Thread started 07 Jan 2010 (Thursday) 11:27
Which zoom setting for flash on bracket?
Warl0rd
Jan 07, 2010 11:27 |  #1
What zoom setting do you guys use when you have the flash mounted on a bracket + diffuser?
What would be better? zoomed in or zoomed out?
Paulo
http://www.flickr.com/​photos/warl0rd (external link)
Canon 450D (XSi) + Grip | Canon 80D | EF-S 10-22 | EF 24-105 L IS | EF 100mm Macro | MP-E 65mm 1-5X | EF-S 18-55 IS STM | EF-S 55-250 IS | Takumar 55mm 1.8 | MT-24EX | Metz 48-AF1 | YN460 II | Kenko DG Auto ET | Kata 3N1-20 DL | Lowepro SlingShot 100 AW | Mitsai JDC195 | Manfrotto 190XPROB + 484RC2
LordV
Jan 07, 2010 13:10 |  #2
Warl0rd wrote in post #9344271 (external link)
Assuming you mean the flash zoom thingy ?
I just leave it alone- I did do some tests with manual zoom on the flash and it didn't seem to make any difference.
Brian v.
Macro Hints and tips
Warl0rd
Jan 07, 2010 18:43 |  #3
LordV wrote in post #9345015 (external link)
yep
on the field i couldn't see any difference either, but I think I'll do some studio tests just to be sure :)
Paulo
LordV
Jan 08, 2010 00:47 |  #4
Warl0rd wrote in post #9347271 (external link)
yep
I'm often using my flashes in a bounce or rotated head position which seems to lock the zoom anyway.
Brian v.
Warl0rd
Jan 08, 2010 04:30 as a reply to  @ LordV's post |  #5
yes I know.
if you have the head at 90º they zoom to cover the lens focal distance, but if you move the head to another position they zoom (out or in, can't recall, but probably out to cover more area). So if you use the flash on the bracket you probably have the the head on a non 90º, thats why I asked which zoom setting you guys use.
I think if the zoom is out, the light should be more diffuse, but you are probably wasting power. Now I don't know if you need the diffusion since you already have the diffuser right next to it
Paulo
John_B
Gallery: 178 photos
Jan 08, 2010 05:53 |  #6
You can manually set the zoom, this way even if you rotate the head (at least on my 580ex) it stays at the same zoom setting. When the head is turned, I set the zoom manually but the difference at such a small distance is very small ;)
click to see (external link)
Warl0rd
Jan 08, 2010 06:55 as a reply to  @ John_B's post |  #7
I know I can set it manually, and thats exactly what I'm asking ;)
Do you guys zoom in or zoom out ?
Paulo
1,556 views & 0 likes for this thread, 3 members have posted to it.
1093 guests, 118 members online
