Thread started 05 Jan 2010 (Tuesday) 15:45
Orion Nebula Pic - Need advice for improvement
JaredBush
Jan 05, 2010 15:45 |  #1
I took this last night... The focus wasn't off but the images were still fuzzy. I am using the following setup:
*Aligned and tracking using a EQ5 PRO Equatorial mount
*8"SCT
*32mm Eyepiece
*Mounted using a tele-extender
*7D camera
*Focused on nearby stars using liveview
*Mirror Locked up
*Bulb mode using anywhere from 1 second to 30 seconds
*Remote activated
Results were all the same... fuzzy/blurry images... like below. Was there just too much camera shake? Was the atmosphere to active? What can I do to improve the image quality?
IMAGE: http://i579.photobucket.com/albums/ss236/ForumRiderUSA/Telescope%20Photos/OrionNebula.jpg
Canon 7D (Gripped) - Canon EF 24-70mm f/2.8 L USM - Canon EF 100-400mm f4.5-5.6 L IS USM - Sigma 50mm f/1.4 EX DG HSM
Sigma 10-20mm F4-5.6 EX DC HSM - Tamron SP 90mm f/2.8 Di Macro - Canon Speedlite 430EX II
Calumet Genesis 400wt Lighting Kit - Manfrotto Tripod/Velbon Monopod - Skywatcher 8" SCT
Michael_B
Joined Sep 2009
Jan 05, 2010 16:06 |  #2
Looks like OOF..but you said it was in focus, so who knows. Did you stack, or is this one single image. I wanna say in-camera noise reduction may be a problem too, I dunno as I never have used that feature.
How low was the constellation in the sky? Typically the best time to observe/image is when your target is at or near directly overhead. Less atmospheric turbulence then.
My Gallery (external link)
50D, 18-55 IS, 70-200 f4L[COLOR=black], 430EX II, BG-E2N, 200-400 IS USM L w/1.4x..thats right, getting ready.
Nighthound
Gallery: 224 photos
Best ofs: 24
Jan 05, 2010 16:13 |  #3
You've got some drift occurring in your tracking which can account for at least some of the blur. A few initial questions before I make suggestions:
1- Did you allow the telescope to "cool down" or equalize the internal tube temperature with the outside temperature before shooting? That time can vary depending on the amount of difference between the two.
2- What method did you use to confirm focus?
3- Has this telescope been collimated recently?
Steve
JaredBush
Jan 05, 2010 18:51 |  #4
Nighthound wrote in post #9331071 (external link)
Yea, I let the scope cool for a few hours... I focused on near by stars using live view and also remote shooting on my laptop. The scope is collimated, looking through the eyepiece you can tell it achieves perfect focus. It was pretty high in the sky and this was a snapshot for ~30 seconds.
I know i'm not going to get crazy photos (like others on this forum) with the equipment I have but should they be better then this? No?
I have gotten pretty sharp detail before using the same method, example:
IMAGE: http://i579.photobucket.com/albums/ss236/ForumRiderUSA/Telescope%20Photos/JupiterStack.jpg
IMAGE: http://i579.photobucket.com/albums/ss236/ForumRiderUSA/Telescope%20Photos/m13a.jpg
Any recommendations?
NovaTJ
Jan 05, 2010 19:49 as a reply to  @ JaredBush's post |  #5
I don't know where you live or where the images were taken, but I was out the last two nights in Virginia trying to image Orion, and M31 and had to give up due to the 20+ mph winds. To me, your focus looks close as you can make out the three stars in the center. Perhaps try shorter exposures and vary your focus ever so slightly between images looking for the best.
Greg
Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
Jeff
Jan 05, 2010 20:29 |  #6
Maybe try without the eyepiece in there? I've never had good luck with ep's in the train and if you can eliminate one possible source of problems it's worth the try.
Also, is this a 100% crop we're looking at?
Jeff
70D | Tokina 12-24 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: QHY268m, Astronomik Deepsky LRGBHaO3S2 filters, Meade 10" SCT, Astrotect 130EDT APO (.8x), iOptron CEM60 to keep it all off the ground.
MY AIRPLANE PICS (external link) | MY ASTRO PICS (external link)
Nighthound
Gallery: 224 photos
Best ofs: 24
Jan 05, 2010 21:02 |  #7
Your M42 image shows movement, getting to the source of that movement would be step one. Any movement at that magnification will cause blur. Periodic error, a light breeze or poor seeing conditions could all be a culprit. It's easy to assess seeing conditions through the eyepiece, if the stars in the trapezium are twinkling like crazy you're probably not going to get great clarity regardless of how well focused you are. On a steady night I would start with a very short exposure and slowly increase the time until you begin to see star distortion from movement. Then I would back it down just enough to get those stars nice and round. I would shoot 30 or more exposures like that to stack. If you see movement at 1-15 seconds you are likely getting some periodic error or your alignment is way off. The clarity in your Jupiter shot is very nice but it's also a fraction of a second exposure so it's not apples to apples with your M42 shot.
Also, precise balance of your rig in both directions with the camera attached is very important to how your mount will perform during extended exposures. Learning to drift align my mount and properly balance it had a huge impact on the quality of my images and the ease of acquiring them.
One minor note worth mentioning, shooting afocal adds more glass to the light path and in addition the quality of that eyepiece and the glass within has an effect on image quality. Have you tried long exposures shooting prime focus, removing eyepiece, and diagonal if you use one? SCTs by design are "softer" so removing anything that might compound that can't hurt.
If you have collimated the scope via a star test at high magnification then you can be confident the scope is collimated. I personally would not rely on visual focus on an object to determine proper collimation of an SCT. Even a slight misalignment can compromise detail. Here's a great reference, you may already have it:
http://astrosurf.com/l​egault/collim.html (external link)
I hope this helps in some way.
Steve
JaredBush
Jan 05, 2010 21:05 |  #8
Tons of great advise and info guys! Thanks...
Adrena1in
Jan 06, 2010 06:14 |  #9
Like Jeff, my initial suggestion would be to remove the 32mm eyepiece. I've never got good results using EP Projection, and I think it would certainly account for the Chromatic Aberration. The tele-extender might account for some of it too. I'd go with Prime shooting first off, then try the tele-extender and compare the two.
Another thing about EP imaging - I've no idea of the mathematics, but what difference would adding a 32mm eyepiece make anyway? Would it magnify that much?
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
Footbag
Jan 08, 2010 13:36 |  #10
Lose the EP and tele-extender. Get a T-ring and adapter. For around $30 you will improve your images considerably. EP projection is only good for planetary or solar system. Not Deep Sky.
Here's a recent image I took of the Orion Nebula with an 8" SCT at Prime Focus.
IMAGE: http://i288.photobucket.com/albums/ll175/Footbag01/Orionlowres.jpg
Adam
My Astrophoto Gallery (external link)
The Astro Imaging Channel (external link)
Celestron
Jan 08, 2010 22:28 |  #11
Footbag wrote in post #9352758 (external link)
Beauty of a picture Footbag !
Footbag
Jan 09, 2010 08:45 |  #12
Celestron wrote in post #9356008 (external link)
I should've said it was shot with a Celestron CPC-800 @F-6.3. Wedge mounted. A combination of exposures, but no more then 45 minutes total. I then had to do some layer masking in Photoshop.
Adam
Nighthound
Gallery: 224 photos
Best ofs: 24
Jan 09, 2010 09:53 |  #13
Great work all the way around Footbag.
Steve
5,621 views & 0 likes for this thread, 8 members have posted to it.
1097 guests, 120 members online
