Thread started 27 Dec 2009 (Sunday) 20:13
Colored circles ruining pictures
MickeyCT
Dec 27, 2009 20:13 |  #1
I'm hoping you folks won't object to my posting a question about a Panasonic P&S. I didn't know where else to turn.
I bought my daughter a Panasonic DMC-TS1 for Christmas and many of the pictures have white or colored circles, or more correctly pentagrams, making them unusable. I've tried to find a pattern to help figure out what's causing it but no luck.
Any ideas? Is there something wrong with the camera or is this something fixable?
I'm considering returning the camera to Panasonic and getting something else. Here's a link to one of the pictures.
Mickey
Switching to Olympus OM-D mirrorless system
Mark1
Dec 27, 2009 20:22 |  #2
Looks like a dirty camera to me.
nardes
Gallery: 1487 photos
Best ofs: 15
Dec 27, 2009 20:43 as a reply to  @ Mark1's post |  #3
It’s difficult to tell from the small photo, but looking at a couple of the artefacts, they appear to show the pattern of diffraction rings? There appears to be a central spot surrounded by concentric 5 petalled “rings”? If the iris is a 5 blade diaphragm this might explain the 5 petalled “rings?
I have seen (round) diffraction patterns (using telephoto lenses) from very bright, point sources in the background of photos, but nothing quite like this?
Can you post an enlargement of a couple of the clearer patterns?
Cheers
Dennis
MickeyCT
Dec 27, 2009 21:37 |  #4
Does this help?
Mickey
Jon
Joined Jun 2004
Dec 28, 2009 05:00 |  #5
You're only seeing it with flash, right? You're seeing the flash reflected off dust in the air. Not the camera's fault.
Jon
Cocker Spaniels
nardes
Best ofs: 15
Dec 28, 2009 05:56 as a reply to  @ Jon's post |  #6
These patterns look very much like the diffraction patterns produced by out of focus point sources.
Here is a photo I took of a Pelican and the water in the background had bright, point like reflections which appeared as diffraction patterns.
When you look at out-of-focus stars through a telescope, you can see similar patterns. The objective lens of a telescope is round so the diffraction rings appear round and concentric. At sharp focus, you only see the point like star (simplistically) but as you approach focus and then pass through it, you would see the concentric diffraction rings. The out-of-focus diffraction rings in my photo appear octagonal, suggesting that the iris has 8 blades, whereas in your lens, there appear to be 5 blades?
So, at face value, a candidate for these shapes are out-of-focus point sources somewhere in the optical train, although I have never seen so many, so widely dispersed, both in front of and behind the main subject?
Cheers
Dennis
MickeyCT
Dec 28, 2009 11:59 as a reply to  @ nardes's post |  #7
Jon: So, if these are caused by dust particles in the air, then how come none of the other cameras used during the day have the same issue. (Yes, it seems to occur only when flash is used.) This was Christmas Day and 20 people in the house and quite a few different P&S cameras of different makes and complexity, plus my 20D. It's only her new camera that had the issue. She even switched to her old camera Fuji Finepix F10 for a while and that had no problems either.
Dennis: I assume your comment about "out-of-focus point sources somewhere in the optical train" might also refer to dust particles.
Is there anything we can do about it? House had been recently dusted and vacuumed. :)
Why would this camera pick this up when others don't?
Mickey
Mickey
Jon
Joined Jun 2004
Dec 28, 2009 12:12 |  #8
The closer the flash is to the lens, the more likely it is to happen. It's like "red-eye" in that. And looking up that camera, I'd have to say that yes, the flash is very close to the lens.
Jon
Cocker Spaniels
dwminer
Dec 28, 2009 13:06 |  #9
Well the pentagrams shape is a product of the iris and/or shutter. As for as the spots go and these are only thoughts, water spots on the lens, particles in the air close to the lens, but these have already been suggested.
nardes
Best ofs: 15
Dec 28, 2009 14:51 |  #10
It does seem odd that only 1 camera is picking up these patterns? The colours of the out of focus pentagrams are a little puzzling. Your cropped enlargement appears to show a red, green and blue diffraction pattern whereas all mine on the pelican shot appear white (RGB combined).
The sensor (chip) has does have a built in RGB array of filters (the Bayer Matrix) – is there a connection here? Surely these “particles” aren’t so close to the sensor such that they only illuminate the pixel below each R, G or B filter of the Bayer Matrix?
Another thing that puzzles me is that I’ve seen these patterns mostly on long focus lenses (+200mm), whereas it looks like you were shooting at the wide angle end of the lens?
Cheers
Dennis
MickeyCT
Dec 28, 2009 14:51 |  #11
Thanks for all the help and suggestions as to cause.
Now, do I return the camera and try to find a waterproof P&S with the flash further from the lens or is there some post processing trick that might easily remove this, sort of like the red-eye fix in Photoshop and Elements?
Mickey
Jon
Joined Jun 2004
Dec 28, 2009 15:00 |  #12
I don't know of any easy post-processing trick, since they're going to be between the camera and the subject so any fix would mean trying to recreate whatever was behind them. So I think your choices are to live with it (maybe try some shots in another location and see if it happens or if there might have been something about the environment that was a contributor) or find another camera that's "waterproof". From the Panasonic site, with a 10' depth limit, I don't think I'd call that "waterproof" - more "splash-proof", you might want to look for something with a deeper limit. Canon's PowerShot D10 has a 33 ft (10 meter) limit. I believe Pentax makes some waterproof, or at least splash-proof models, too.
Jon
Cocker Spaniels
hnikesch
Gallery: 24 photos
Dec 28, 2009 15:03 |  #13
I agree with Jon, I have has similar issues with dust in the air close to the camera. My camera also has the flash close to the lens. I get this about 4 or 5 times a year
Hans
tkbslc
Dec 28, 2009 15:39 |  #14
It is out of focus dust reflecting flash light back to the sensor. I have had cameras that are worse for that problem than others - like my second digital camera (back in 2002) - the Fuji A201. Could not shoot it indoors for that reason. My CAnon SD1100 does it more than my Casio Z70 or Fuji S700 did, but still not very often. The old fuji A201 was literally 95% of indoor shots. So I feel your pain. I ended up getting rid of it because I did not feel confident using it indoors with flash. Honestly, I would return it because it won't get better.
Taylor
EOS Rp | iPhone 11 Pro Max
MickeyCT
Dec 28, 2009 15:45 |  #15
Update - I just talked with Panasonic and pointed them to this thread to see the pictures. They think it is dust or particles in the camera itself and they are going to replace it for me.
I'll keep you posted. Thanks for all the help.
Mickey
3,877 views & 0 likes for this thread, 12 members have posted to it.
1744 guests, 169 members online
