Thread started 18 Feb 2003 (Tuesday) 06:22
Flash exposure problem with off-camera studio flash
SkipD
Joined Dec 2002
Feb 18, 2003 06:22 |  #1
Has anybody else experimented with studio style off-camera flash and the G2? I've noticed that proper exposure settings don't agree with my flash meter, a Sekonic L-358 .
When shooting either of my film cameras using the same flash units (a couple of Alien Bees for main and fill and a different type above the subject), the proper exposure settings match my what my flash meter says quite closely. I proved this by taking an experimental series of exposures with one of my Nikon F's and a Pentax PZ-10.
However - when I use the G2, I need to stop it down by about two stops below (larger F-stop number) what the flash meter says. I get great exposures, it's just that the camera doesn't like the meter readings.
Anybody have any ideas?
Skip Douglas
HJ ­ Seeley
Joined Jan 2003
Feb 18, 2003 07:48 |  #2
Yep, I agree with you. The small digital cameras do not correlate with "standard" flash metering. Plus it's really easy to get hyper real colors that are not exactly blown out, but still incredibly bright. Thankfully you can just review the image for exposure correction.
I do the same as you, meter, stop down 1, test, adjust flash output, test again, repeat. With studio strobes in particular, I figure that the Canon ISO of 50 is roughly equal to a film ISO of 160.
This can be a real problem. My main two strobes are 640w/s heads, I like to work with the lights very close to the subject. But even at minimum power, it's still too much for a measley F8 on the G2. So I ended up getting a basic 160w/s strobe head, and that works much better (using either a 2x3' softbox or a 9"x36" strip).
D-SLR's do not have this same problem at all. There's a world of difference.
SkipD
Joined Dec 2002
Feb 18, 2003 17:13 |  #3
My Alien Bees strobes are 320w/s, and since I'm doing a lot of tabletop work, I also see that I can't stop down enough with the camera. The strobes have a 5-stop turndown, which is quite handy.
My solution is to either turn down the strobes (but then sometimes the balance to my full/half-power-only overhead strobe goes wacky) or to use ND filters. I got a full set to play with. My polarizing filter also works pretty well as a ND.
Skip Douglas
jmhobbs
Joined Dec 2002
Feb 20, 2003 16:19 |  #4
I'm not alone!!!!!
I think my G2 is off by more than 1 stop, though. I've used my meter with 4 other cameras (2 film, 2 D-SLR) with no problem. The G2 is way off. I just did a test the other day. Meter said 1/125 @ F2.8. Set the camera to that, fired a shot. "Whoa, that's overexposed!" After trial and error I wound up somewhere around 1/500 @ F8.
I don't trust the LCD completely either, so trial and error means flipping back and forth between shooting mode and viewing mode to check histograms. I need to do some more testing to figure out the "actual" ISO, so I can just adjust my meter's ISO setting and be done with it.
On the up-side, I shot over 200 frames the past 2 days and it didn't cost me a penny :)
SkipD
Joined Dec 2002
Feb 20, 2003 16:51 |  #5
My experimentation shows about a 2-stop difference between my flash meter and the required settings on the G2 to achieve good exposures with my studio flash rig. It's as if the G2, when set to ISO-50, is close to ISO-200. This is apparently only true with external flash, as the conventional light readings seem to be close. I too need to do some more experimentation.
I am going to get a lot of use out of the neutral density filters I bought to use with my G2 (and they fit my Pentax as well - 58mm threads).
Skip Douglas
jmhobbs
Joined Dec 2002
Feb 22, 2003 20:35 |  #6
2 stops sounds pretty accurate.
The ND filter idea is brilliantly simple. Great idea. Thanks guys.
Jon
4,593 views & 0 likes for this thread, 3 members have posted to it.
1543 guests, 135 members online
