Thread started 09 Jan 2010 (Saturday) 13:56
advice needed regarding indoor lighting
ayoyoayoyo
Jan 09, 2010 13:56 |  #1
it seems to me that when indoor, my photos are underexposed relative to what my eyes see.
why is this the case and how do i compensate for it??
thx
JerelXTI
Jan 09, 2010 23:46 |  #2
Have you set your WB? I've found that setting a custom WB helps out alot for me.What type of camera are you using? Using a flash will help. If you can post an example. Oh yea I make sure I check my in camera exposure meter and adjust from there.
Canon 5D MK III, 24-105L,Canon 7D, Rebel XTI, Kit Lens 18-55,50mm f/1.8 II lens, 55-250mm f/4-5.6, 18-135mm f/3.5-5.6, Canon BG-E3 Battery Grip, Opteka IR Remote, X-Rite Colorchecker,580 EXII,430EXII
My Flickr (external link) / My Website (external link) / Facebook (external link)
toxic
Jan 10, 2010 03:13 |  #3
Remember that your camera is only seeing the light for a fraction of a second, whereas your eyes get a continuous image, so lighting will always look better to you than it does to the camera.
You need to increase your exposure or use a flash.
ayoyoayoyo
Jan 10, 2010 04:13 |  #4
flash makes the photo looks weird and i dont like it at all so i dont use it.
i got a 450d with a 18-55 kit lens (teh suxxor i know) its max aperture is f/3.5. with a fluorescent ceiling light i need 1/5 shutter speed for it to look ok @ iso400.
so i guess the lens is not for indoor??
KCMO ­ Al
Jan 10, 2010 13:22 |  #5
I don't know about your camera's high iso capability but I always use iso 1000 or even 1600. The 24-105 is f/4.0 and it works very well, although my 35 f/1.4 is ideal for this application (but expensive). I also have the advantage most of the time of having good window light where I do most of my shooting. At night, a flash with a diffuser gives near-natural light. Simple bounce flash works pretty well too, depending on your environment. Fluorescent light varies tremendously in color temperature so is difficult to use as a predictable light source.
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D Mk III
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
number ­ six
fully entitled to be jealous
Jan 10, 2010 16:32 |  #6
ayoyoayoyo wrote in post #9363265 (external link)
Actually, your 18-55 IS lens is amazingly good for the price. It's quite sharp and the IS works well. But yes, it's not a low-light lens.
Try ISO 800 - that'll let you use 1/10 shutter under the same lighting. As long as your subject isn't moving, you should be able to handhold that just fine with the IS on.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
neilwood32
Jan 10, 2010 17:09 |  #7
If the images are under exposed at those settings, the easiest way to improve them is more light.
And it doesnt have to be flash although flash done properly does work very well.
And dont be afraid of ISO 800+ - anything to get a good shot!
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
ayoyoayoyo
Jan 11, 2010 01:18 |  #8
using iso800 gives me weird purple specks in the photo. i hate them so much.
neilwood32
Jan 11, 2010 06:58 |  #9
Those weird purple specks can be removed using post processing software (DPP, PS, LR etc).
One thing to note is that the noise (the specks) doesnt look nearly as bad printed or when the image is resized (downwards for web use). It is only really horrible when viewed at 100% on a monitor imho.
Annie ­ Social
Joined Sep 2009
Jan 12, 2010 14:50 |  #10
Is this guy for real or is he some sort of troll? I knew more than this when I was 8. When I decided to take up photography, I checked out a book from the library; maybe ayoyoayoyo needs to do the same!
Annie
"I've wrestled with reality for thirty-five years, and I'm happy, Doctor; I finally won out over it!" -Elwood P. Dowd
JCH77Yanks
Gallery: 28 photos
Jan 12, 2010 15:08 |  #11
Get a speedlite and bounce that flash off of a white wall or ceiling and you will become a believer. Start using off camera flash and it gets even better.
Joe Halliday
7D | XT | 10-22 | 24-105 f/4L | 28 1.8 | 50 1.4 | 85 1.8 | 580EXII | 430EXII | 430EX | Flickr (external link)| 500px (external link) |
Dial "M" for Manual.
ckckevin
Jan 12, 2010 15:13 |  #12
I think the OP probably using one of the auto modes. in those mode, once you have a side subject that is really bright, it'll tends to make the other part of the image underexposed.
Kevin life= learning
500D, Canon 10-22mm, Tamron 17-50mm 2.8, Canon 60 macro, Canon 85mm 1.8, Sigma 8mm 3.5, Sigma 30mm 1.4, Sigma 50-150mm 2.8, Kenko SP300 1.4x, efs extension tubes, 580EX, and lens that i don't like
number ­ six
Jan 12, 2010 18:16 |  #13
Annie Social wrote in post #9379955 (external link)
:rolleyes:
"Be seeing you."
neilwood32
Jan 13, 2010 07:24 |  #14
Remind me to ignore you if you ever have a problem or maybe i will just refer you to your library!:rolleyes:
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jan 13, 2010 08:55 |  #15
ayoyoayoyo wrote in post #9369394 (external link)
First of all, it would be really helpful if you told us what your subject is?
Overhead fluorescents are probably the worst light sources that you can use. They're positioned to put shadows under the eyes, & are lacking in red tones.
Underexposed ISO 800 will not look as good as properly exposed ISO 1600, except that you'll always have problems with noise in the black areas. If you're shooting on Auto, think about setting a manual exposure:
Need an exposure crutch?
Why?
Post #47
Finally, if you insist on using only available darkness, then maybe you should consider getting a faster lens? The 50mm f/1.8 isn't all that expensive.
2,060 views & 0 likes for this thread, 11 members have posted to it.
2794 guests, 140 members online
