Thread started 12 Jan 2010 (Tuesday) 13:40
5D Mark 2 Viewfinder
.mark.
Jan 12, 2010 13:40 |  #1
I've been looking into my next body to upgrade to and I am strongly leaning towards the 5d2. I've just been googling around and have found an image which shows the spread of AF points of the view finder
This image has had the "rule of thirds" imposed over the top. I'm shocked to see how clustered the points are. It barely seems worth switching from the centre point (ok, maybe I'm exaggerating a little bit!).
So I guess the point of this topic, apart from to express my surprise, is to ask 5d users how they manage with this and if it's limiting or am I overreacting? Bear in mind I've only ever shot with my 450D.
5DIII :: 15FE :: 16-35LII :: 24LII :: 50L :: 85 1.8 :: 135L :: 100-400L :: 430EX2 :: 580EX2 :: YN560II x2
flickr (external link) :: twitter (external link) :: 500px (external link) :: Facebook (external link) :: Gear list :: Project365 (external link)
gjl711
Jan 12, 2010 13:42 |  #2
.mark. wrote in post #9379570 (external link)
Thats been a complaint of the 5D cameras for a long time.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Ianfp
Jan 12, 2010 13:59 |  #3
I have absolutely no problem with the arrangement of focus points or the whole focussing system performance. Don't believe all you read, because you will note that most of the negative comments about the 5D2 focus setup are from folks who have never used a 5D2 let alone own one. Of course there are faster cameras, but if you want the ultimate in IQ and a very usable focussing system, the 5D2 is it! IMO
Ian
Nikon D850, 85mm f/1.4G
5D2
EF17-40 f/4.0 L, EF135 f/2.0L EF200 f/2.8L
EF24-105L, EF100 f/2.8L Macro. EOS-M, 22mm f/2
Hasselblad 500C/M, Planar 80mm f/2.8
justaf ­ IREMAN
Jan 12, 2010 14:00 |  #4
I'm ok with it when shooting portraits, I just go to the closest focus point and re-compose a little. With action type AI servo though It would be nicer for the focus point to be more spread out. It's a good thing I can crop the hell out of the image with little difference. It's one of those things that this camera lacks but I easily forget when I see the images taken with it.
current gear...1DIII, X-E1, X-PRO 1, X100, Lumix LX5, Fujinon 35 1.4, 85LII, 430EXII, 430EX....
past canon gear....XS, 7D, 2 5DII, 2 1DIII, , 18-55IS, 24-70L, 85 F1.8, 85LII, 35F2, 35L, 24L, 200 F2L, 580EXII....
sebr
Jan 12, 2010 14:03 |  #5
I must admit that I was suprised when I first got my 5D2, but ultimately I do not think it will matter that much. I was using center point on my 50D most of the time anyway.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
laydros
Jan 12, 2010 14:17 |  #6
Yeah, I almost exclusively use focus and recompose, but basically the 5D has one really big center point. That can be a really big problem with the 5Ds shallow DOF, and using a super fast lens wide open (think 85L.) Focus and recompose can be problematic because as you move, you are rotating a little. With a bigger DOF, not a problem, but with a razor thin DOF, you loose some focus. The D700 has a leg up on Canon on this one, not to mention it has a pro level AF system.
So yes, definitely a problem, and a major part of why people are clamoring for the 5D to get better AF, in addition to the fact it is fairly slow for a camera used by many pros.
BUT.. as others have said, it doesn't really bother me for what I shoot, mostly portraits and art.
Jason Hamilton - flickr (external link) - Twitter (external link) - laydros.org (external link)
Canon 5D, 24-85 f/3.5-4.5 USM, 35 f/2, 50 f/1.8 II, 85mm f/1.8 USM, 70-210 f/3.5-4.5 USM, 100mm f/2.8 Macro, 430EX
Nikon FE, 35/2, 50/1.8, 105/2.5 and Mamiya C220 Complete Gear List.
.mark.
Jan 12, 2010 15:13 |  #7
hmmm this has really got me thinking. One of my reasons for upgrading is low light shooting of friends/family at parties/events. Candid shots look (imo) better when you try and get an eye on a rule of third intersection. Shooting candidly, you don't really get chance to focus and recompose. Also, if shooting low light, I'll be using a prime probably wide open which equals no focus recompose as I'd have a very shallow dof. So, I'd either use one of the (so called) outer points which are inferior to the centre one, or use the centre and crop my pics a lot.
People manage with this AF layout right? This has just swung the ball in the 7d direction. I'd love FF for the high ISO and ability to really isolate your subjects, but I seem to be giving up a lot that the 7d offers to get it.
professoryeti
Jan 12, 2010 16:21 |  #8
Seems like you could "crop compose" with a center point focus and 21mp. Of course if you want or need all of that resolution it wouldn't work, but for those with more flexible requirements that could be a simple solution.
Saturnalia for all you have.
5D Mark II | 5D | 24mm f/1.4L II | 35mm f/1.4L | Nikkor 50mm f/1.2 | Canon 100mm f/2.8L | 24-105mm f/4L | 70-200mm f/2.8L IS II |
JoshNibertPhotography.​com (external link)
elader
Joined Nov 2005
Jan 12, 2010 16:55 |  #9
1dsmkII - 45 points of love. But even in the 1 series, the focusing ellipse is the same size between the 1.3crop and the FF - meaning it covers less area in the FF cameras.
I use the center point on the 5D mostly. Occasionally I use an off center point. usually that works out.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
.mark.
Jan 12, 2010 16:58 |  #10
professoryeti wrote in post #9380504 (external link)
The "crop compose" method would work but I prefer to get as much right in camera. Maybe I'm overreacting and this isn't a big issue. I'm going through the 5d2 pic thread and thinking "I wonder what focus point was used here"!
laydros
Jan 12, 2010 17:40 |  #11
I probably haven't done enough candid stuff with my 5D yet, I just haven't had much time to use it, but I typically did the focus and recompose business on my 40D, and didn't have a ton of trouble.
The 5D II is going to have considerably better high ISO than the 7D.
If you are taking the time to switch up focus points, you can use that upper right and then recomposing to the 1/3 cross isn't very far, so the change in focus isn't great. I wouldn't be too worried with the primes you have now, but if you picked up the 50L or 85L you may have some trouble wide open.
Unfortunately this isn't really something you can test out in a store, all I can offer is that despite the fact I said it IS a problem, it hasn't bothered me in doing shooting pretty similar to what you do. And to me FF is the way to go, unless you need the weather sealing or fast AF and fps of the 7D. It is a heck of a camera, and I loved my 40D, but the 5D is just right.
Erik_L
Jan 12, 2010 17:45 |  #12
I was using a 5D2 in store with a 24-70 f/2.8L and I had trouble focusing on peoples faces that were just several feet away from me. It would simply refuse to lock and would go back and forth a few times. stuck the lens on my 50D and shot away.
I don't know what's up, but something is fishy.
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
toxic
Jan 12, 2010 18:18 |  #13
The AF point spread is basically the same in all of Canon's cameras. It only appears smaller in the 5D because it has the largest sensor, and not enough people have a 1Ds to complain about it.
There was a tech tips article awhile ago about it, basically it's very difficult to make useful AF points very far from the center of the lens.
laydros
Jan 12, 2010 20:47 |  #14
toxic wrote in post #9381162 (external link)
Hmm.. looks like you are right:
1Ds:
IMAGE: http://a.img-dpreview.com/reviews/CanonEOS1DSMarkIII/images/vf.jpg
1D:
IMAGE: http://a.img-dpreview.com/reviews/CanonEOS1DMkII/Images/viewfinderdiag.gif
I think they designed the 1D/1Ds system for 1.3x, and the 5D/40D for 1.6x. The coverage is pretty decent on the crops. Unfortunately if the 7D system makes it into the next 5D or 3D, it still doesn't have great coverage.
D700 looks about the same, maybe a little better:
IMAGE: http://a.img-dpreview.com/reviews/nikond700/images/d700viewfinderview.jpg
But the D300 has really nice coverage.
tvphotog
Jan 12, 2010 21:53 |  #15
.mark. wrote in post #9380094 (external link)
I would say that if you use all the focus points and you're wide open, you're going to get some shots with your main subject out of focus because one of the peripheral points picks up an extraneous object in the background, for example. For candids, don't you think that most subjects will be in more or less the same plane? If not, I'd go one f/stop higher, and use only the central point and recompose. And if you set the camera so you can change to a single peripheral point, you'll lose the shot in the time it takes to change the focus point.
I think IQ is better with the 5D2 than the 7D, esp at high iso's.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
8,423 views & 0 likes for this thread, 20 members have posted to it.
1027 guests, 106 members online
