Thread started 30 Dec 2009 (Wednesday) 15:15
Lacie SAFE - terrible trouble
hania
Dec 30, 2009 15:15 |  #1
I bought an 1TB Lacie SAFE (by mistake) not realising what the SAFE designation meant - its a biometric drive (use fingerprint to open it) .
Its been nothing but trouble since I got it - recently it suffered a hardware crash so I lost all my date & Lacie put a new drive in but it worse than ever - seems to work ok but then suddenly I get: disk needs initialsing etc and all my data has gone again.
It also randomly mounts & dismouts; sometimes it mounts, I open it with my fingerprint - but the icon does not appear on the desktop!
Ive already had the power supply replaced.
It loooks to me as if its not compatible with an imac - my lacie D2 quadra spins down fine when the imac shuts down - this stays running.
Ive wasted hours putting data back on only for it to vanish without warning!
Has anyone esle had similar problems?
I am thinking of just junking the drive even though its still under the manufacturers 3 year warranty.
russ_hillis
Dec 30, 2009 15:24 |  #2
Dunno. I'm assuming this is an external drive. So the 1st thing to replace is the cable and make absolutely sure it's seated properly.
My greatest dream, is to find a wife selling her husbands gear for what he told her it was worth! Zenfolio (external link)Promo Code BU4-Y6F-KHG My Flickr (external link) 7D Tamron 17-50 mm f2.8, Nifty 50, Vivitar 135mm f2.8, Tokina ATF/D 80-400mm
pipspeak
Dec 30, 2009 20:46 |  #3
I hate Lacie drives. Look nice but seem to die too easily, often because of dodgy power circuits. IMO it's always better to build your own external drives -- buy a bare OEM drive and a decent enclosure for about $30 and you generally have a far more robust solution than the all-in-ones.
hania
Dec 31, 2009 05:18 |  #4
russ_hillis wrote in post #9291359 (external link)
swapped power supply with other lacie I have - same problem
hania
Dec 31, 2009 05:20 |  #5
pipspeak wrote in post #9293150 (external link)
good idea - not too difficult to do I assume?; I had seen a dock at Maplins where you just stood a bare drive in - seems a good idea also. Will investigate
Lowner
"I'm the original idiot"
Dec 31, 2009 05:41 |  #6
I wish I'd come across this before ordering 2x 1TB LaCie external drives. I ordered two Western Digital drives, was told they were on back order and allowed myself to be talked into the LaCies. A month later I'm still waiting because guess what? They are on back order.
I'm suspicious. Why talk me out of WD and into LaCie, more profit margin for Warehouse Express?
Richard
russ_hillis
Dec 31, 2009 08:40 |  #7
hania wrote in post #9295139 (external link)
I'm not talking about the power supply I'm talking about the data cable. The issue is symptomatic of a bad data cable or a poor connection.
bohdank
Dec 31, 2009 08:45 |  #8
hania wrote in post #9295140 (external link)
I use an ESATA dock. Would never go back to "enclosures".
MDJAK
Dec 31, 2009 09:32 |  #9
I have one Lacie rugged drive which works flawlessly.
But I do often see a disk dismounting without warning, but as I have about 7 external hard drives, including a G safe, I never know which one it is.
Lowner
Dec 31, 2009 09:38 |  #10
What does "mount" and "dismount" refer to? My current WD external hard drive is on, but asleep as I write this, but should I need anything from it, or wish to save to it, then its quick enough to restart. So I assume that whats being talked about is something more serious?
Richard
morthcam58
Dec 31, 2009 09:55 |  #11
I'm with MDJAK. Not to discount the OP's valid problems, but I have 3 Lacie external drives and have never had a problem. But they're plain vanilla drives, no biometrics or fancy stuff.
Matt
Sold off all the Canon gear, trying Fuji now
russ_hillis
Dec 31, 2009 10:17 |  #12
Lowner wrote in post #9296072 (external link)
Mount - (connecting / connected) available & ready to use. Dismount,(disconnectin​g / disconnected) and unavailable for use.
pipspeak
Dec 31, 2009 13:36 |  #13
Sticking a drive into an off-the-shelf enclosure is as simple as removing the top of the enclosure and installing the drive with four supplied screws. You can get enclosures with all sorts of port options and most come with decent controller chipsets and replaceable power supplies. Look at online computer equipment retailers for external 3.5" drive enclosures and you should find a pretty good selection with whatever ports you need.
A decent Vantec external enclosure plus a WD Caviar Black 1TB drive would cost about $130 in the US. A similar setup through, say, amazon in the UK would be about £100 (enclosure about 30 and drive about 70)
hania
Jan 01, 2010 04:12 |  #14
yes - it dosen't appear on the desktop as being available to use (even though I can hear it running)
hania
Jan 01, 2010 04:12 |  #15
russ_hillis wrote in post #9295770 (external link)
Oh- shall try another data cable - thanks
Looked at cables - I had daisy-chained it with firewire 800 from the other lacie drive. I have now connected it with firewire 400 direct to my imac and will see if it behaves better!
Unfortunately my imac only has 1 800 port.
2,327 views & 0 likes for this thread
Latest registered member is socrbob
948 guests, 293 members online
