Thread started 21 Jun 2005 (Tuesday) 09:14
Your choice of Monopod?
hotled
Joined Jun 2005
Jun 21, 2005 09:14 |  #1
I have the RebXTand going to use a Sigma 70-200 f/2.8, just wondering what an inexpensive but useful monopod is.
I looked on e-bay and there are hundreds to choose from anywhere from 15.00-125.00.
Ball mount , adjustable, etc... what specs and size do you prefer?
Ken
Canon 7D | ∑ 17-50 f/2.8 | Canon EF 50 1.8 | Σ 70-200 2.8 EX DG OS HSM| YN-568EX II | YN-622
My Fickr (external link)
Todd ­ Jacobsen
Jun 21, 2005 09:34 |  #2
Typically, the monopods come without heads. Depending on how you plan on using the monopod will impact your choice. Example: Do you plan on hiking (moving a lot) ? Do you only use it at sporting events, plays (usually static at same spot)?
If you ever plan on shooting portrait with the pod (and without a bracket), you will need to purchase a head as well to allow you to swivel 90 degrees. Typically, this will add noticeable weight to the pod. I consider my monopod(s) as add-ons to the camera and weight is important to me. I chose a graphite rod. I do own a head for the pod and the weight difference is quite noticeable. When I use my bracket with the pod, I do not use the head (my bracket can do portrait/landscape shots).
My pod also works as a walking stick while doing landscape/animal photography.
Todd Jacobsen
20D / Rebel T2
EF : 28 f1.8/ 50 f1.4/ 50 f2.5 Macro/ 85 f1.8/ 20-35 f3.5-4.5 USM
EF-L: 16-35 f2.8/ 24-70 f2.8/ 70-200 IS f2.8 / 100-400 IS f4.5 / 180 f3.5 Macro
EF-S: 10-22 f3.5-4.5 USM
cc3chan
Jun 21, 2005 09:34 |  #3
I got the basic Manfrotto monopod (679). It's fairly light but quite strong. Carried it with my gear for 7.5 hours at the zoo and it felt fine. Actually felt like the lightest part of my kit. I use my 20D with 70-200 2.8 lens and there's no flexing of the monopod. Tried it with a borrowed 100-400L as well. Great quality for the price.:)
Canon EOS 20D
Canon EF 100-400 F4.5-5.6L IS
Canon
EF 50mm F1.8 II
Tamron 28-75mm F2.8 XR DI
hotled
Joined Jun 2005
Jun 21, 2005 09:41 |  #4
I will be using at indoor and outdoor sports and not in a static position. I may be shooting some race action soon to.
Ken
Camo ­ 757
Jun 21, 2005 10:02 as a reply to  @ hotled's post |  #5
I have the 679 too. It's a bit short as I am 6 4" but other than that I love it.
60D gripped/Tamron 17-50 VC 2.8/Tamron 60mm Macro 2.8/Canon 70-300mm IS
lostdoggy
King Duffus
Joined Aug 2004
Jun 21, 2005 11:55 |  #6
I also have the 679 w/ Action grip ball head and 390 RC2 pan & tilt head. I'm 5' 9" and I'm nowhere near the full extention of the pod, especially since the Action Grip adds another 7" to 8" to the pod. With the 20D and the 70-200 f/2.8, I would make sure the pod will support the combo. At minimum you'll need the Bogen MiDi RC2 ball head. The great thing about this pod is it is strong enough to be used as a walking stick. Oh, I don't recommend the action grip for long walk because it is heavy. For a lightweight combo the 3d Magnisium is a good choice at 0.6lb.
Jack ­ W.
Joined Jun 2003
Jun 21, 2005 12:02 as a reply to  @ lostdoggy's post |  #7
I use this Gitzo monopod:
http://www.bhphotovide​o.com …ails&Q=&sku=170​883&is=REG (external link)
With this ball head:
http://www.bhphotovide​o.com …ails&Q=&sku=272​449&is=REG (external link)
20D, 30D, 500f/4L IS, 300f/4L IS, 300f/2.8L IS, Canon 1.4TC, Canon 2xTC, 70-300IS, 17-85IS, EFS 10-22, Sigma 150 Macro, 3021PRO, RRS BH-40LR, Gitzo 1325, full Wimberley Head v2, Wimberley Sidekick, and a bunch of other stuff. :-)
arpi
Jun 21, 2005 18:03 as a reply to  @ Jack W.'s post |  #8
I got the Gitzo 1588 with the Manfrotto head 3229 (quick release)
the g1588 is built like a tank but it is not heavy. in a couple of occasions I found myself alone and with not defense weapon. with this monopod I feel safe! if an angry deer shows up, I am ready for a fight! :)
"if you don't have experience you'll fall in love"
Daddy Yankee
gasrocks
Jun 22, 2005 09:15 as a reply to  @ arpi's post |  #9
My old reliable monopod is a Bogen 3016. If you want to travel light, get the new Bogen Digi676B. Almost as tall, a lot lighter and compact. Very portable. The monopod to carry if you sometimes wish you had one along.
Rob612
Jun 22, 2005 09:31 |  #10
Manfrotto 680 here. I like the smaller sections that build the things up so when folded is shorter.
Danny ­ Boy
Joined Jul 2004
Jun 22, 2005 10:25 |  #11
I have the Manfrotto 680B with the 3229 head. I don't really use the head much but the monopod is excellent. It's not too heavy and supports my 20D w/ 100-400L w/ no problem. I'd recommend it. It works especially well when I'm taking pictures of my kids playing sports and the larger lenses are required.
Dan
jojiboy
Jun 22, 2005 13:31 |  #12
I have the Manfrotto 679B with the 3229 head. I'd recommend it also.
hotled
Joined Jun 2005
Jun 23, 2005 00:47 as a reply to  @ jojiboy's post |  #13
Silly question, but what are the thread size on the Rebel XT 1/4-20 ?
Ken
lostdoggy
King Duffus
Joined Aug 2004
Jun 23, 2005 01:26 |  #14
All tripod mount on the camera side is female 1/4 20. The Bogen monopod has bothe 1/4 20 and 3/8 16. The 3/8 16 retracts to expose the 1/4 20 so you can mount the camera directly on the monopod. The problem with that is it is difficult to take portrait while mounted on the pod.
If you want to look really cool Feisol makes a carbon fiber monopod for $100:
http://www.thresholdco​ncepts.com/photo-cm1401.htm (external link)
But I personally like a metal Monopod especially when I need it as a baton:
http://www.adorama.com …nfo=bogen%20679​&item_no=4 (external link)
JoshBowers
Jun 25, 2005 23:38 |  #15
I also use Manfrotto 676B Digi Monopod.
about $30 at newegg.com. Very light, but strong....
I actually broke it a few weeks ago, it reminded me tomuch of a telescoping lightsaber:o :rolleyes:
The latches all came apart... But I got it back together. Took about an hour to figure out how the thing worked, but it's fixed.
So... Just a tip.... It's not a lightsaber.
ChronicDaydreamer (external link)
3,306 views & 0 likes for this thread, 18 members have posted to it.
1012 guests, 121 members online
