoming obsolet, I'll have more than enough time to do conversions. In the meantime, CR2 is supported by more applications than DNG is, so I'm happy using the CR2 files as my library format as well as my backup format. Tony
Tony, thanks a lot. Your suggestions and opinions are so valuable and helps me a lot.
tonylong ...winded More info | Dec 25, 2009 22:29 | #12 Happy Holidays back at 'ya, and hope the new year brings all the answers to our most important questions Tony
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Dec 27, 2009 02:47 | #13 Just a note, AFAIK you can only create a DNG file file when you're in ACR or similar software. Once you get an image into Photoshop the RAW data isn't available so there's no way/need/logic to creating a DNG. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is ANebinger 1149 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
