Thread started 06 Jan 2010 (Wednesday) 00:26
User error with 7D causes bad pictures LOL
gdl357
Jan 06, 2010 00:26 |  #1
I just can't get decent indor peicture where my 50D had no problems doin it. I have way more noise with my 7D. I am dissapointed. I wonder if there is something wrong with my camera...unless it really is me.
This is with a 70-200 2.8 IS on a tripod with a 580 EX II in an umbrella on the right front of the subject. Subject 20 feet away. Horible.
"A mind once stretched by the imagination never regains it's original form."
:p Gear List
sportsshooter50
Jan 06, 2010 00:32 |  #2
Have you tried sharpening the photo?
krb
Jan 06, 2010 00:33 |  #3
I agree that it doesn't look right but I'm a little confused by your choice of settings. 1 second exposure at f/2.8 and ISO 400 while using a flash? Looking at teh shadow on teh background it seems like the 580 should have been closer to her.
-- Ken
Gear list
speedline_fc
Jan 06, 2010 00:33 |  #4
Your exposure seems a little screwy (that's putting it nicely)
# Exposure Time (1 / Shutter Speed) = 1/1 second ===> 1 second
# Lens F-Number / F-Stop = 28/10 ===> ƒ/2.8
# ISO Speed Ratings = 400
a shutter speed of "1 second" is most likely capturing a lot of subject movement
how about posting some daylight shots of static objects (trees, signs, rocks) with plenty of sunlight?
My Flickr (external link)
https://photography-on-the.net …php?p=9822373#p​ost9822373
Invertalon
Jan 06, 2010 00:35 |  #5
Yeah, with a flash you should be able to shoot much higher shutter speeds. One second? Why?
And you can correct WB easily from RAW.
Looks to be serious user error here..
-Steve
Facebook (external link)
callaesthetics
Jan 06, 2010 00:36 |  #6
I first had the same trouble.
Using a dedicated focus point is the proper way to shoot portrait.
Also turn off all noise reduction settings.
Now i get very sharp images.
This one was also shot on a 7D and 2 speedlights thru softbox umbrellas.
Just keep shooting and adjusting, this camera can do really great things.
HTTP response: NOT FOUND | Redirected to error image by MYSPACECDN
5DmkIII, 200 2.8L II, 135L, 100L, 50L, 35L, 40 2.8,17-40L, Tamron 45
www.facebook.com/camxi​ongphotographer
gdl357
Jan 06, 2010 00:37 as a reply to  @ speedline_fc's post |  #7
Umbrella was 3 feet away from her pointing downwards and to the wall at 45deg angle.
All I did was put my camera to auto ISO and AV and took the shot. The 580 was at EC +2 and set to slave and triggered from the 7D.
I have "Standard" set to 4 = sharpening, +1 = contrast. I will put these back to default. ISO Noise reduction was set to "standard"
:p Gear List
sportsshooter50
Jan 06, 2010 00:37 |  #8
By the way, you exif data shows 1 second. Photographing a person at that speed, even with a tripod, can be tricky. Plus the f-stop is 2.8. That makes for a very shallow depth of field.
krb
Jan 06, 2010 00:40 |  #9
gdl357 wrote in post #9334147 (external link)
Don't use Av with a flash. It does the metering and selects the shutter speed (and ISO in your situation) based only on the ambient light. Try using Tv at 1/100 or faster. You may also find that auto ISO doesn't work well with flash but I have no experience with that.
-- Ken
Gear list
themadman
Jan 06, 2010 00:42 |  #10
As others have stated... exposure 1sec???
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
gdl357
Jan 06, 2010 00:47 |  #11
themadman wrote in post #9334174 (external link)
I shut all the lights off in the house and had a little light coming from a window on the oposite side of the umbrella, then I shot the camera/flash to get what you see.
The place i am shooting has fleurecent lights. i was trying to see if I could get away without having them turned on.
:p Gear List
jxs1984
Jan 06, 2010 00:54 |  #12
IS turned off?
Nikon D810 · Tokina 16-28mm f/2.8 · Sigma 35mm f/1.4 art · Nikon 85mm f/1.8g
flickr (external link), facebook (external link)
, gear & feedback
callaesthetics
Jan 06, 2010 00:55 |  #13
gdl357 wrote in post #9334189 (external link)
even if you shoot at F4 and 1/250th iso100...that should be enough to kill the ambient lights.
AlanU
Gallery: 144 photos
Jan 06, 2010 00:55 |  #14
Your mistake is that you used AV mode.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
gdl357
Jan 06, 2010 00:59 |  #15
jxs1984 wrote in post #9334209 (external link)
IS turned off?
The IS on the 2.8 70-200 detects tripod. No need to turn it off. It actually helps having it on to help with tripod vibration, as per the manual.
:p Gear List
7,395 views & 0 likes for this thread, 32 members have posted to it.
Latest registered member is Moonraker
773 guests, 172 members online
