Thread started 02 Jan 2010 (Saturday) 04:27
Off Camera Flash with E-TTL
PixelMagic
Jan 02, 2010 04:27 |  #1
I apologize if this question has been asked previously but I searched and couldn't find an answer.
I have a few 580EX speedlites and I'd like to use two of them off-camera as key and fill lights while still maintaining E-TTL functionality.
Is the following scenario possible?
  1. Set lighting ratio on Master/fill light
  2. Mount Master/fill light on lightstand using an ETTL cable from FlashZebra's website (I'm thinking of either the 5 or 7.5 meter cables)
  3. Mount Slave/key on second lightstand and trigger wirelessly.
I'm already aware of the wireless triggers available; I used to own CyberSyncs. But most of these triggers require using manual flash and I'd prefer to be able to set my exposure in manual; set my flash to E-TTL, and just dial in FEC as needed.
Of course I can also use an ST-E2 but I'd rather not since the wireless capability already exists in the 580EX.
EDIT.
Just ignore this question... I'm not going to delete since it might help someone else. The answer is obviously "yes, its possible." I'm overthinking and need to get some sleep :)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jan 02, 2010 05:27 |  #2
The only issue I see with your setup is if you actually have the 580 EX, not the 580 EX II. The fact that you can control a 580 EX II master from the camera (provided the camera is new enough; at least a 40D) may come in handy when the master is a bit away from the camera.
When it's on camera, it doesn't matter that much.
Anders
PixelMagic
Jan 02, 2010 06:03 |  #3
You raised a point I did not think about at all.
I don't have a "new enough" camera; currently I have a 30D, a 5D, a 1D Mark II and a 1D Mark II N but I plan on acquiring a 1D Mark III sometime soon.
Last year I decided to rationalize my flash setup and sold off my Nikon SB-28 flashes and CyberSync triggers. I settled on using 580EX flashes over the later model because from what I've read a number of the controls on the EX II have been moved to the menus. But the ability to control a 580EX II as an off-camera Master directly from the camera would be a huge plus.
apersson850 wrote in post #9307147 (external link)
apersson850
Gallery: 35 photos
Jan 02, 2010 11:54 as a reply to  @ PixelMagic's post |  #4
The "number of controls" that have been moved is the mechanical Normal - Master - Slave switch. Since that setting, just like everything else, now can be controlled from the camera, a mechanical setting on the flash wouldn't work. That can't be controlled from the camera.
The loss of this switch makes it difficult for users who frequently want to switch quickly between normal and master mode.
On the plus side, the 580 EX II has:
  • Faster recycle time.
  • Control through the camera's menu system.
  • Its own sensor, if you want to use the old type of automatic flash.
  • Better battery compartment cover.
  • Better locking system when mounting on the camera.
  • Sturdier foot.
  • Built-in sync connector (not sure if that's on the 580 EX as well?).
Being of about the same vintage as the 40D, the 1D Mark III is "new enough" to support menu control of new flash units.
Anders
1,361 views & 0 likes for this thread, 2 members have posted to it.
1064 guests, 104 members online
