Thread started 06 Jan 2010 (Wednesday) 10:02
Why I do not use flash meter.. Do you?
akoloskov
Jan 06, 2010 10:02 |  #1
I found this device useless in the studio and out.. Now, with all digital and instant photo preview, do you really use it?
Have a small post regarding the subject on on my blog (external link)
Would be glad to hear your opinion..
Alex Koloskov
AKELstudio, inc (external link) photographer
www.koloskov.com (external link) http://akelstudio.live​journal.com (external link)
breal101
Jan 06, 2010 12:03 |  #2
I use it a lot less than I did in my film daze, it was a part of me then. I would be driving home from a shoot or walk into a restaurant on the way home and realize that it was still hanging around my neck. I still use it for a basic set up for ratio but since I shoot tethered so much now it isn't as valuable as it once was.
"Try to go out empty and let your images fill you up." Jay Maisel
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 06, 2010 12:06 |  #3
I still use a flashmeter. Using the review screen and histogram as a preview is fine, but I still like to calculate my ratios in case I want to repeat them later.
hawkeye60
Jan 06, 2010 12:07 |  #4
I always use it for the basic set-up, it saves a lot of time over the trial and error method. But I do make small adjustments after the fact based on the preview.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
sapearl
Gallery: 243 photos
Jan 06, 2010 12:12 |  #5
Hi Alex - I don't use a modern digital flashmeter - but I do have an old analog light meter that I will use outdoors for incident meter readings. It does a terrific job and has enabled me to produce some very good portraits. Essentially it's the same thing, just the old analog variant.
I like to do a lot of bridal portraits and groups in open shade. Typically the camera is set on Manual. Taking an incident reading at the b/g's position, I'll get an excellent reading of the amount of light falling on the white dress & black tuxedo, instead of a reflected measure from one or the other, which will be totally different.
Once I have my accurate ambient reading, I'll set my flash to output light that is 1/2 to 1-stop less than the ambient for a pleasant, modelled effect. If I did studio work I'd probably use the digital meter a lot as Gonzo and Hawkeye have indicated. It's nice to know where your starting point is, and then tweak from there.:D - Stu
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
sapearl
Gallery: 243 photos
Jan 06, 2010 12:44 |  #6
Read part of your blog Alex - interesting comments.... some of it I agree with, parts I don't.
The flashmeter is just another tool in the kit, a different sized wrench, etc. I grew up with a hand held meter, owning my first one in 1969. It helps some to do things faster, easier and more creatively while other folks can figure the exposures in their heads, or with a glance at the histogram. It's whatever you're comfortable with that works.
matonanjin
Jan 06, 2010 13:30 |  #7
sapearl is right in that it is another tool. One can choose to use it or not.
It also depends a lot on what one shoots. I shoot sports both indoor and out. Lot's of difficult lighting. I would be in deep trouble without my meter.
My Web Site (external link)
My Equine Photography Blog (external link)
My Stuff and Feedback
Wilt
Jan 06, 2010 14:49 |  #8
With a light meter I can quickly do these things that I could not do as rapidly (or at all) without a meter...
1. Set the relative intensity of shoot-thru gelled light thru a background with one test shot
2. Set the dynamic range of the lighting so that highlights:shadows will not exceed what an offset press printer can reproduce in a printed magazine ad or brochure
If you do not shoot professionally, you can get away without a meter. There are pro applications which cannot be done (like item 2 in the list) with no meter. And other things (like item 1 in the list) could only be done experimentally, wasting the client's time and/or taxing their patience.
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jan 06, 2010 14:57 |  #9
akoloskov wrote in post #9336084 (external link)
From your blog:
After I’ve got it in hands and played in studio and out, I found that I do not need it at all.. It was completely useless in a studio, as I always connect camera to a computer, and after first test shot I can clearly see where I need more or less light. And, looking on the image directly I do have much more info where and how much I need to change lights comparing to dry numbers flash meter tells me.
So what do you use when you're in a situation not connected to a computer?
gonzogolf
Gallery: 561 photos
Jan 06, 2010 15:04 |  #10
Or if your laptop isnt calibrated..
rvdw98
Jan 06, 2010 15:10 |  #11
RDKirk wrote in post #9338179 (external link)
gonzogolf wrote in post #9338223 (external link)
The camera's histogram?
Roy
gonzogolf
Gallery: 561 photos
Jan 06, 2010 15:16 |  #12
rvdw98 wrote in post #9338267 (external link)
Yes, but that's not the computer, its the camera.
akoloskov
Jan 06, 2010 15:48 |  #13
Thanks for responses to all, I see your points.
I agree, if you get use to it, you'll be using it with the great success. And the opposite is true as well: if you have enough experience, you "feel" the lights (especially if this is your studio strobes), you can get great results without a flash meter. Especially if you soot exteriors and interiors using multiple exposures (aka HDR) photography, like I do. The result (clients said, not me:-) is far better that you can do by "conventional" way.
Also, if you have a laptop (it does not need to be calibrated, histogram, color temp, etc will tell you everything you need to know) Also, if you know how to read your camera histograms (which I never do, it is not accurate, it based on a JPEG, not RAW, regardless on what format you are shooting) it helps a lot.
I never studied any photography lessons, courses or college. Really, what I know and do I "invented" myself, just by looking on photography I like and trying to get the same result. So, you can call me completely uneducated photographer :-)
So, flash meter was not a part of my education, and I guess it never will be a part of my professional carrier. But, who knows.. never say never :-)
P.S I also really like to eat gene modified products, the future after them! :-))
Alex Koloskov
buurin
Jan 06, 2010 16:03 |  #14
I use it. I mostly shoot on location (i.e. not tethered) so I find it pretty valuable.
Im still new & pretty bad at guessing where I'm at when it comes to flash exposure. Its nice to have a good starting point.
I never use it for ambient - but I keep telling myself I'm going to start.
B
30D ● 5D ● Canon 24-70/2.8L
Canon 17-40/4.0L Canon 50/1.4 ● Canon 100mm/2.8 Macro ● 2xVivitar 285HVs ● 430EX ● Cybersync Flash Triggers ● AB800 ● AB400 ● Vagabond II
Mark_Cohran
Joined Jul 2002
Jan 06, 2010 16:11 |  #15
I use a flash meter a lot in studio. It lets me quickly set up by basic exposures and flash ratios. Like any other tool, it can be be quite useful if it's used for the right purpose in the right situation. I'd much rather spend 5 minutes setting up my initial flash settings and ratios than much more time trying to do it by trial and error.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
5,032 views & 0 likes for this thread, 17 members have posted to it.
2689 guests, 149 members online
