Thread started 11 Jan 2010 (Monday) 21:16
Which comes out sharper, a screen image or a print?
MikeFairbanks
Jan 11, 2010 21:16 |  #1
Just wondering which is traditionally sharper, the image on the screen or the printed image.
Thank you. bw!
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jan 12, 2010 01:20 |  #2
I believe print is.
Gallery: http://tomyi.smugmug.c​om/ (external link)
themadman
Jan 12, 2010 01:33 |  #3
generally prints.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
FlyingPhotog
Cream of the "Prop"
Jan 12, 2010 01:54 |  #4
Interesting that you guys say print.
I think it's the other way 'round. You can push sharpening on screen to the point where it looks to be slightly too much, but you won't see it that "crispy" in the final print. Especially when you start to get up to 12x18s or larger.
Jay
chauncey
Jan 12, 2010 04:27 as a reply to  @ FlyingPhotog's post |  #5
Gotta agree with Jay on this one. Every tutorial I've ever seen on softproofing states that you must oversharpen that image...the very act of printing will soften it.
TattooedAffliction
Jan 12, 2010 04:30 |  #6
chauncey wrote in post #9377121 (external link)
Interesting. I was under the impression that prints will generally produce sharper images. I'll have to test that out.
Tom
Canon 5D MK II | 7D | 40D | EF-S 17-55 f/2.8 | EF 28-135 f/3.5-5.6
70-200 f/2.8L IS II USM |[COLOR=red] [COLOR=Black]24-70 f/2.8L USM | 580EX II
Elinchrom 2 & 4 D-Lite kits
Sekonic L-358http://www.airliners.n​et …otographersearc​h=PeterEde (external link)
sjones
Jan 12, 2010 04:43 as a reply to  @ TattooedAffliction's post |  #7
All I know is that my prints are unquestionably superior to anything on see on the screen.
May 2022-January 2023 (external link)
neilwood32
Jan 12, 2010 07:05 |  #8
Without testing it, I would say the screen image would be sharper (given the same workflow) and displayed at the same actual size.
This would be due to the nature of ink (being liquid there is a minute amount of bleed/spread) whereas a pixel is always a pixel and will never change size or shape.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jan 12, 2010 12:47 |  #9
I have a 27" monitor which measures (roughly) 24" wide x 15" high
It is resolution is 2560×1600, so about 106 dpi.
I regularly print at 300 or 600 dpi.
Either 300 or 600 > 106.
Printer has MUCH BETTER resolution, and therefore presents a much sharper image.
If anyone is using a monitor that displays 300dpi, I would be interesting in seeing it.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
René ­ Damkot
Jan 12, 2010 12:50 |  #10
According to DekeMcClelland, (IIRC), when print is viewed on print size, and image is shown on "print size" view in PSCS4 (with screen resolution properly set up and supported grapics card) or reduced to be 'print sized' at 100% view with older versions PS (using bicubic) the screen is showing slightly sharper. (because ink has dot gain in paper (again: IIRC))
Others disagree: Thread (external link)
Also: IMO, paper choice has a *lot* of impact.
Still have to test this out for myself, but sice my graphic card doesn't support any PSCS4 fancyness, I still do it the old "guesstimation" way ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
René ­ Damkot
Jan 12, 2010 12:59 |  #11
Radtech1 wrote in post #9379269 (external link)
Yeah, sure. And the printers native resolution might be 360 or 720ppi. And it might print 1440dpi or 5760 dpi.
But the question was which looks sharper, not which has a higher resolution. Not the same IMO.
It'd be interesting to do some tests, but how do you compare?
"I think this looks sharper". "No, I think this looks sharper" :lol:
number ­ six
fully entitled to be jealous
Jan 12, 2010 13:05 |  #12
I use a Mitsubishi CRT monitor and my screen images look sharper than my (or Costco's) prints when viewed at the same size and distance.
But maybe that's because the CRT has a couple of stops more dynamic range...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
HappySnapper90
Jan 12, 2010 13:15 |  #13
Screen definitively. Try using 2MP to make a print the same size as my 24" (diagonal) wide screen LCD. It will look pretty sad compared to my LCD monitor.
Screen is far sharper than print and takes fewer pixels. In many ways, LCDs are superior for image presentation than print. But LCD's of this range cost $300 and a 13"x19" print costs $5 or so.
I strongly disagree. The thing is your don't need a monitor to display 300ppi (not dpi). There's always the statement "don't use 100% view to judge IQ because that'd be the same as a huge print". Well look at what a 24" wide screen monitor can do for your 2MP at 100% view of a well captured image! It can make it look as good as viewing the whole image on the screen at the same time!
The reason printers many people send images to printers at 300 ppi is that a 100 ppi print would not look very good up close, yet you can do that with a 100 ppi view on your computer screen! LCDs are superior to print except for price and portability!
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Jan 12, 2010 13:15 |  #14
another factor is that light is produced by the monitor, and reflected by the print. the viewed surface of the screen is flat and smooth, the media that you print on is probably not, and will scatter some light at various angles, also affected by the source angle of the reflected light. All this adds up to less than crisp transitions from one area to another on the print, as seen by the human eye.
Thats the way I learned it anyway.
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
Annie ­ Social
Joined Sep 2009
Jan 12, 2010 13:33 as a reply to  @ birdfromboat's post |  #15
Remember that a lot of factors influence apparent sharpness of an image, such as contrast, brightness, relative "shininess" of media, viewing distance, and much more.
Annie
"I've wrestled with reality for thirty-five years, and I'm happy, Doctor; I finally won out over it!" -Elwood P. Dowd
1,149 views & 0 likes for this thread, 15 members have posted to it.
2623 guests, 154 members online
