I have a 5D Mark II on order and was wondering if I should set the ISO to one-stop increments instead of 1/3 stop increments. That's what I do on my 50D. Is the 5D's ISO any different in that regard?
SamAlfano Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | Dec 28, 2009 07:53 | #1 I have a 5D Mark II on order and was wondering if I should set the ISO to one-stop increments instead of 1/3 stop increments. That's what I do on my 50D. Is the 5D's ISO any different in that regard?
Dec 28, 2009 08:24 | #2 You can set the ISO increments to 1/3, 1/2 or 1 stop. Just look at CF I-1 and I-2 and customize to your liking. Jim
SamAlfano THREAD STARTER Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | Dec 28, 2009 08:44 | #3 Does the 5DM2 'push' the in-between settings like the 50D does? Or are the 1/3 stop 'real' ISO settings. I'm probably not wording this very well.
sandpiper Cream of the Crop More info | I don't know if the 5D II is the same, but with my 20D and 5D (classic) the 1/3 stop ISOs are, very slightly, noisier than the next up 'normal' ISO (according to published tests). This is due to them being adjusted differently in processing apparently.
sandpiper Cream of the Crop More info | Dec 28, 2009 08:49 | #5 abigailandsam wrote in post #9275246 Does the 5DM2 'push' the in-between settings like the 50D does? Or are the 1/3 stop 'real' ISO settings. I'm probably not wording this very well. Worded fine to me. That is what I referred to in my answer above, the pushing of the thirds. I don't know if the mk II does it or not, but I would assume so until shown otherwise, as it seems to be the norm on previous bodies.
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | Dec 28, 2009 10:41 | #6 abigailandsam wrote in post #9275246 Does the 5DM2 'push' the in-between settings like the 50D does? Or are the 1/3 stop 'real' ISO settings. I'm probably not wording this very well. They are software-generated. Only 1-series cameras have native 1/3-stop ISO increments.
versedmb Goldmember 4,448 posts Likes: 4 Joined Apr 2006 More info | Dec 28, 2009 11:22 | #7 toxic wrote in post #9275860 They are software-generated. Only 1-series cameras have native 1/3-stop ISO increments.
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Dec 28, 2009 11:27 | #8 As far as I know, everything but 100 ISO is software generated in some way as sensors are not film. My collection of boxes with holes
SamAlfano THREAD STARTER Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | Dec 28, 2009 12:23 | #9 toxic wrote in post #9275860 They are software-generated. Only 1-series cameras have native 1/3-stop ISO increments. Thanks for that info. I suspected that was the case but wasn't sure.
puttick Senior Member More info | Dec 29, 2009 09:08 | #10 Sandpiper wrote: "I don't know if the 5D II is the same, but with my 20D and 5D (classic) the 1/3 stop ISOs are, very slightly, noisier than the next up 'normal' ISO (according to published tests)." Nigel Puttick
RDKirk Adorama says I'm "packed." More info | Dec 29, 2009 10:15 | #11 HankScorpio wrote in post #9276132 As far as I know, everything but 100 ISO is software generated in some way as sensors are not film. Well, no, the full stop increments are hardware amplified, not software generated. TANSTAAFL--The Only Unbreakable Rule in Photography
RDKirk Adorama says I'm "packed." More info | Dec 29, 2009 10:21 | #12 puttick wrote in post #9282319 Sandpiper wrote: "I don't know if the 5D II is the same, but with my 20D and 5D (classic) the 1/3 stop ISOs are, very slightly, noisier than the next up 'normal' ISO (according to published tests)." That sounds very unlikely - though I'm not saying you are wrong. Where are the tests? I would be very interested to know, or better still see the evidence. Nigel I've seen personal tests shared on other forums. It's something that you probably would never see outside of a pixel-peeping test, but what the tests also prove is that there's no benefit to the 1/3 intervals, either, except to clutter up the workflow. TANSTAAFL--The Only Unbreakable Rule in Photography
EOS_JD Goldmember 2,925 posts Likes: 2 Joined Dec 2005 Location: Lanarkshire, Scotland More info | Dec 29, 2009 10:23 | #13 sandpiper wrote in post #9275256 with my 20D and 5D (classic) the 1/3 stop ISOs are, very slightly, noisier than the next up 'normal' ISO The 20D doesn't do 1/3 stops. Only full stops. All My Gear
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Dec 29, 2009 10:56 | #14 RDKirk wrote in post #9282691 Well, no, the full stop increments are hardware amplified, not software generated. Well, yes but anything but the native ISO of a sensor is in some way faked which is what I mean. My collection of boxes with holes
gjl711 "spouting off stupid things" 57,724 posts Likes: 4057 Joined Aug 2006 Location: Deep in the heart of Texas More info | Dec 29, 2009 11:08 | #15 HankScorpio wrote in post #9282969 Well, yes but anything but the native ISO of a sensor is in some way faked which is what I mean. Even ISO 100 is amplified. The difference between ISO 100, 200, 400, 800 and so forth is the amount of amplification. They are all hardware generated. 1/3 stop ISOs have the additional step of either pushing or pulling the exposure via software. Not sure why, but call me JJ.
| Latest registered member is zachary24 1455 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
