Rebecka Senior Member More info Post edited over 2 years ago by Rebecka. | Jan 10, 2010 07:36 | #1 That is a 100% crop (taken as a screenshot within Bridge, so no PP at all) of a sunset I took on Friday. Unfortunately there is a lot of clipping going on, in particular a nasty red outline around the top of the sun. I am pretty sure there was nothing I could have done in camera to avoid this while still exposing for the whole scene and not just the sun alone. So given I am left with this problem, what is the best way of dealing with it? Any tips and suggestions would be appreciated. Thanks. Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Jan 10, 2010 08:20 | #2 GND filters... "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
nprdavid Senior Member 977 posts Joined Aug 2008 Location: Concord, NC More info | Jan 10, 2010 16:07 | #3 If you are talking about pp then you could use your eliptical tool and make a selection slightly smaller than that of the sun. Copy to another layer. Hoosier Daddy
Jan 11, 2010 17:45 | #4 argyle wrote in post #9363925 GND filters... I did think of that after, but I was happy with the exposure of the sky. The problem was caused by the high contrast between it and the sun so to get a properly exposed red sun the sky would have been too dark. nprdavid wrote in post #9366345 If you are talking about pp then you could use your eliptical tool and make a selection slightly smaller than that of the sun. Copy to another layer. while working on the lower layer. Then you could clone around the edges with areas just past the sun. or you could transform the selection by scale to where it covers what you don't want in there. might not even be what you were asking. That is the kind-of thing I was looking for, so thanks for the suggestions. Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Jan 12, 2010 17:01 | #5 mij wrote in post #9374003 I did think of that after, but I was happy with the exposure of the sky. The problem was caused by the high contrast between it and the sun so to get a properly exposed red sun the sky would have been too dark. That is the kind-of thing I was looking for, so thanks for the suggestions. I was thinking of applying a blur to the sun to try to both eradicate the red border and smooth out the banding as it goes from red to yellow to white. But before doing anything I thought it seemed such an unavoidable problem with digital photography that there must be a best solution that people apply. Given how I was not able to find anything searching on here or Google maybe it is not though? I guess I will just have to try the different ideas out and see which works best. Michael. Sorry about that...I thought you were asking about how to avoid the problem at the time of capture. Your best bet would be to apply a blur to the image, then fill the layer mask with black. Paint over the sun's edge at the area's in question with a small white brush and this should do the trick, or at least improve things. I gave it a shot to see how it would work, and with a lot more attention to detail I could probably work it. I spent maybe 30-seconds on it...the before/after is below. It's an improvement, but you could do better since you'd be more likely to pay closer attention to detail than I did, for obvious reasons.
Jan 12, 2010 18:50 | #6 That is quite a noticeable difference, especially for a quick example, so that looks a pretty good way to go. Will hopefully have the time to go back to those shots later in the week so will hopefully be back to show the results. Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
| Latest registered member is semonsters 1043 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
