BrianMc3 wrote in post #9291975
I'm on the fence as usual about getting a prime (50f/1.2 or 85f/1.2 II). Right now I use 16-35 24-70 and 70-200IS all f/2.8. I read reviews about how much better the prime lens is over the zooms lets see the difference. The difference may not be able to be sen here due to the restriction in size and quality so if you could post a link. I want to get one, probably have to rent to see if I like it, but let me know what you think!
The difference in sheer IQ may not be seen anywhere unless you are a quite careful photographer in a situation in which you can take that care.
"Better" is relative. For someone who is after the shallowest possible depth of field at maximum aperture, a very fast prime is better. For someone after the smallest, lightest, fastest lens at a given focal length, a prime will usually be the best choice.
In most cases, a good prime will be sharper than a zoom at the same aperture as the zoom's maximum aperture. But you have to compare lenses of similar construction quality and level of design. I have, for instance, an f/2.8 50mm Tessar (made in the early 50s for an old Exacta) that is nowhere near as sharp and contrasty as my Canon 80-200 f/2.8 L at any focal length.
