sorry I'm a newbie at this. just able to open my RAW files today
what do you guys use this for most? usually the biggest issue I have is with lighting. im sure this will help fine adjust that.
just curious of typical routines for this
thanks
scott0999 Member 173 posts Joined Aug 2006 More info | Jan 04, 2010 21:19 | #1 sorry I'm a newbie at this. just able to open my RAW files today Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
jdhart73 Senior Member 476 posts Joined Mar 2009 Location: Wichita, Kansas More info | Jan 04, 2010 21:36 | #2 White Balance....Exposure.....saturation....vibrancy..... BLOG
kevin1016 Member 73 posts Joined Dec 2009 More info | Jan 04, 2010 23:03 | #3 I read somewhere that Lightroom has the order from top to bottom on the development pane. Is that correct?
dugcross Senior Member 879 posts Likes: 3 Joined Jan 2008 Location: St. Petersburg, Florida More info | Jan 04, 2010 23:32 | #4 kevin1016 wrote in post #9326210 I read somewhere that Lightroom has the order from top to bottom on the development pane. Is that correct? Yes that is correct. They set it up just for that reason. Start at the top and work your way down. Doug Cross
KarlosDaJackal Goldmember 1,740 posts Likes: 2 Joined Jul 2008 Location: Dublin, Ireland More info | quick tab on capture one from top to bottom, anything else the picture needs. My Website
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 05, 2010 18:34 | #6 Top to bottom will work, though I find you can't judge color until the exposure's fixed. I do exposure, brightness, color temp, contrast, blacks, vibrance. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
kevin1016 Member 73 posts Joined Dec 2009 More info | Jan 05, 2010 19:59 | #7 tim wrote in post #9331996 Top to bottom will work, though I find you can't judge color until the exposure's fixed. Color corrections or below exposure in LR.
dugcross Senior Member 879 posts Likes: 3 Joined Jan 2008 Location: St. Petersburg, Florida More info | Jan 05, 2010 23:03 | #8 tim wrote in post #9331996 Top to bottom will work, though I find you can't judge color until the exposure's fixed. I do exposure, brightness, color temp, contrast, blacks, vibrance. Exposure is second from the top with white balance being on top. Color is below that. So I'm not sure what you're talking about. Doug Cross
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 06, 2010 00:31 | #9 dugcross wrote in post #9333616 Exposure is second from the top with white balance being on top. Color is below that. So I'm not sure what you're talking about. What I mean is top to bottom will work, but you'll probably go top to bottom then have to start at the top again to tweak some things. My main point is I find you need to correct the exposure before you can correct the white balance, contrast, and saturation. This is just from experience, not theory, I shoot in all kinds of light at weddings - 2500K to 12,000K and mixed lighting. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
WaFp Goldmember 1,076 posts Likes: 37 Joined Jul 2009 Location: West Sacramento, CA More info | Jan 06, 2010 00:56 | #10 LR2 - top to bottom works here. Occasionally I get lazy and just hit "Auto" -- Trent
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jan 06, 2010 07:45 | #11 tim wrote in post #9334114 What I mean is top to bottom will work, but you'll probably go top to bottom then have to start at the top again to tweak some things. Agree. "I think the idea of art kills creativity" - Douglas Adams
57hardtop Senior Member 760 posts Joined Mar 2008 Location: Chicago More info | Jan 18, 2010 13:23 | #12 tim wrote in post #9334114 What I mean is top to bottom will work, but you'll probably go top to bottom then have to start at the top again to tweak some things. My main point is I find you need to correct the exposure before you can correct the white balance, contrast, and saturation. This is just from experience, not theory, I shoot in all kinds of light at weddings - 2500K to 12,000K and mixed lighting. René Damkot wrote in post #9335359 Agree. Even the sharpness/NR can be affected by a (pretty big) WB correction for instance. +1 Roger
| Latest registered member is Mihai Bucur 1154 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
