Thread started 26 Dec 2009 (Saturday) 11:24
Can't find EasyPhoto Pro plugin in CS4 after Pixma Pro 9500 II install
sdipirro
Dec 26, 2009 11:24 |  #1
This is going to sound lame, but I'm running CS4 on my PC and just installed the Canon Pixma Pro 9500 Mark II on the machine. After everything seemed to be installed correctly (including the EasyPhoto Pro plugin), I opened CS4 and a test image. I went to the Help screen and menu item for plugins, and there it is, the EasyPhoto Pro plugin. So then I went through every CS4 menu and the entire print process twice for some test pictures and can't find the EasyPhoto plugin anywhere. I know what it's supposed to look like because I've been running the old standalone version on my PC to sometimes use to print on my i9900. I'm running 32-bit XP on this machine too. So I know it's not the 32-bit/64-bit issue. I'm just missing something basic. Can anyone tell me WHERE I'm supposed to see the plugin show up? Thanks.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
paavor
Dec 27, 2009 04:59 |  #2
sdipirro wrote in post #9265589 (external link)
It's under File menu. :)
File
-- Automate
---- Canon Easy PhotoPrint Pro
Or at least that's where it is in my system (Pixma Pro 9000 Mk II).
Paavo Rissanen
Gear list | Website (external link) (in Finnish)
sdipirro
Dec 27, 2009 18:24 |  #3
Thanks. And it was so obvious too!
1,616 views & 0 likes for this thread, 2 members have posted to it.
1698 guests, 139 members online
