Thread started 31 Dec 2009 (Thursday) 13:31
50mm1.2L - worth using for macro?
chadsmith
Dec 31, 2009 13:31 |  #1
We just got the 50mm 1.2 at home, and I was wondering if this would be worth using as a macro lens (with tubes). I also have the 85mm1.2L.
This is coming up because my 100mm 2.8 is dying, and if I have to spend the money, I already know I want a macro flash, so I'm hoping I can make use of another lens for the time being.
could I even try the 50 with the 85 reverse mounted?
Thanks in advance!
5DMk2,100mm/2.8 macro, 580ex2 (my macro setup)
70-200/2.8 nonIS, 50mm/1.2, 85mm/1.2, 24-70/2.8
http://www.facebook.co​m …otography/11211​7175487648 (external link)
themadman
Dec 31, 2009 14:10 |  #2
You can try reverse mount or extension tubes.
1. You don't need a macro flash, your 580EX II should work fine if you just diffuse the light.
2. How did you 100mm 2.8 macro die?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
chadsmith
Dec 31, 2009 14:52 as a reply to  @ themadman's post |  #3
It focuses to infinity if it has to focus more than slight amount. I might take it in for repair, but I want to see if I can get similar results with other lenses and tubes.
themadman
Dec 31, 2009 17:39 |  #4
In autofocus or manual?
chadsmith
Dec 31, 2009 17:45 as a reply to  @ themadman's post |  #5
autofocus. It used to work just fine.....now it usually focuses to infinity and keeps going, with a grinding noise.
themadman
Jan 01, 2010 01:31 |  #6
Hmm... weird. Well, I never use autofocus for macro so it wouldn't bother me =P
1,400 views & 0 likes for this thread, 2 members have posted to it.
1096 guests, 177 members online
