Thread started 27 Dec 2009 (Sunday) 01:40
Blegh.. I can't get ANY "good" (from my perspective) pictures anymore...
quadwing
Gallery: 6 photos
Joined Sep 2009
Dec 27, 2009 01:40 |  #1
Dear POTN:
I'm having a problem. Having a DSLR isn't as exciting as it was anymore. I've been trying and trying, and none of my pictures are as fun as they used to be. They either turn out overexposed, underexposed, or blurry, or perfect--just not good... :( Here are some examples (view links below):
http://img69.imageshac​k.us/img69/1657/img002​9wo.jpg (external link)
http://img51.imageshac​k.us/img51/2184/img004​0w.jpg (external link)
http://img69.imageshac​k.us/img69/9601/img005​4e.jpg (external link)
http://img686.imagesha​ck.us/img686/9695/img0​056nk.jpg (external link)
http://img42.imageshac​k.us/img42/7487/img006​9g.jpg (external link)
http://img85.imageshac​k.us/img85/4431/img007​3y.jpg (external link)
I find this discouraging. I rarely find a picture I'm happy with anymore. And on top of that, when I zoom 100% on any photo, it's annoyingly noisy, or unsharp and I'm using only 800 ISO at max. I'm using a 50mm f/1.8 (canon of course), and generally shoot at f/1.8 aperture in either Av mode, or manual. I seldom use Tv. If you guys could help me out, I'd appreciate it.
Thanks,
Regards,
QuadWing. :(
Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
Erik_L
Dec 27, 2009 01:51 |  #2
1.8 is going to be soft. that lens is not "tack sharp" until about 2.8 or so. If you want to shoot at f/2, I suggest the 50 f/1.4.
do a front/rear focus test by shooting a ruler that is angled away from you, focus on a particular number and be sure that THAT NUMBER is the one in focus. let us know
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
JimmyG
Dec 27, 2009 02:01 |  #3
All those images look like lighting issues to me, I see underexposure and camera shake.
James
Gripped EOS 5Dc|Gripped EOS 7D|EOS 450D|EOS Elan|Polaroid 103|Minolta X-700|Rokinon 8mm Fisheye|Canon 40mm 2.8 'pancake'|Canon 85mm 1.8|Canon 70-200 F4 L
James R Graves Photo (external link)
fivegallon
Joined Sep 2004
Dec 27, 2009 02:04 |  #4
1.add some light or use a tripod....
2.your first pic is at iso 1600
3.you may need to learn the relationship between aperture, speed and light if you insist on shooting manual and are not sure why your pics are under-exposed or blurred
Info
insanecutback
Dec 27, 2009 02:04 |  #5
Go somewhere new. Get outside and breathe in some fresh air and snap a pic or two. Go to the mall and get some portraits. Call a friend and ask her or him to model for you. Follow your pet around. Do some time lapse. Set the timer and model yourself. Just some ideas to freshen it up a bit.
Canon 7D, 10-22 ES USM, 17-40 1:4 L, Sigma 30 1:1.4 HSM, 50 1:1.8 II, 55-250 IS
Erik_L
Dec 27, 2009 02:04 |  #6
I concur. did these "crappy" photos happen once you stopped using the IS kit lens? Remember, that tiny little 50 1.8 is about the same reach as the kit when it's fully zoomed, so it's susceptible to a shakey hand.
Invest in a flash or crank the ISO to 800 or so
If you use photoshop, I found the TLD DNR plugin (free!) to be incredibly effective, not that you'd need it at ISO 800
http://www.thelightsri​ghtstudio.com/TLRDigit​alNoiseReduction.htm (external link)
Remember, 1/5 second exposure is MUCH too long for any focal length(without a tripod)! turn the lights on and try again!
Canon EOS 1D III
yalequan
Dec 27, 2009 02:07 |  #7
As Erik said, 1.8 has a very shallow DOF, so if you move slightly after focusing your plane of focus may change. Because I can't see any EXIF I can't give you any more help. I also cannot see anything on your flicker so I don't know what you're comparing these photos too.
The first two look like you were exposing for the brighter surface behind your subject, and thus your subject is very under exposed. The other two look like either camera shake or the focus somehow changed.
The one's with the plane do look a bit soft, but 1.8 on the 50mm isn't going to be incredibly sharp. Try redoing some of the photos with a smaller aperture and see if that works, or try using a tripod to do some focus tests.
Sorry if this comes across harsh, I'm just trying to be helpful.
-Yale
Erik_L
Dec 27, 2009 02:08 |  #8
not harsh at all...
Check your metering mode - set it for center average or evaluative. Maybe it's set to spot or something. if you could post all of your current settings, other than exposure, that may help us out a bit!
Canon EOS 1D III
NeoTokyo
Dec 27, 2009 02:23 |  #9
Seems like poor lighting and less than adequate shutter speed for hand holding.
If a tripod isnt your thing you might want to try a monopod to see if that helps to steady your shots during slower shutter speeds.
Keep shooting, maybe buy a new lens like a 50mm 1.4 like said before or try a different focal length all together or a quality zoom.
Check out my flickr! http://www.flickr.com/​photos/crainracing/ (external link)
Omaru
Dec 27, 2009 02:27 |  #10
I suggest you go out and do some landscapes or ask a friend to model for you. Try different things it will refresh you.
Visit my flickr (external link)
Visit my vimeo too! (external link)
Cosplay is Awesome
quadwing
Gallery: 6 photos
Joined Sep 2009
Dec 27, 2009 02:52 |  #11
Erik_L wrote in post #9268910 (external link)
not harsh at all...
Ah, I stopped it up again, a lot sharper, but the light is still kinda weird.
Back-front end focus test:
Alright, the ISO for all of these pictures are set to 800, I use custom white balance, I'm using partial metering, continuous shooting, medium-fine quality. Also using auto focus. I have everything in custom settings turned off. The picture style is set to landscape, and I'm using AI Focus mode.
I shot 6 shots. Three without flash, and the other three with flash. First three are underexposed because I didn't feel like grabbing my tripod from the car because the house has an alarm, and it goes off whenever I leave, so I'd rather not wake anyone up. Also, I'm pretty sure the EXIF on these photos will be available:
http://img691.imagesha​ck.us/img691/2852/img0​001nq.jpg (external link)
http://img38.imageshac​k.us/img38/4051/img000​2uc.jpg (external link)
http://img7.imageshack​.us/img7/9749/img0003r​e.jpg (external link)
http://img691.imagesha​ck.us/img691/6528/img0​005tz.jpg (external link)
http://img42.imageshac​k.us/img42/5876/img000​6qd.jpg (external link)
http://img85.imageshac​k.us/img85/8305/img000​7n.jpg (external link)
Also, yeah, it has a lot to do with my emotional feeling on photography as well. So thanks for noticing that, Insane! Also Erik, I've never owned the kit lens. Ever, lol. Also haven't used the 18-55 since I've owned the T1i, haha. And to the person who mentioned Flickr: I recently set one up, so I haven't really had a chance to put anything on it yet (holidays and such), but I will when I get back home! :)
This would have to be the best shot I've gotten today:
http://img15.imageshac​k.us/img15/9934/useoft​hefinger.jpg (external link)
...No joke, lol!
Erik_L
Dec 27, 2009 02:54 |  #12
LOL, oh well.
Canon EOS 1D III
quadwing
Gallery: 6 photos
Joined Sep 2009
Dec 27, 2009 02:57 as a reply to  @ Erik_L's post |  #13
Kinda OT: I want to buy a flash, but I don't have enough money for one, haha. I guess I'll start saving though. Should I go for the 580EX II, or the 430EX II?
Erik_L
Dec 27, 2009 03:02 |  #14
if you can't afford one, go for a used 420 EX. it's bright and swivels and tilts. The only differenece between it and the 430 EX II is:
slightly less bright (guide number 42 instead of 43)
full auto only, no manual control (E-TTL works so well, you'll likely never need manual)
one button to control tilt, one for swivel - 430 has one button for both
plastic foot instead of metal foot
slightly slower recycle time
noisy recycle, 430 is completely silent
I got my 420 EX for $80 - very worth it, but I do like my 430 EX II a lot better... Avoid the temptation (if any) to get a 270 EX as it will not cut it in many circumstances.
Canon EOS 1D III
quadwing
Gallery: 6 photos
Joined Sep 2009
Dec 27, 2009 03:08 |  #15
Erik_L wrote in post #9269036 (external link)
Ah. I'd rather go for a 430EX II because the plastic shoe on the 420EX kind of turns me off, but then again, the 580EX II is only $100-$150 more than the 430EX II, and if I have the 580EX, I don't have to worry about upgrading my flash, unless Canon comes out with a 600EX or something. (Lol, run on sentence). Anyway, I guess I'll start saving up then. Might take a month or two, seeing as I'm a teen who's unemployed, $100 is rather tricky to come by for me, haha.
And yeah, 270EX.. absolutely not, hahaha. I would never mount such a hideous thing on my shoe. :mad:
6,725 views & 0 likes for this thread, 23 members have posted to it.
1452 guests, 127 members online
