I took this hand held photo from my daughter's place in Henderson and I noticed that the verticals are not plumb, how do i adjust. Please post any other C&C:
tonyniev Cream of the Crop More info | Jan 01, 2010 00:08 | #1 I took this hand held photo from my daughter's place in Henderson and I noticed that the verticals are not plumb, how do i adjust. Please post any other C&C: Cheers,
vk2gwk Cream of the Crop 13,360 posts Gallery: 332 photos Likes: 1836 Joined Jun 2009 Location: One Mile Beach, NSW 2316, Australia More info | Jan 01, 2010 01:40 | #2 Depends on the software you are using for post processing. Most of the time you'll find a sort of "ruler" or other device that lets your straighten your horizons or verticals. My name is Henk. and I believe "It is all in the eye of the beholder....."
AmandaMarie Cream of the Crop 6,211 posts Likes: 5 Joined Jul 2009 More info | Jan 01, 2010 01:43 | #3 In Photoshop Elements, there is an option under Image > Rotate > Custom. Then you can enter 1 degree, 2 degrees etc. Not sure what program you use. Meow.
gonzogolf dumb remark memorialized More info | Jan 01, 2010 02:13 | #4 Is this a panorama or a crop from a single shot? Most programs that let you crop have the ability to adjust the crop to straighten the horizon as you crop.
Woolburr Rest in peace old friend. 66,487 posts Gallery: 115 photos Best ofs: 2 Likes: 143 Joined Sep 2005 Location: The Tupperware capitol of eastern Oregon...Leicester, NC! More info | Jan 01, 2010 02:24 | #5 Most editing software has a built in leveling tool. For instance, in Photoshop Elements, there is an icon on the tool bar that looks like a level monitor on top of one that is tilted about 20 degrees. To use it, you simply select the tool, find an object in the image that should be level....move the cursor to one side of that item and left click...it will place a marker at that point....move to the opposite side of the item you wish to level and click again on a point that should be level with the first...the program will then rotate your image to level....all you have to do is crop away the portion that is no longer on screen. People that know me call me Dan
Snydremark my very own Lightrules moment More info | If you're using LightRoom, open the crop window and click the ruler icon near the bottom of the edit panel; click and hold at one point on the horizon and draw a line along the horizon that you want to be flat. - Eric S.: My Birds/Wildlife
Lonnie Goldmember 1,606 posts Likes: 1 Joined Feb 2006 Location: Southern Louisiana More info | Jan 01, 2010 09:10 | #7 There's also a nice tool for leveling in Picasa, which is free. Downside to leveling is that you'll lose a good bit of the top and bottom of an image that is as crooked as this one. My YouTube Vlog: https://www.youtube.com/c/GarageFlips
Jan 01, 2010 09:41 | #9 thanks to all the inputs, I have photoshop elements that came with my old Rebel 350. Cheers,
Based on you kind inputs. I rechecked the editing capabilities at smugmug and saw tilt edit, did some here...Also the original was over exposed I will do some more adjustments later. Now I know how to control tilt; Cheers,
| Latest registered member is semonsters 1634 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
