Thread started 01 Jan 2010 (Friday) 13:32
Another trying to master Macro.
jgsenior
Jan 01, 2010 13:32 |  #1
Have shot my first real attempts at macro photography. Would like some constructive comments. These were made using a Canon Rebel T1i with Canon 55-250 with Canon closeup 500D attached and a Speedlite 430 EX light source. The ISO was 100 using manual at f32 @1/200. The sea urchin is on a platform that is 22mm in diameter. Is this lens sufficient or would I do better with a dedicated macro lens. Thanks for your suggestions.
Jgsenior
Greg_C
Gallery: 10 photos
Joined Nov 2005
Jan 01, 2010 14:59 |  #2
Not too bad for a kit lens and a dioptre. There is a fair bit of detail in the urchin and in the Zygo catus. Most macro shooters don't shoot much at the F32 range, we're more likely to use F11.
As to the question is this lens the right one, well only you can answer this. Personally I'd stick with it for a bit and make sure Macro is something you are really keen on. Then once you are sure about this I'd think about purchasing a true macro lens.
Greg
Blog (external link) | Photogallery (external link) | 1DmkIV + other stuff
Sanity is a madness put to good use.
gmazza
Joined Sep 2009
Jan 01, 2010 16:17 |  #3
I used to have a quite flexible Sony H5, after revisiting 2 years of shoots concluded that the better opportunities were in macro (there were monqueys and tucanos here too but much more episodic than insects). So I decided to purchase dedicated macro gear. But this depends a lot of how muc % of your photos are macro.
Gustavo Mazzarollo
Portfolio
http://www.gmazza.com/ (external link)
Flickr Gallery
http://www.flickr.com/​photos/gmazza/ (external link)
LordV
Jan 02, 2010 01:19 |  #4
Good shots. A dedicated macro lens will be capable of sharper shots and higher magnifications - think your max mag with this setup is around 0.5:1.
Brian V.
Macro Hints and tips
905 views & 0 likes for this thread, 4 members have posted to it.
1547 guests, 145 members online
