merlin2375 wrote in post #9275669
2) In addition to #1, it seems changing the distance of subject only changes the near limit of acceptable sharpenss. Why is that?
It's probably because you are entering subject distances greater than the hyperfocal distance for that aperture and focal length. When you do that it will show infinity as the far limit of acceptable sharpness, then show an increasingly distant near limit of acceptable sharpness as you increase the subject distance.
Give it a try. Using the default values of 55mm and f/16, put 30 feet for the subject distance. Note both the near and far limit of acceptable sharpness. Now put in 31, then 32, noting the results. Now you are approaching the hyperfocal distance. Now enter 32.1, 32.2, 32.3 etc, up to and beyond the hyperfocal distance, which is 32.8'. Once you get to 32.8' the far limit will become infinity and any subject distance further than that will only affect the near limit of acceptable sharpness. This is because you have exceeded the hyperfocal distance, which is the distance that will give you the greatest depth of field for that aperture and focal length.
Anything before or after that point results in a shallower depth of field.
Mike
