Thread started 04 Jan 2010 (Monday) 14:02
Simulating sunlight with studio lighting - Did I pull it off?
sdipirro
Jan 04, 2010 14:02 |  #1
I was reading about how to simulate overhead sunlight in the studio and thought it would be a fun thing to try while it was snowing like crazy outside. I shot this with two lights. The main light is behind me, bare bulb, and aimed roughly 45 degrees at my low (white) ceiling. The second light is on a boom, above and slightly behind the subject, with a 7" reflector, and also aimed down at the background at roughly 45 degrees. I wanted it to look like the sunlight was coming from the same direction as it hit the subject and also the background. No other lights or reflectors were used, and I'm wondering if I pulled off "the look" or if there's something I should have done differently. Thanks.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
hawk911
Jan 04, 2010 14:46 |  #2
if I read that right, you bounced the main light? Why bounce it versus just aiming the light at her?
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
sdipirro
Jan 04, 2010 14:49 |  #3
I didn't want to blast the light right into her face. I wanted it to appear as though the light was coming from above. I saw this technique described in Christopher Grey's books as well as in other places. The bare bulb helps to scatter the light coming from above in all directions, as the sun appears to do. I'm just wondering if it looks anything like sunlight here.
hawk911
Jan 04, 2010 15:45 |  #4
it looks flat to me. There's barely a hint of shadow under her nose, which I would expect more of if this were actual sun on a brightly lit day. It doesn't look like sun to me, but let's see what others say.
ChasWG
Jan 04, 2010 15:52 |  #5
It looks like strobes to me too. The sun is harsher and thus causes more shadows. I think you'd need more of a direct effect to pull it off. Maybe moving a reflector closer to the subject. Something like a silver shiny board would be a step in the right direction. Harsh, yet not as harsh as real sun light.
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
sdipirro
Jan 05, 2010 12:51 |  #6
I see what you mean about the nose shadow. I'm not sure how a reflector would help. One thing I thought of is using a flag to block off some of the direct light so that most of the light hitting her is bounced light from the ceiling above. I think a snoot or reflector on the main light might produce too narrow a beam of light...but might be worth a try too. I was also thinking it didn't really look like sunlight but wanted to see if others saw it the same way. Thanks for the feedback.
PacAce
Joined Feb 2003
Jan 05, 2010 13:13 |  #7
Can you explain what you mean by "sunlight". To me, and I'm sure it's the same with the others who have replied here, sunlight is the direct light that's coming straight from the sun. The sun is a small light source, and hence, is harsh and the shadow cast by it is distinct and contrasty. Bouncing the light from the strobe off the ceiling will not achieve that effect. In fact, it'll do the opposite since bouncing the light makes the apparent light source larger, making the lighting soft. Bouncing the light off the ceiling will simulate an overcast lighting, not direct sunlight.
If you want to simulate direct sunlight falling on your subject, you need a strobe, with a reflector mounted, pointed at the subject. If you want the light to be coming from above, place the strobe high up and point it downwards.
...Leo
hawk911
Jan 05, 2010 15:48 |  #8
yup- what Leo said.
bobbyz
Jan 05, 2010 16:23 |  #9
I would now take a smilar shot out in the sunlight and compare the two.
Fuji XT-1, 18-55mm
GenuineRolla
Jan 05, 2010 18:43 |  #10
Sunlight is never that soft.
flickr (external link) | 40/60 Photo (external link) | Petey Photography (external link)| Canon 5D + 17-40mm f/4L + 50mm f/1.4 | 3x Alien Bee B800 | shuttrr.com (external link) - are you in?
Johnny ­ V
Jan 05, 2010 19:40 |  #11
There's sunlight and there's daylight. Your shot looks more like daylight (softer light)
Fear the Gear! Canon 5D3/6D/50D/T2i/EOS-M; 17-40L f4; 70-200 f4; 50 f1.4; 18-55 f3.5 IS; Sigma 85 f1.4; Tamron 85 f1.8; Canon 35 f2-IS; 580EX; Comet Strobes; Smugmug 20% Discount  (external link)
aroundlsu
Jan 05, 2010 21:35 |  #12
You need something in the shot to hint towards the light source. Like a window or something that looks like outside. Then shoot a strobe with a yellow gel directly the left of your model. But barn door or flag it so there is just a sliver of light stroking her. Then add a tungsten lamp in the shot and meter and white balance to the lamp. It will look like a sunrise shooting through the shot. It is not all about the light. It is also about selling the shot.
Teddy Smith, SOC
IATSE Local 600 Cinematographer
sdipirro
Jan 06, 2010 11:57 |  #13
I guess I was thinking more daylight than sunlight, but I understand (and appreciate) all the points made here. It's back to the drawing board for me!
Johnny ­ V
Jan 06, 2010 12:07 |  #14
For daylight use a large bank/umbrella or bounce strobe off wall or large white card. Your portrait it almost works simulating sunlight... almost... but it's the other objects in an image, with light falling on it, that will add to the feel of the quality of light. (geez can't explain it succinctly)
Titus213
Jan 06, 2010 13:34 |  #15
The Master Lighting Guide for Portrait Photographers says for the key light use bare bulb pointed up, above and to one side of your subject. Light the BG separately because sunlight doesn't fall off like studio lights. (Well, not in the distances we're talking about).
There will be a lot more shadow than you have.
Dave
Perspiring photographer.
5,948 views & 0 likes for this thread, 9 members have posted to it.
1698 guests, 139 members online
