Thread started 26 Dec 2009 (Saturday) 13:58
Sigma Ring Flash vs. Canon
Jack ­ McEntire
Dec 26, 2009 13:58 |  #1
I'm planning to buy the Sigma Ring Flash for macro work very soon, but I was wondering, why is it so much cheaper than the Canon equivalent? I can't afford the Canon alternative at the moment, but is the Sigma flash suitable?
I can't seem to find any decent reviews and I've found no comparisons, so I was wondering if anyone could help me out?
Also, do I need to buy one 'to fit Canon'? On some sites I've found it doesn't list the brand that it fits, and on others it says either 'for Canon' or 'for Nikon'.
Either way, I'm planning to buy it from the following website:
http://www.crazycamera​s.co.uk …roductId=9202&a​ff_code=gg (external link)
Would this be okay?
Sorry for all the questions but I just want to ensure that I'm making the right decision! :)
themadman
Dec 27, 2009 04:34 |  #2
I'll be honest with you, I think it is extremely expensive piece of very specialized equipment. A nice diffuser on a regular flash works just fine as far as I can tell.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Warl0rd
Dec 27, 2009 11:54 |  #3
yes you need to buy "for canon" you you want ETTL to operate.
Paulo
http://www.flickr.com/​photos/warl0rd (external link)
Canon 450D (XSi) + Grip | Canon 80D | EF-S 10-22 | EF 24-105 L IS | EF 100mm Macro | MP-E 65mm 1-5X | EF-S 18-55 IS STM | EF-S 55-250 IS | Takumar 55mm 1.8 | MT-24EX | Metz 48-AF1 | YN460 II | Kenko DG Auto ET | Kata 3N1-20 DL | Lowepro SlingShot 100 AW | Mitsai JDC195 | Manfrotto 190XPROB + 484RC2
LordV
Dec 28, 2009 01:33 |  #4
I certainly would not buy the sigma fit version for a canon camera- as commented above it may not work at all and certainly would not allow ETTL metering. There has also been some problems with even the canon version working properly with some of the recent canon bodies- not sure if sigma has fixed this.
This type of flash does get the light where you want it but is very hard to get decent diffusion - as commented by Will above I'd get a normal canon flash such as a 430Ex and use it with a diffuser such as a Lumiquest softbox.
Brian v.
Macro Hints and tips
Jack ­ McEntire
Dec 28, 2009 07:10 |  #5
Thanks for all of your comments, luckily I did end up buying the Canon fit one! :lol: It should be here by the end of this week so soon I can have a decent play around with it and make a decision... if I don't feel it's giving me the results I want, I'll be returning it and looking into regular flashguns.
I've got a few more questions to ask (directed especially towards LordV):
1. Can 'nice', 'artistic' lighting be achieved through the use of a ring flash? I've read that ring flashes can create dramatic '3D' lighting when played around with, but I've also read that they can produce pretty flat light. I'd really like to produce images similar in style to yours and those of other photographers such as Igor Siwanowicz; what would you personally say are the big pros/cons of ring flashes vs. side-mounted flashguns? The main reason I just wanted to get a ring flash was because I felt that they looked much more compact and a hell of a lot less fiddly and weighty than a side-mounted flashgun.
2. Probably a stupid question, but can a ring flash be used when a lens hood is attached? :o
Warl0rd
Dec 28, 2009 09:26 as a reply to  @ Jack McEntire's post |  #6
if your shooting macro at 1:1 then you probable don't have the hood attached already :P
Paulo
themadman
Dec 28, 2009 15:44 |  #7
Warl0rd wrote in post #9275462 (external link)
+1 I rarely use lens hoods when doing macro, they tend to bump stuff and mess up my shots!
KCMO ­ Al
Jan 03, 2010 14:19 |  #8
As long as it uses e-ttl it is compatible. Sigma makes good stuff so I wouldn't hesitate to try it out.
I have the Canon and some of the comments by people who don't have it are off the mark. You can turn off or turn down the tube on one side to give you some modeling and you can hold the flash off camera for more.
You cannot use the lens hood as it goes directly on the front of the 100 macro lens. Other lenses, including the new 100 L macro, require an adapter.
One excellent feature of the Canon is that it can be used as a master with the 580 and 430. That opens up huge opportunities. I'm not sure the Sigma can do that.
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D Mk III
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
IslandCrow
Jan 04, 2010 11:57 |  #9
I own the Sigma, and I've been very happy with it. I use it exclusively with my MP-E 65mm lens (I've never felt the need for a ring flash with my 100mm 1:1 macro). The ETTL does work, but I seem to use manual settings more often. I remember getting some quirkiness with ETTL when I first got the flash, but that was probably more user error than anything else. I also seem to remember the Sigma having the capability to act as a Master, but I've never actually tried it, so assuming I even remember correctly, I don't know how well it works. Perhaps I'll have to play around with that when I get home today.
Dalantech
Gallery: 525 photos
Best ofs: 5
Jan 05, 2010 08:18 |  #10
IMHO you'd be better off with a standard flash on a bracket. Even with ratio control the light from a ring flash is going to look flat. If you really want a dedicated flash for macro then get the MT-24EX and build a diffuser for it (external link). I own the MR-14EX and I only use it for abstract work, and wouldn't have bought it if I'd known how poor the light quality would be...
My Gallery (external link)
My Blog (external link)
Macro Tutorials (external link)
Jack ­ McEntire
Jan 06, 2010 06:02 |  #11
Thank you all for your help and advice! :) The flash came today so I've been having a play around with it with my Sigma 150mm at 1:1, and I'm afraid to say that the light is indeed very flat and unattractive! However, holding the flash off camera produces the right kind of look; here's a quick experiment I did earlier with a dead orchid mantis:
IMAGE: http://i20.photobucket.com/albums/b246/JACKMCENTIRE/DPP1_0001editsmall-1.png
Now, I'm wondering, if I'm going to be constantly holding the flash off camera, is it worth the £220 it cost me? I don't know whether I should take it back for a regular flashgun, but if I did then surely bracket mounting the flashgun would make the whole thing very heavy, and I wouldn't be able to move the flash whereever I wanted it? :confused:
I'd really like to hear what people think, I'm very confused as to where to go next!
Warl0rd
Jan 06, 2010 06:29 as a reply to  @ Jack McEntire's post |  #12
why do you think some advised to buy a standard flash...
you can also play with the flash settings or see if you can make some kind of diffuser...
Paulo
Jack ­ McEntire
Jan 06, 2010 06:42 |  #13
Yeah, I understand why some suggested a regular flashgun but I thought that bracket mounting looked like a bit of a messy job and I thought that it would make the whole unit very large and heavy. :o Also I just wanted to try out the Sigma flash just to see how it worked, and when held off camera it seems to work as I would like it to, despite the fact it's very tricky to hold the camera in one hand and the flash in the other and still take a decent shot. :confused: All I'm asking now is would it be more practical and affordable for me to get a regular flashgun which I could suspend off camera and diffuse?
Warl0rd
Jan 06, 2010 06:50 as a reply to  @ Jack McEntire's post |  #14
I would say switch to regular flash unless you can figure out a way to use the ring the way it is supposed...
Paulo
Jack ­ McEntire
Jan 06, 2010 07:04 |  #15
IMAGE: http://i20.photobucket.com/albums/b246/JACKMCENTIRE/DPP2_0001editsmall.png
IMAGE: http://i20.photobucket.com/albums/b246/JACKMCENTIRE/DPP2_0002EDITsmall.png
1st shot is off camera, 2nd shot is on... there's no way that having it attached to the lens is going to produce the kind of results I'm looking for... :confused:
8,707 views & 0 likes for this thread, 8 members have posted to it.
1593 guests, 137 members online
