Sibil wrote in post #9301869
I am not an expert by any means, but I think the question on ambient setting was asked as a point of reference.
Correct. I'm trying to figure out if the OP's flashes were getting him far enough above the ambient lighting to eliminate ghosting.
Gottcha18 wrote in post #9301691
They didnt allow me to use my Alienbees and i was barely allowed to use my flashes (speedlights). Im sorry i dont remember the ambient settings.
The whites look pretty hot on the shots. That can sometimes be tough to avoid using direct flash.
Its kinda tough to tell from the small photos posted, but it looks like you may have a bit of motion blur in the shots. This can happen due to the long flash duration of speedlites when used at full or half power. Speedlights are the opposite of most A/C powered strobes in that the flash duration gets shorter as you turn down the power. With your AB800's, the flash duration is shortest at full power.
It would also be a good idea to get at floor level. Sports photos are generally more appealing when you shoot from slightly below the players. This gives them a "larger than life" and more powerful appearance. The angle you were shooting at works well for a few shots (like your first one, which is an excellent shot), but not for every shot.
